Error occurs when adding more than one characteristic to a custom BLE service.
I have followed your tutorials on implementing custom service and one on custom characteristics. Everything works when adding only one characteristic. When calling sd_ble_gatts_characteristic_add() the second time I get a terminal error. I have already increased NRF_SDH_BLE_VS_UUID_COUNT to 5 but I have not modified NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE which is 1408. Please see my service code, sdk_config and main.c. I believe the error was out of memory. I need to double check that.
I have modified the RAM_SIZE and RAM_START in the project options (see screen cap). I increased RAM_START after running out of memory.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* Driver for SAADC side sensor */
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
/* Driver for TWI manager */
#include "nrf_twi_mngr.h"
#include "nrf_drv_twi.h"
#include "nrf_drv_gpiote.h"
#include "ble_tonepen.h"
/* Driver for TMD3702 color sensor */
#include "tmd3702.h"
#define DEVICE_NAME                     "Tonepen"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "Tonepen LLC"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_TONEPEN_DEF(p_tonepen_service);
/* -----------------Time for SAADC instance --------------------*/
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
/* --------------TWI instance ---------------------- */
#define TWI_INSTANCE_ID             0
#define MAX_PENDING_TRANSACTIONS    5
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
/* ------------BLE GATT and advertisement instances -------------- */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       ret_code_t err_code;
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    NOTE must be executed AFTER m_nrf_twi_mngr is initialized
    /* TODO do I need to zero out p_tonepen_service?? */
    tonepen_service_init(&p_tonepen_service, &m_nrf_twi_mngr);
    /* YOUR_JOB: Add code to initialize the services used by the application.
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            //err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            //APP_ERROR_CHECK(err_code);
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
            p_tonepen_service.conn_handle = BLE_CONN_HANDLE_INVALID;
            nrf_drv_timer_disable(&m_timer);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            p_tonepen_service.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/* This is executed before the SAADC callback (I think)*/
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 5);//400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    //nrf_drv_timer_enable(&m_timer);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
    channel_config.gain = NRF_SAADC_GAIN4;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
// TWI (with transaction manager) initialization.
static void twi_config(void)
    uint32_t err_code;
    nrf_drv_twi_config_t const config = {
       .scl                = TMD3702_SCL_PIN,
       .sda                = TMD3702_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
       .clear_bus_init     = false
    err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
void tmd3702_interrupt_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_out_toggle(TMD3702_INT);
 * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
 * and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_RAW_CONFIG_IN_SENSE_HITOLO(true);
    err_code = nrf_drv_gpiote_in_init(TMD3702_INT, &in_config, tmd3702_interrupt_pin_handler);
    nrf_drv_gpiote_in_event_enable(TMD3702_INT, true);
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Tonepen started.");
    application_timers_start();
    saadc_init();
    saadc_sampling_event_init();
    twi_config();
    gpio_init();
    tmd3702_init(&m_nrf_twi_mngr);
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
sdk_config.hble_tonepen.h
#include <stdint.h>
#include <string.h>
#include "SEGGER_RTT.h"
#include "../../../examples/ble_peripheral/ble_app_template/tmd3702.h"
void tonepen_tmd3702_read_callback(ret_code_t result, void * p_user_data) {
    ble_tonepen_t *p_tonepen = (ble_tonepen_t*) p_user_data;
    ble_gatts_value_t p_value;
    p_value.len = 2;
    p_value.offset = 0;
    p_value.p_value = read_data;
    //sd_ble_gatts_value_set(p_tonepen->conn_handle, p_tonepen->tmd3702_read_handles.value_handle, &p_value);
static void on_write(ble_tonepen_t * p_tonepen, ble_evt_t const * p_ble_evt)
