Does bootloader need put data on MBR section of coed?
I am developing a product based on nrf52840 soc, I need to write a softdevice, program hex file, bootloader on the chip. when I want to select them all in the nrf connect to program the chip, nrf connect says that bootloader and softdevice have some overlapping data. as I can see this overlapping occurs in the MBR section.
is this normal? does bootloader need to put data on the MBR section of code?
I've attached the bootloader and softdevice.
thanks
bootloader.hexsoftdevice.hex
  • Hi Alireza,
    Which SDK version are you using? It could sound like you are using SDK v15.3.0, where we introduced support for the v6.1.1 SoftDevices. The v6.1.1 SoftDevices allows the bootloader to write the bootloader start address and the MBR parameter page address to flash locations inside the MBR. The MBR will then use these addresses instead of fecthing the bootloader start and the MBR parameter page addresses from the UICR registers. If the bootloader start and the MBR parameter page address is not written to the MBR region, then the MBR will try to fetch the addresses from UICR like before.
    In SDK v15.3.0 we modified the bootloader project so that it would place the bootloader start and the MBR parameter page addresses in the MBR region, i.e. it would place the bootloader start and MBR parameter page addresses at 0xFF8 and 0xFFC respectivly. So the compiled bootloader binary will contain code in the MRB region, so this is why nRF Connect Programmer states that the bootloader and SoftDevice( specifically the MBR) overlaps.
    This can be solved by modifying the bootloader to place the bootlaoder start address and MBR parameter page to UICR and then write to 0xFF8 and 0xFFC at run-time, rather than placing the addresses in the MBR region in the compiled binary. The bootloader will only perform the write to the MBR region on the first start up and on all subsequent startups the values inside the MBR will be used and not the ones stored in the UICR registers.
    The modification needed is adding the snippet below to main() before nrf_bootloader_flash_protect().
    Then you need to  modify the flash_placement.xml to place the addresses in UICR instead of flash.
    Best regards
    Bjørn
  • Thank you so much for a detailed answer,
    Yes, I am using SDK v15.3. just some points that I did not get from your answer:
    1. what is the benefit of placing data in the MBR section instead of UICR?
    2. I have got PCA10059 bootloader from https://devzone.nordicsemi.com/f/nordic-q-a/40924/how-can-i-restore-the-original-bootloader-of-a-pca10059, and this bootloader also has data in the MBR section. and also I have written SoftDevice in the PCA10059 many times and softdevice has data in the MBR section. so I think every time I write softdevice to PCA10059 stored data of bootloader in MBR section will be erased. how PCA10059 bootloader handle this?
     The UICR can potentially be erased from on-chip code through the ERASEUICR register. So writing the addresses to the MBR adds a level of security, i.e. this will ensure that the NRF52 will jump to the bootloader in the unlikely case the the UICR registers are accidentally erased.
     If you add the changes that I suggested, then the addresses will be written at run-time when the bootloader starts up, so then it does not matter if you re-flash the SoftDevice.
