How do I redirect printf in ble_template_app?
So I'm trying to start off development of my project using the PCA10040 development board. I have downloaded the SDK16 and built a couple of examples no problem using SES. Now I have started using the ble_app_template  - which builds fine and seems just right to base development on.
Until I try to use the UART. I've searched & tried dozens of things, none of which work and often break the project. Often the Googled answer to a question is just "please look at the UART example" which doesn't help with modifying another example. After two days of trying to get this one simple thing working I've finally decided to ask here..
It looks like the printf redirect is the simplest option, but there isn't any option in the sdconfig.h which is incomplete.
So what do I need to do to turn off the debug logging and to output to the UART?
Thanks!
  • It does look strange, yes. Stranger when I perform "build & debug", because when I click "go" it works as expected (!)
    I noticed that the output actually  looks like "He" <pause> "llo world", where the <pause> is maybe 100ms. So maybe something to do with power management?
  • The power management should not affect this, as the events from the UART peripheral should wake the CPU.
    Could you upload your current project for us to reproduce and debug the behavior that you are seeing?
  • Sure,  Here's the main.c
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    //#include "nrf_log.h"
    //#include "nrf_log_ctrl.h"
    //#include "nrf_log_default_backends.h"
    #include "app_uart.h"
    #define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    static void uart_init(void)
    	ret_code_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              APP_UART_FLOW_CONTROL_DISABLED,
              false,
              //NRF_UARTE_BAUDRATE_115200
              UARTE_BAUDRATE_BAUDRATE_Baud115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                           ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
        /* YOUR_JOB: Add code to initialize the services used by the application.
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                //NRF_LOG_INFO("Fast advertising.");
                //APP_ERROR_CHECK(err_code);
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                //NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                //NRF_LOG_INFO("Connected.");
               // APP_ERROR_CHECK(err_code);
               // NRF_LOG_DEBUG("PHY update request.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Client Timeout.");
            case BLE_GATTS_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Server Timeout.");
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        //NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    //static void log_init(void)
    //    ret_code_t err_code = NRF_LOG_INIT(NULL);
    //    NRF_LOG_DEFAULT_BACKENDS_INIT();
        //if (NRF_LOG_PROCESS() == false)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        uart_init();
        printf("Hello World\r\n");
        printf("Line2\r\n");
        //log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        //NRF_LOG_INFO("Template example started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    I'm now getting an inexpected error trying to embed sdk_config.h so I'll try to put into a separate message
  • Sorry, the site won't accept sdk_config as embedded code, so it will have to be pasted as text:
    19.03.sdk_config.h
  • Finally the project file
    <!DOCTYPE CrossStudio_Project_File>
    <solution Name="ble_app_template_pca10040_s132" target="8" version="2">
      <project Name="ble_app_template_pca10040_s132">
        <configuration
          Name="Common"
          arm_architecture="v7EM"
          arm_core_type="Cortex-M4"
          arm_endian="Little"
          arm_fp_abi="Hard"
          arm_fpu_type="FPv4-SP-D16"
          arm_linker_heap_size="8192"
          arm_linker_process_stack_size="0"
          arm_linker_stack_size="8192"
          arm_linker_treat_warnings_as_errors="No"
          arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
          arm_target_device_name="nRF52832_xxAA"
          arm_target_interface_type="SWD"
          c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10040;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52;NRF52832_XXAA;NRF52_PAN_74;NRF_SD_BLE_API_VERSION=7;S132;SOFTDEVICE_PRESENT;"
