Unable to Perform a DFU over USB CDC ACM (the Bootloader never boots the new app)
For my all DFU i follow the steps on the Getting started guide , just in the Performing DFU step i use the nrfutil tool for the over USB.
First i tried with the DFU examples provided, i started with the open_bootloader , uploaded that to the nrf52840 dk after a full erase. and then use nrfutil to upload the blinky_mbr.zip package located in the secure_dfu_test_images folder. the package gets loaded to the board, i can see the uploading process over the Command line.but, after that the blinky_mbr app never gets started. the board just turns off all the LEDs , and when i Reset it starts in the Bootloader mode, it never jumps to the app. i still can see the the bootloader /app files in nrf connect.
I used the debug version of the bootloader, And here is the logging i get:
Starting from the upload of the bootloader till the end of the DFU.
<info> app: Open USB bootloader started
<debug> app: In nrf_bootloader_init
<debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
<debug> nrf_dfu_settings: Writing settings...
<debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
<debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20008640, len=896 bytes), queue usage: 1
<debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
<info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
<debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1
<debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x200089C0, len=896 bytes), queue usage: 1
<debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0
<debug> app: Enter nrf_bootloader_fw_activate
<info> app: No firmware to activate.
<info> app: Boot validation failed. No valid app to boot.
<debug> app: DFU mode because app is not valid.
<info> nrf_bootloader_wdt: WDT is not enabled
<debug> app: in weak nrf_dfu_init_user
<debug> app: timer_stop (0x20000054)
<info> app: Entering DFU mode.
<info> app_timer: RTC: initialized.
<debug> app: Initializing transports (found: 1)
<debug> nrf_dfu_serial_usb: Initializing drivers.
<debug> nrf_dfu_serial_usb: Starting USB
<debug> nrf_dfu_serial_usb: USB Transport initialized
<debug> app: Enter main loop
<info> nrf_dfu_serial_usb: USB power detected
<info> nrf_dfu_serial_usb: USB ready
<warning> nrf_dfu_serial_usb: Could not read from CDC. Error: 0x92.
<debug> nrf_dfu_serial: Set receipt notif target: 0
<debug> nrf_dfu_serial_usb: Allocated buffer 20000130
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
<debug> nrf_dfu_serial: Received serial mtu
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
<debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
<debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
<debug> app: Shutting down transports (found: 1)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
<debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
<debug> nrf_dfu_serial_usb: Allocated buffer 20000934
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
<debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
<debug> nrf_dfu_validation: PB: Init packet data len: 62
<debug> app: Enter nrf_dfu_cache_prepare()
<debug> app: required_size: 0x5E4.
<debug> app: single_bank: true.
<debug> app: keep_app: false.
<debug> app: keep_softdevice: false.
<debug> app: SD_PRESENT: false.
<debug> app: Bank contents:
<debug> app: Bank 0 code: 0x00: Size: 0x0
<debug> app: Bank 1 code: 0x00: Size: 0x0
<debug> app: pass: 0.
<debug> app: cache_address: 0x1000.
<debug> app: cache_too_small: false.
<debug> app: keep_firmware: false.
<debug> app: delete_more: true.
<debug> app: pass: 1.
<debug> app: keep_firmware: true.
<debug> app: Invalidating app.
<debug> nrf_dfu_validation: Write address set to 0x00001000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
<debug> nrf_dfu_req_handler: Writing valid init command to flash.
<debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
<debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00001000, len=1 pages), queue usage: 1
<debug> nrf_dfu_flash: Flash erase success: addr=0x00001000, pending 0
<debug> nrf_dfu_req_handler: Creating object with size: 1508. Offset: 0x00000000, CRC: 0x00000000
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001000, src=0x20000938, len=1024 bytes), queue usage: 1
<debug> nrf_dfu_flash: Flash write success: addr=0x00001000, pending 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001400, src=0x20000134, len=484 bytes), queue usage: 1
<debug> nrf_dfu_flash: Flash write success: addr=0x00001400, pending 0
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
<debug> nrf_dfu_req_handler: Offset:1508, CRC:0x3477E14C
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
<debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
<debug> nrf_dfu_validation: Hash verification. start address: 0x1000, size: 0x5E4
<debug> nrf_dfu_validation: Invalidating old application in bank 0.
<debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
<debug> app: Resetting bootloader.
<debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
<debug> nrf_dfu_settings: Using settings page.
<debug> nrf_dfu_settings: Copying forbidden parts from backup page.
<debug> app: Valid App
<debug> app: Enter nrf_dfu_app_continue
<debug> app: No copy needed
<debug> app: Setting app as valid
Have also tried to use the secure_bootloader, and trying to upload my DFU package, but same issue .and here is the logging i get:
Logs dropped (1)
<info> cdc_acm: EPOUT_DATA: 01 done
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
<debug> nrf_dfu_serial_usb: Allocated buffer 20000924
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017400, src=0x20000124, len=1024 bytes), queue usage: 1
Logs dropped (1)
<debug> nrf_dfu_flash: Flash write success: addr=0x00017400, pending 0
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
<debug> nrf_dfu_serial_usb: Allocated buffer 20000120
Logs dropped (2)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017800, src=0x20000928, len=1024 bytes), queue usage: 1
Logs dropped (2)
<debug> nrf_dfu_flash: Flash write success: addr=0x00017800, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (1)
Logs dropped (3)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017C00, src=0x20000124, len=1024 bytes), queue usage: 1
Logs dropped (2)
<debug> nrf_dfu_flash: Flash write success: addr=0x00017C00, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Offset:94208, CRC:0xA6AE13B9
Logs dropped (2)
Logs dropped (2)
<info> cdc_acm: EPIN_DATA: 81 done
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
<debug> app: timer_stop (0x20000044)
Logs dropped (2)
<debug> app: timer_activate (0x20000044)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00018000, len=1 pages), queue usage: 1
Logs dropped (5)
<debug> nrf_dfu_flash: Flash erase success: addr=0x00018000, pending 0
<debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00017000, CRC: 0xA6AE13B9
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
Logs dropped (2)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018000, src=0x20000928, len=1024 bytes), queue usage: 1
Logs dropped (2)
<debug> nrf_dfu_flash: Flash write success: addr=0x00018000, pending 0
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
Logs dropped (3)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018400, src=0x20000124, len=1024 bytes), queue usage: 1
Logs dropped (1)
<debug> nrf_dfu_flash: Flash write success: addr=0x00018400, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018800, src=0x20000928, len=1024 bytes), queue usage: 1
Logs dropped (2)
<debug> nrf_dfu_flash: Flash write success: addr=0x00018800, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018C00, src=0x20000124, len=1024 bytes), queue usage: 1
Logs dropped (2)
<debug> nrf_dfu_flash: Flash write success: addr=0x00018C00, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Offset:98304, CRC:0xD86AAEC2
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00019000, len=1 pages), queue usage: 1
Logs dropped (5)
<debug> nrf_dfu_flash: Flash erase success: addr=0x00019000, pending 0
<debug> nrf_dfu_req_handler: Creating object with size: 784. Offset: 0x00018000, CRC: 0xD86AAEC2
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019000, src=0x20000928, len=784 bytes), queue usage: 1
Logs dropped (5)
<debug> nrf_dfu_flash: Flash write success: addr=0x00019000, pending 0
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
<debug> nrf_dfu_req_handler: Offset:99088, CRC:0x3C49E020
Logs dropped (2)
Logs dropped (4)
Logs dropped (2)
Logs dropped (1)
Logs dropped (4)
<debug> nrf_dfu_validation: Hash verification. start address: 0x1000, size: 0x18310
Logs dropped (4)
Logs dropped (2)
Logs dropped (4)
Logs dropped (3)
Logs dropped (4)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x200084C8, len=896 bytes), queue usage: 1
Logs dropped (3)
Logs dropped (3)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (3)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20008848, len=896 bytes), queue usage: 1
Logs dropped (4)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
Logs dropped (2)
<info> app: Inside main
Best Regards,
Abdelali
