Unfortunately, I'm not seeing NRF_EVT_POWER_FAILURE_WARNING events on my s210 based system. As I've seen in other questions on the forum, I've implemented the calls below with no luck. Attempts to use sd_evt_get() were also fruitless. Any ideas? Thank you!
err_code = sd_softdevice_enable(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, softdevice_assert_callback);
err_code = sd_nvic_SetPriority(SD_EVT_IRQn, NRF_APP_PRIORITY_LOW);
err_code = sd_nvic_EnableIRQ(SD_EVT_IRQn);
err_code = sd_power_pof_enable(true);
err_code = sd_power_pof_threshold_set(NRF_POWER_THRESHOLD_V27); /**< 2.5 Volts power failure threshold. */
for (;;)
err_code = sd_power_pof_enable(false);
err_code = sd_app_evt_wait();
// Extract and process all pending ANT events as
//long as there are any left.
do
// Fetch the event.
err_code = sd_ant_event_get(&ant_channel, &event_id, event_message_buffer);
if (err_code == NRF_SUCCESS)
// Handle event.
switch (event_id)
case NRF_EVT_POWER_FAILURE_WARNING:
set_led(); //never gets called
} while (err_code == NRF_SUCCESS);