          c_user_include_directories="../../../../../NRFSDK16/components/libraries/fifo;../../../../../NRFSDK16/components/libraries/uart;../../../config;../../../../../NRFSDK16/components;../../../../../NRFSDK16/components/ble/ble_advertising;../../../../../NRFSDK16/components/ble/ble_dtm;../../../../../NRFSDK16/components/ble/ble_racp;../../../../../NRFSDK16/components/ble/ble_services/ble_ancs_c;../../../../../NRFSDK16/components/ble/ble_services/ble_ans_c;../../../../../NRFSDK16/components/ble/ble_services/ble_bas;../../../../../NRFSDK16/components/ble/ble_services/ble_bas_c;../../../../../NRFSDK16/components/ble/ble_services/ble_cscs;../../../../../NRFSDK16/components/ble/ble_services/ble_cts_c;../../../../../NRFSDK16/components/ble/ble_services/ble_dfu;../../../../../NRFSDK16/components/ble/ble_services/ble_dis;../../../../../NRFSDK16/components/ble/ble_services/ble_gls;../../../../../NRFSDK16/components/ble/ble_services/ble_hids;../../../../../NRFSDK16/components/ble/ble_services/ble_hrs;../../../../../NRFSDK16/components/ble/ble_services/ble_hrs_c;../../../../../NRFSDK16/components/ble/ble_services/ble_hts;../../../../../NRFSDK16/components/ble/ble_services/ble_ias;../../../../../NRFSDK16/components/ble/ble_services/ble_ias_c;../../../../../NRFSDK16/components/ble/ble_services/ble_lbs;../../../../../NRFSDK16/components/ble/ble_services/ble_lbs_c;../../../../../NRFSDK16/components/ble/ble_services/ble_lls;../../../../../NRFSDK16/components/ble/ble_services/ble_nus;../../../../../NRFSDK16/components/ble/ble_services/ble_nus_c;../../../../../NRFSDK16/components/ble/ble_services/ble_rscs;../../../../../NRFSDK16/components/ble/ble_services/ble_rscs_c;../../../../../NRFSDK16/components/ble/ble_services/ble_tps;../../../../../NRFSDK16/components/ble/common;../../../../../NRFSDK16/components/ble/nrf_ble_gatt;../../../../../NRFSDK16/components/ble/nrf_ble_qwr;../../../../../NRFSDK16/components/ble/peer_manager;../../../../../NRFSDK16/components/boards;../../../../../NRFSDK16/components/libraries/atomic;../../../../../NRFSDK16/components/libraries/atomic_fifo;../../../../../NRFSDK16/components/libraries/atomic_flags;../../../../../NRFSDK16/components/libraries/balloc;../../../../../NRFSDK16/components/libraries/bootloader/ble_dfu;../../../../../NRFSDK16/components/libraries/bsp;../../../../../NRFSDK16/components/libraries/button;../../../../../NRFSDK16/components/libraries/cli;../../../../../NRFSDK16/components/libraries/crc16;../../../../../NRFSDK16/components/libraries/crc32;../../../../../NRFSDK16/components/libraries/crypto;../../../../../NRFSDK16/components/libraries/csense;../../../../../NRFSDK16/components/libraries/csense_drv;../../../../../NRFSDK16/components/libraries/delay;../../../../../NRFSDK16/components/libraries/ecc;../../../../../NRFSDK16/components/libraries/experimental_section_vars;../../../../../NRFSDK16/components/libraries/experimental_task_manager;../../../../../NRFSDK16/components/libraries/fds;../../../../../NRFSDK16/components/libraries/fstorage;../../../../../NRFSDK16/components/libraries/gfx;../../../../../NRFSDK16/components/libraries/gpiote;../../../../../NRFSDK16/components/libraries/hardfault;../../../../../NRFSDK16/components/libraries/hci;../../../../../NRFSDK16/components/libraries/led_softblink;../../../../../NRFSDK16/components/libraries/log;../../../../../NRFSDK16/components/libraries/log/src;../../../../../NRFSDK16/components/libraries/low_power_pwm;../../../../../NRFSDK16/components/libraries/mem_manager;../../../../../NRFSDK16/components/libraries/memobj;../../../../../NRFSDK16/components/libraries/mpu;../../../../../NRFSDK16/components/libraries/mutex;../../../../../NRFSDK16/components/libraries/pwm;../../../../../NRFSDK16/components/libraries/pwr_mgmt;../../../../../NRFSDK16/components/libraries/queue;../../../../../NRFSDK16/components/libraries/ringbuf;../../../../../NRFSDK16/components/libraries/scheduler;../../../../../NRFSDK16/components/libraries/sdcard;../../../../../NRFSDK16/components/libraries/sensorsim;../../../../../NRFSDK16/components/libraries/slip;../../../../../NRFSDK16/components/libraries/sortlist;../../../../../NRFSDK16/components/libraries/spi_mngr;../../../../../NRFSDK16/components/libraries/stack_guard;../../../../../NRFSDK16/components/libraries/strerror;../../../../../NRFSDK16/components/libraries/svc;../../../../../NRFSDK16/components/libraries/timer;../../../../../NRFSDK16/components/libraries/twi_mngr;../../../../../NRFSDK16/components/libraries/twi_sensor;../../../../../NRFSDK16/components/libraries/usbd;../../../../../NRFSDK16/components/libraries/usbd/class/audio;../../../../../NRFSDK16/components/libraries/usbd/class/cdc;../../../../../NRFSDK16/components/libraries/usbd/class/cdc/acm;../../../../../NRFSDK16/components/libraries/usbd/class/hid;../../../../../NRFSDK16/components/libraries/usbd/class/hid/generic;../../../../../NRFSDK16/components/libraries/usbd/class/hid/kbd;../../../../../NRFSDK16/components/libraries/usbd/class/hid/mouse;../../../../../NRFSDK16/components/libraries/usbd/class/msc;../../../../../NRFSDK16/components/libraries/util;../../../../../NRFSDK16/components/nfc/ndef/conn_hand_parser;../../../../../NRFSDK16/components