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    if (   (p_evt_write->handle == p_tonepen->tmd3702_write_handles.value_handle)
        && (p_evt_write->len == 2)
        && p_tonepen->twi_mngr != NULL)
        tmd3702_sched_write_reg(p_tonepen->twi_mngr, p_evt_write->data[0], p_evt_write->data[1]);
    } else if (   (p_evt_write->handle == p_tonepen->tmd3702_read_handles.value_handle)
        && (p_evt_write->len == 1)
        tmd3702_sched_read_reg(p_tonepen->twi_mngr, p_evt_write->data[0], p_evt_write->data[1], tonepen_tmd3702_read_callback);
void ble_tonepen_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    ble_tonepen_t * p_tonepen = (ble_tonepen_t *)p_context;
        case BLE_GATTS_EVT_WRITE:
            on_write(p_tonepen, p_ble_evt);
static void tonepen_add_tmd_characteristics(ble_uuid128_t *base_uuid, ble_tonepen_t * p_tonepen_service) {
    uint32_t err_code;
    ble_uuid_t          char_writ_uuid, char_read_uuid, char_data_uuid;
    char_writ_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_TMD_REG_WRITE_UUID;
    char_read_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_TMD_REG_READ_UUID;
    char_data_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_TMD_DATA_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_writ_uuid.type);
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_read_uuid.type);
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_data_uuid.type);
    /* Config permissions  */
    ble_gatts_char_md_t char_writ_md, char_read_md, char_data_md;
    memset(&char_writ_md, 0, sizeof(char_writ_md));
    memset(&char_read_md, 1, sizeof(char_read_md));
    memset(&char_data_md, 2, sizeof(char_data_md));
    char_writ_md.char_props.write = 1;
    char_writ_md.char_props.read = 1;
    char_read_md.char_props.write = 1;
    char_read_md.char_props.read = 1;
    char_data_md.char_props.write = 1;
    char_data_md.char_props.read = 1;
    ble_gatts_attr_md_t attr_writ_md, attr_read_md, attr_data_md;
    memset(&attr_writ_md, 0, sizeof(attr_writ_md));
    memset(&attr_read_md, 0, sizeof(attr_read_md));
    memset(&attr_data_md, 0, sizeof(attr_data_md));
    attr_writ_md.vloc        = BLE_GATTS_VLOC_STACK;
    attr_read_md.vloc        = BLE_GATTS_VLOC_STACK;
    attr_data_md.vloc        = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_writ_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_writ_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_read_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_read_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_data_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_data_md.read_perm);
    /* config characteristic value attr */
    ble_gatts_attr_t    attr_char_writ_value;
    ble_gatts_attr_t    attr_char_read_value;
    ble_gatts_attr_t    attr_char_data_value;
    memset(&attr_char_writ_value, 0, sizeof(attr_char_writ_value));
    memset(&attr_char_read_value, 0, sizeof(attr_char_read_value));
    memset(&attr_char_data_value, 0, sizeof(attr_char_data_value));
    attr_char_writ_value.p_uuid      = &char_writ_uuid;
    attr_char_read_value.p_uuid      = &char_read_uuid;
    attr_char_data_value.p_uuid      = &char_data_uuid;
    attr_char_writ_value.p_attr_md   = &attr_writ_md;
    attr_char_read_value.p_attr_md   = &attr_read_md;
    attr_char_data_value.p_attr_md   = &attr_data_md;
    attr_char_writ_value.max_len     = 1;
    attr_char_writ_value.init_len    = 1;
    attr_char_read_value.max_len     = 1;
    attr_char_read_value.init_len    = 1;
    attr_char_data_value.max_len     = 1;
    attr_char_data_value.init_len    = 1;
    uint8_t value[10]            = {0,0,0,0,0,0,0,0,0,0};
                                    //0,0,0,0,0,0,0,0,0,0,
                                    //0,0};
    attr_char_writ_value.p_value     = value;
    attr_char_read_value.p_value     = value;
    attr_char_data_value.p_value     = value;
    err_code = sd_ble_gatts_characteristic_add(p_tonepen_service->service_handle,
                                   &char_writ_md,
                                   &p_tonepen_service->char_writ_handles);
                                   &char_read_md,
                                   &p_tonepen_service->char_read_handles);
    return;
                                   &char_data_md,
                                   &p_tonepen_service->char_data_handles);
    return ;
