I am using the nRF9160dk development board and I could not find a test or example for the internal RTC. could you provide a simple example of using the internal RTC.
You can take a look at this sample, it uses the RTC directly.
But for most use-cases, you should use the kernel timer instead (the kernel timer uses the RTC). See this page
Snippet:
struct k_timer single_shot_timer;
struct k_timer multi_shot_timer;
static void my_expiry_function_1(struct k_timer *timer)
ARG_UNUSED(timer);
printk("single_shot_timer expired\n");
static void my_expiry_function_2(struct k_timer *timer)
ARG_UNUSED(timer);
printk("multi_shot_timer expired\n");
void main(void)
printk("The kernel timer sample started\n"); // Doc: https://docs.zephyrproject.org/latest/reference/kernel/timing/timers.html
/* start one single shot timer that expires after 5000 ms */
/* start one multi shot timer that expires after 5000ms, and then every 5000 ms */
k_timer_start(&single_shot_timer, K_MSEC(5000), 0);
k_timer_start(&multi_shot_timer, K_MSEC(5000), K_MSEC(5000) );
K_TIMER_DEFINE(single_shot_timer, my_expiry_function_1, NULL);
K_TIMER_DEFINE(multi_shot_timer, my_expiry_function_2, NULL);Sigrud
yes I know how to use the timers. that is not what I want here. I will use the timers for other things in the application. I want a real time clock that knows it is March 17,202 and will know months, days, leap years etc. I loaded and ran the RTC example you pointed me to. it did nothing so I assume I did not do the following.
Starting nrfx rtc sample!
To run in non-secure mode, you need to add RTC0 to spm.c
I did not understand what this meant. what do I need to add and where do I add it to spm.c. if this is a real RTC then this is what I need. I could not find the supporting documention (apis, etc.).