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../NRFSDK16/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../NRFSDK16/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/ac_rec;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/common;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/hs_rec;../../../../../NRFSDK16/components/nfc/ndef/connection_handover/le_oob_rec;../../../../../NRFSDK16/components/nfc/ndef/generic/message;../../../../../NRFSDK16/components/nfc/ndef/generic/record;../../../../../NRFSDK16/components/nfc/ndef/launchapp;../../../../../NRFSDK16/components/nfc/ndef/parser/message;../../../../../NRFSDK16/components/nfc/ndef/parser/record;../../../../../NRFSDK16/components/nfc/ndef/text;../../../../../NRFSDK16/components/nfc/ndef/uri;../../../../../NRFSDK16/components/nfc/platform;../../../../../NRFSDK16/components/nfc/t2t_lib;../../../../../NRFSDK16/components/nfc/t2t_parser;../../../../../NRFSDK16/components/nfc/t4t_lib;../../../../../NRFSDK16/components/nfc/t4t_parser/apdu;../../../../../NRFSDK16/components/nfc/t4t_parser/cc_file;../../../../../NRFSDK16/components/nfc/t4t_parser/hl_detection_procedure;../../../../../NRFSDK16/components/nfc/t4t_parser/tlv;../../../../../NRFSDK16/components/softdevice/common;../../../../../NRFSDK16/components/softdevice/s132/headers;../../../../../NRFSDK16/components/softdevice/s132/headers/nrf52;../../../../../NRFSDK16/components/toolchain/cmsis/include;../../../../../NRFSDK16/external/fprintf;../../../../../NRFSDK16/external/segger_rtt;../../../../../NRFSDK16/external/utf_converter;../../../../../NRFSDK16/integration/nrfx;../../../../../NRFSDK16/integration/nrfx/legacy;../../../../../NRFSDK16/modules/nrfx;../../../../../NRFSDK16/modules/nrfx/drivers/include;../../../../../NRFSDK16/modules/nrfx/hal;../../../../../NRFSDK16/modules/nrfx/mdk;../config;"
          debug_additional_load_file="../../../../../NRFSDK16/components/softdevice/s132/hex/s132_nrf52_7.0.1_softdevice.hex"
          debug_register_definition_file="../../../../../NRFSDK16/modules/nrfx/mdk/nrf52.svd"
          debug_start_from_entry_point_symbol="No"
          debug_target_connection="J-Link"
          gcc_debugging_level="Level 3"
          gcc_entry_point="Reset_Handler"
          linker_output_format="hex"
          linker_printf_fmt_level="long"
          linker_printf_width_precision_supported="Yes"
          linker_scanf_fmt_level="long"
          linker_section_placement_file="flash_placement.xml"
          linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002250;RAM_SIZE=0xddb0"
          linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000"
          macros="CMSIS_CONFIG_TOOL=../../../../../NRFSDK16/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
          project_directory=""
          project_type="Executable" />
        <folder Name="Segger Startup Files">
          <file file_name="$(StudioDir)/source/thumb_crt0.s" />
        </folder>
        <folder Name="nRF_Log">
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_backend_rtt.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_backend_serial.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_backend_uart.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_default_backends.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_frontend.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/log/src/nrf_log_str_formatter.c" />
        </folder>
        <folder Name="nRF_Libraries">
          <file file_name="../../../../../NRFSDK16/components/libraries/button/app_button.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/util/app_error.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/util/app_error_handler_gcc.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/util/app_error_weak.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/scheduler/app_scheduler.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/timer/app_timer2.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/util/app_util_platform.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/crc16/crc16.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/timer/drv_rtc.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/fds/fds.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/hardfault/hardfault_implementation.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/util/nrf_assert.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/atomic_fifo/nrf_atfifo.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/atomic_flags/nrf_atflags.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/atomic/nrf_atomic.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/balloc/nrf_balloc.c" />
          <file file_name="../../../../../NRFSDK16/external/fprintf/nrf_fprintf.c" />
