gzll host frequency channels
To the kind attention of Nordic support team,
I was wondering if it is mandatory that Host and Devices share the very same frequency table, with same size.
Is it possible to have an Host using F1 F2 F3 F4 F5 F6 and Device_A using F1 F2 F3 and Device_B using F4 F5 F6?
I'm asking, because I have been testing this scenario:
Device A host using frequency table F_T
Device B device using frequency table F_T
Device C device using frequency table F_T
C is transmitting in a loop without any particular timing constraint, C transmissions are successfully received in A
B is transmitting at the same time, B transmissions are successfully received in A for a while. B stops transmitting for ever. This doesn't affect C.
Maybe B transmission is stuck because of transmission queue is filled up.
B is a very well tested device, that has not got its own transmission problem. Bug shows up only when C is transmitting.
So my Idea, was without entering too much in details, try to physically tell frequencies apart.
Thank you for your kindness