void tonepen_service_init(ble_tonepen_t * p_tonepen_service, nrf_twi_mngr_t *twi_mngr)
    uint32_t err_code;
    // STEP 3: Declare 16 bit service and 128 bit base UUIDs and add them to BLE stack table
    ble_uuid_t    service_uuid;
    ble_uuid128_t base_uuid = BLE_UUID_TONEPEN_BASE_UUID;
    service_uuid.uuid = BLE_UUID_TONEPEN_SERVICE;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
    p_tonepen_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    // STEP 4: Add our service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &service_uuid, &p_tonepen_service->service_handle);
    SEGGER_RTT_WriteString(0, "Executing tonepen_service_init().\n"); // Print message to RTT to the application flow
    SEGGER_RTT_printf(0, "Service UUID: 0x%#04x\n", service_uuid.uuid); // Print service UUID should match definition BLE_UUID_OUR_SERVICE
    SEGGER_RTT_printf(0, "Service UUID type: 0x%#02x\n", service_uuid.type); // Print UUID type. Should match BLE_UUID_TYPE_VENDOR_BEGIN. Search for BLE_UUID_TYPES in ble_types.h for more info
    SEGGER_RTT_printf(0, "Service handle: 0x%#04x\n", p_tonepen_service->service_handle); // Print out the service handle. Should match service handle shown in MCP under Attribute values
    tonepen_add_tmd_characteristics(&base_uuid, p_tonepen_service);
   // APP_ERROR_CHECK(err_code);
//Print messages to Segger Real Time Terminal
    //UNCOMMENT THE FOUR LINES BELOW AFTER INITIALIZING THE SERVICE OR THE EXAMPLE WILL NOT COMPILE.
    /* Add Tonepen Light sensor Characteristic UUID *
    ble_uuid_t          char_uuid;
    char_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_LIGHT_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
    ble_gatts_char_md_t char_md;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read = 1;
    char_md.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md;
    memset(&cccd_md, 0, sizeof(cccd_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.vloc                = BLE_GATTS_VLOC_STACK;
    char_md.p_cccd_md           = &cccd_md;
    char_md.char_props.notify   = 1;
    Config attrib metadata
    ble_gatts_attr_md_t attr_md;
    memset(&attr_md, 0, sizeof(attr_md));
    attr_md.vloc        = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    ble_gatts_attr_t    attr_char_value;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid      = &char_uuid;
    attr_char_value.p_attr_md   = &attr_md;
    attr_char_value.max_len     = 12;
    attr_char_value.init_len    = 12;
    uint8_t value[12]            = {0,0,0,0,0,0,0,0,0,0,0,0};
    attr_char_value.p_value     = value;
    /add characteristic to service
                                   &char_md,
                                   &attr_char_value,
                                   &p_tonepen_service->char_handles);
    * Create Tonepen Characteristic for writing a TMD3702 register
    //ble_uuid_t          char_uuid;
    char_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_TMD3702_WRITE_UUID;
    //ble_gatts_char_md_t char_md;
    / Config attrib metadata
    //ble_gatts_attr_md_t attr_md;
    / config characteristic value attr
    //ble_gatts_attr_t    attr_char_value;
    attr_char_value.max_len     = 2;
    attr_char_value.init_len    = 2;
    uint8_t value2[2]            = {0,0};
    attr_char_value.p_value     = value2;
    / add characteristic to service
                                   &char_md,
                                   &attr_char_value,
                                   &p_tonepen_service->tmd3702_write_handles);
    / Create Tonepen Characteristic for reading a TMD3702 register
    char_uuid.uuid      = BLE_UUID_TONEPEN_CHAR_TMD3702_READ_UUID;
    / Config permissions
    uint8_t value3[2]            = {0,0};
    attr_char_value.p_value     = value3;
                                   &char_md,
                                   &attr_char_value,
                                   &p_tonepen_service->tmd3702_read_handles);
    APP_ERROR_CHECK(err_code);*/
void ble_tonepen_service_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context) {
void tonepen_update(ble_tonepen_t *p_tonepen_service, int32_t *value) {
    if (p_tonepen_service->conn_handle != BLE_CONN_HANDLE_INVALID)
        uint16_t               len = 12;
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_tonepen_service->char_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &len;
        hvx_params.p_data = (uint8_t*)value;
        sd_ble_gatts_hvx(p_tonepen_service->conn_handle, &hvx_params);*/