          <file file_name="../../../../../NRFSDK16/external/fprintf/nrf_fprintf_format.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/fstorage/nrf_fstorage.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/fstorage/nrf_fstorage_sd.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/memobj/nrf_memobj.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/ringbuf/nrf_ringbuf.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/experimental_section_vars/nrf_section_iter.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/sortlist/nrf_sortlist.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/strerror/nrf_strerror.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/sensorsim/sensorsim.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/uart/retarget.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/uart/app_uart_fifo.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/fifo/app_fifo.c" />
        </folder>
        <folder Name="None">
          <file file_name="../../../../../NRFSDK16/modules/nrfx/mdk/ses_startup_nrf52.s" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/mdk/ses_startup_nrf_common.s" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/mdk/system_nrf52.c" />
        </folder>
        <folder Name="Board Definition">
          <file file_name="../../../../../NRFSDK16/components/boards/boards.c" />
        </folder>
        <folder Name="nRF_Drivers">
          <file file_name="../../../../../NRFSDK16/integration/nrfx/legacy/nrf_drv_clock.c" />
          <file file_name="../../../../../NRFSDK16/integration/nrfx/legacy/nrf_drv_uart.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/soc/nrfx_atomic.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/drivers/src/nrfx_clock.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/drivers/src/nrfx_gpiote.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/drivers/src/prs/nrfx_prs.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/drivers/src/nrfx_uart.c" />
          <file file_name="../../../../../NRFSDK16/modules/nrfx/drivers/src/nrfx_uarte.c" />
        </folder>
        <folder Name="Board Support">
          <file file_name="../../../../../NRFSDK16/components/libraries/bsp/bsp.c" />
          <file file_name="../../../../../NRFSDK16/components/libraries/bsp/bsp_btn_ble.c" />
        </folder>
        <folder Name="Application">
          <file file_name="../../../main.c" />
          <file file_name="../config/sdk_config.h" />
        </folder>
        <folder Name="nRF_Segger_RTT">
          <file file_name="../../../../../NRFSDK16/external/segger_rtt/SEGGER_RTT.c" />
          <file file_name="../../../../../NRFSDK16/external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
          <file file_name="../../../../../NRFSDK16/external/segger_rtt/SEGGER_RTT_printf.c" />
        </folder>
        <folder Name="nRF_BLE">
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/auth_status_tracker.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/common/ble_advdata.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/ble_advertising/ble_advertising.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/common/ble_conn_params.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/common/ble_conn_state.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/common/ble_srv_common.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/gatt_cache_manager.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/gatts_cache_manager.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/id_manager.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/peer_data_storage.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/peer_database.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/peer_id.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/peer_manager.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/peer_manager_handler.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/pm_buffer.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/security_dispatcher.c" />
          <file file_name="../../../../../NRFSDK16/components/ble/peer_manager/security_manager.c" />
        </folder>
        <folder Name="UTF8/UTF16 converter">
          <file file_name="../../../../../NRFSDK16/external/utf_converter/utf.c" />
        </folder>
        <folder Name="nRF_SoftDevice">
          <file file_name="../../../../../NRFSDK16/components/softdevice/common/nrf_sdh.c" />
          <file file_name="../../../../../NRFSDK16/components/softdevice/common/nrf_sdh_ble.c" />
          <file file_name="../../../../../NRFSDK16/components/softdevice/common/nrf_sdh_soc.c" />
        </folder>
      </project>
      <configuration
        Name="Release"
        c_preprocessor_definitions="NDEBUG"
        gcc_optimization_level="Optimize For Size" />
      <configuration
        Name="Debug"
        c_preprocessor_definitions="DEBUG; DEBUG_NRF"
        gcc_optimization_level="None" />
    </solution>
