AT_CLIENT app not working
I have a Thingy91 pca20035 board (not the DK). So far, I have had success building my own modifications of the asset_tracker application by building it using SES and loading the HEX file into the device by using the nRF connect programmer.
My issue is that I am not able to make the AT_CLIENT work. I tried programming the device with the default HEX file (both the image_dfu and the image_full version) found in https://www.nordicsemi.com/Software-and-Tools/Prototyping-platforms/Nordic-Thingy-91/Download#infotabs (the asset_tracker application found there works just fine). I have tried both COM ports in the nRF connect LTE link monitor. I have also the "auto device/port filter" option unchecked. I have tried turning on and off the device as well as reloading the LTE Link Monitor several times. All I see is this:
Additionally, the UART, Modem, UICC and LTE indicators are red color, while the PDN indicator is grey in the LTE Link Monitor.
It would be nice if you guys have any suggestion?
  • This is the log file:
    2020-03-18T09:00:01.729Z INFO Application data folder: C:\Users\zdiva\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2020-03-18T09:00:01.791Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-03-18T09:00:01.792Z DEBUG App path: C:\Users\zdiva\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2020-03-18T09:00:01.792Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-03-18T09:00:01.792Z DEBUG nRFConnect path: C:\Users\zdiva\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-03-18T09:00:01.792Z DEBUG HomeDir: C:\Users\zdiva
    2020-03-18T09:00:01.792Z DEBUG TmpDir: C:\Users\zdiva\AppData\Local\Temp
    2020-03-18T09:00:08.442Z INFO Modem port is opened
    2020-03-18T09:00:08.448Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-18T09:02:51.075Z DEBUG modem >> AT\x0D\x0A
    2020-03-18T09:02:52.076Z ERROR Error: 'AT
    ' timed out
    2020-03-18T09:02:58.827Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-18T09:02:59.828Z ERROR Error: 'AT+CFUN?
    ' timed out
    2020-03-18T09:03:00.489Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2020-03-18T09:03:01.490Z ERROR Error: 'AT+CFUN=1
    ' timed out
    And this is how the LTE Link Monitor looks like:
    I am trying to send any command. I am using the same HEX image that worked once yesterday (thingy91_at_client_dfu_2019-11-29_d3130d77.hex). Yesterday I was able to send a few AT commands, the most important for me is the AT+CESQ, I even could receive RSRP notifications!!.
  • What version of the Thingy:91 do you have?
    When you got it to work, did you see this log at startup?
    I know people have had trouble with the serial connection in the past but I believe the issue has been fixed.
    Are you running the newest modem firmware version 1.1.1?
    2020-03-18T09:11:00.311Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.311Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.312Z DEBUG modem << 02 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.312Z DEBUG modem << 03 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.314Z DEBUG modem << 04 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.315Z DEBUG modem << 05 NRF_UARTE2           Secure\x09\x09SKIP\x0D\x0A
    2020-03-18T09:11:00.316Z DEBUG modem << 06 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.316Z DEBUG modem << 07 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.317Z DEBUG modem << 08 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.318Z DEBUG modem << 09 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.320Z DEBUG modem << 10 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.321Z DEBUG modem << 11 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.322Z DEBUG modem << 12 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.322Z DEBUG modem << 13 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.323Z DEBUG modem << 14 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.323Z DEBUG modem << 15 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.324Z DEBUG modem << 16 NRF_WDT              Secure\x09\x09SKIP\x0D\x0A
    2020-03-18T09:11:00.325Z DEBUG modem << 17 NRF_IPC              Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.327Z DEBUG modem << 18 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.328Z DEBUG modem << 19 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.329Z DEBUG modem << 20 NRF_EGU1             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.330Z DEBUG modem << 21 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.330Z DEBUG modem << 22 NRF_DPPIC            Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.330Z DEBUG modem << 23 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2020-03-18T09:11:00.331Z DEBUG modem << 24 NRF_REGULATORS       Secure\x09\x09SKIP\x0D\x0A\x0D\x0A
    2020-03-18T09:11:00.331Z DEBUG modem << SPM: NS image at 0x18200\x0D\x0A
    2020-03-18T09:11:00.332Z DEBUG modem << SPM: NS MSP at 0x20027fa0\x0D\x0A
    2020-03-18T09:11:00.333Z DEBUG modem << SPM: NS reset vector at 0x1a07d\x0D\x0A
    2020-03-18T09:11:00.334Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2020-03-18T09:11:00.335Z DEBUG modem << ***** Booting Zephyr OS build v2.0.99-ncs1 *****\x0D\x0A
    2020-03-18T09:11:00.335Z DEBUG modem << The AT host sample started\x0D\x0A
  • Well, I think my modem firmware is not the most recent. My version is mfw_nrf9160_1.0.0-24.rc.
    I did not save the log file for my only successful connection to LTE Link Monitor.
    Right now, I do not have access to a DK board. As far as I know, the only way to update the modem firmware is by using the DK board. So, I guess my older modem firmware has issues with reliable serial connection to LTE Link Monitor.
    Thanks for the help, Heidi :)
    Yes, unfortunately, as of now, this is the only way. MFW update via MCUboot is coming, though I can't give you a date for that right now.
  • Just a message for people who have the same issue I had: the ASSET_TRACKER application can be used to connect to the LTE LINK MONITOR. It allows sending AT commands and reading the device response. the AT_CLIENT application is bugged in my opinion.
