Sending a CSV File over ble Gatt connection
I need to send data from a CSV file on the nordic board(Via fatfs library). I have presently gotten a Gatt service up and running.
I have a mobile application which, can see the gatt service and write to the characteristics. From a specific write command from the mobile device I want the nordic board to send the CSV file over.
I can presently read a single line of the CSV file formatted like this: (Time stamp, data1, data 2, data3, data 4, data 5).
What I need to implement is:
  • Reading the whole file but, one or multiple lines at a time due to the size of the CSV
  • Changing the read pointer of the SD card (So I know where to continue to read from)
  • Send this data to the characteristic
  • Read this characteristic data.
My code is based upon :  https://github.com/bjornspockeli/custom_ble_service_example
My CSV file size depends on the length of time I have been storing data from. It could be upto around 1-2mbytes. I beleive I need to set up some kind of notification service. Where I read a line(or several) of the SD card, set the GATT characteristic value to this. Then change the SD card pointer. Wait till the data is received by the mobile application. Then repeat until the file is read full.y
Note I am using SDK 16 NRF52840-dk PCA 10056 S140.
This post is similar and mentions using two characteristics one from commication from the mobile app and, one for receiving the data.
https://devzone.nordicsemi.com/f/nordic-q-a/53987/nrf52840-file-transfer-via-ble
  • Try to set:
    data_lengt = 51;
    (hardcode it) to see if the length is the issue.
    And where do you call SEND_CSV() from? Do you do it once, or many times?
    If that doesn't give any improvement, compare the data in the nRF Connect for Mobile (your last screenshot) with the data that you are sending. You probably need an ascii table to translate it. Compare the bytes after the ble_csv_data array with the data being sent. Does it look similar?
    I don't know what IDE you are using, so I'll show you for SES. If you are using something else, you can probably find out how you can see it using google.
    As you can see, you can see what's located in the RAM after the array of "helloworld". If that area is used before, it is likely populated, and if the length is incorrectly set, then the data you send will look like jibberish.
    Edvin
  • Cheers, I do use SES.
    I did set the data length to 51 made no difference. Below is my output
    So the first bits of data are fine but the rest is 0. This is the same for the NRF connect application.
    SEND_CSV is sent once. If i press a specific command on my phone. Which writes gatt data to another characteristic. Then runs in the main loop.
  • So it seems like you do not want to send 51 bytes, then? In this case, it looks like you would only want to send 41 bytes? Perhaps you should try to cut after you see "0D 0A", since each line would end with this?
    I suspect that you read it into the same area each time, so the next time you would call this, and the new line is shorter than the previous one, you probably don't reset this string, and you send the full 51 bytes again, is that correct?
    1st line:
    31 35 38 34 39 36 39 30 36 35 2C 31 38 37 35 26 31 38 34 33 2C 31 38 36 32 2C 31 38 36 32 2C 2D 30 2E 30 32 30 30 30 30 0D 0A 00 00 00 00 00 00 00 00 00
    Then for the argument's sake, let us say that your second line is only: "1,2,3", which would be "31 32 33 0D 0A", then that would not be the case if you send the entire 51 bytes. It would be:
    31 32 33 0D 0A 36 39 30 36 35 2C 31 38 37 35 26 31 38 34 33 2C 31 38 36 32 2C 31 38 36 32 2C 2D 30 2E 30 32 30 30 30 30 0D 0A 00 00 00 00 00 00 00 00 00
    Remember that the softdevice will do exactly what you tell it to do. If you tell it to send 51 bytes from a pointer, it will do that. If you tell it to send 247 bytes from a pointer, it will do that too. You must find out based on your readouts where the line ends, and then send that many bytes.
    BR,
    Edvin
    • Thank you for your response. I do want to send 51 bytes.
    • You are correct it reads the same data each time as I am just reading the first line of my CSV at the moment for testing purposes.
    • But, where in my code does it say send more than 51 bytes?
    • The data length I send into my ble_cus_send_csv is 51. But this function clearly sends more.
    • Also what do you mean by cut off? I read 51 bytes via my reading CSV function yes this will include commas, and return characters.
    • Or do I need to change this in the sdk_config.h? As NRF_SDH_BLE_GAP_DATA_LENGTH i have set to 251 from 27.
    Also to have only the specified bytes sent aka 51. Do I need:
    blcm_link_ctx_storage_t * const p_link_ctx_storage; /**< Pointer to link context storage with handles of all current connections and its context. */
        ble_nus_client_context_t * p_client;
        VERIFY_PARAM_NOT_NULL(p_nus);
        err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage, conn_handle, (void *) &p_client);
        VERIFY_SUCCESS(err_code);
  • It is the "sizeof()" that doesn't work exactly as you expect. Try to log the output from sizeof and see what it says.
     No. You don't need to do that.
    As long as you set the length to 51, it will send 51 bytes.
     From the post where you said this, it clearly sent 51 bytes. Is that the behavior that you want?
    The blcm_link_ctx_get() is a function used to fetch the notification status. Just to check whether notifications are enabled or not. It is not crucial, but nice to have. You can see where p_client is used later in the function where you found blcm (ble_nus_data_send()).
    Edvin
