Sending and receiving beacons on demand.
Our device using nRF52840 is running an external (non-BT) radio most of the time. We need to send and receive data In between operations of this other radio.  At any given time, there will be one sender and multiple receivers.  Since there will be no BLE connection or interaction, this is essentially a beacon operation except for the scheduling.  We are trying to understand if it is possible to manually send and receive without running a BLE schedule and without any interaction between sender and receiver.
We are assuming/hoping this will be possible using L2CAP functions instead of GAP/GATT functions and never starting any GATT scheduling.  However the L2CAP message sequence charts in SD140 v7.0.1 all show two-way communication.
Please clarify how the scheme described here can be accomplished.
The overall schedule will be something like
Receive-only devices:
  1. Receive other radio
  2. Receive BLE (20-40ms interval)
  3. (repeat steps 1 & 2 indefinitely)
Receive/Transmit devices:
  3. (repeat steps 1 & 2 N times)
  4. Transmit other radio
  5. Transmit BLE
  6. (repeat steps 1 - 5 indefinitely)
  • If you are concerned about IP, I can convert this ticket to a private ticket - viewable only to you and the support staff here at Nordic Semiconductor. Would you like me to do that?
    I think you understood my problem so no need.
     Aha, I see what you mean. Well, I suppose you could attempt to start an advertising at the beginning of the slot and stop it at the end - could you attempt this, and let me know if it suits your application?
    We will experiment and see if it works.  One question: will the first beacon go out immediately when we call sd_ble_gap_adv_start()?
    Is this example relevant?
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Fble_sdk_app_es.html
    It seems to be for telemetry, which is closer t what we'redoing than an information beacon. Plus the encryption part of is is compelling.
    Now we have to discuss the second part: receiving.
    • We need the same devices to listen for beacons when they are not transmitting (blue boxes in the picture above).
    • Can we listen at specific times for beacons while transmitting a beacon?
    • Does this mean we have to operate as "multirole"?  It looks like S140 can support this, please confirm.
    • I looked at the examples under "ble_central_and_peripheral" and "ble_app_hrs_rscs_relay" seems the most relevant.  is there a better multirole example?
    thank you
    Great, I'll look forward to any updates on the development!
    Yes, or at least immediate in the sense that it will not have to wait for a given timeslot to begin advertising.
    I am unsure of the real-time delay between the function call and the first advertisement.
    Yes, you may use the Eddystone beacon as your foundation instead of the beacon example. I do not suppose it will make you able to broadcast any faster or "on demand" - since it still follows the BLE Specifications - but you could definitely make use of its added security features.
    You may scan for advertisement packets at specific times, yes.
    Just remember that a beacon is non-connectable, so what you are listening for is advertising packets.
    I can confirm that S140 supports the multirole, as demonstrated in the experimental multirole exmaples from the SDK.
    However, I am not sure it is multirole you are looking for, since the functionality demonstrated in multirole is to act both as a central and peripheral device.
    The central role is the initiator of BLE connections and communication.
    However, I do not see why the beacons would need to act as a central at any time? Perhaps I am missing something in my understanding of your application?
    Both these examples are good examples for demonstrating a device acting both as a central and a peripheral, but as I said I am not sure this is what you are looking for.
    Just remember that these are experimental examples.
    Karl
  • Yes, or at least immediate in the sense that it will not have to wait for a given timeslot to begin advertising.
    we have now run some experiments and not quite sure whether we are seeing an issue or not.
    Have you been able to confirm how soon after sd_ble_gap_adv_start() the first beacon will be transmitted?
    Additionally we need to know a few things about sd_ble_gap_adv_stop():
    • what would happen if we call this while the beacon is being transmitted?
    • how soon after calling this are we guaranteed that the transmitter will not turn on
    We are detecting the beacons using nRF Connect for Android v.4.24.1 and see a 30-50ms difference in beacon-to-beacon timing even though we are calling sd_ble_gap_adv_start() with fixed (3.2sec) intervals.  We are pretty sure about our timing because this timing also controls the other radio which has been tested in detail.  How dependable is the timing from nRF Connect for Android?
  • Hi again,
    Thank you for your patience.
    What do you mean by this, are you no longer seeing the original issue?
    I have not looked further into how long it takes the hardware to respond to the call, but  However, please keep in mind the random 3 - 13 ms delay added before advertising packets, as written about in the S140 documentation - advertising scheduling and suggested intervals and windows in particular.
    The delay is part of the BLE specifications, and can not be omitted if you are to use BLE.
    You may check it by using a Sniffer tool for monitoring the BLE traffic, complete with timestamps and contents of each advertised packet.
    If this does not fit your application requirements, then I suggest making use of the Timeslot API to schedule proprietary radio communication windows.
    Using a proprietary protocol could significantly reduce your latency, which sounds to be your main concern. Timeslots will give you complete control(no SD interruption) over the radio for their duration. If you would like to take a look at this, I can recommend this tutorial on setting up the Timeslot API for starters.
    This example code could also be useful to have a look at, when looking for demonstrations of Timeslot API usage for the purpose you describe. Unfortunetely, said example is now a bit old - written for the nRF51 DK - but it is still relevant and the principles still hold.
    The timing from the nRF Connect app is dependable, but as I mentioned earlier, I suggest that you use a Sniffer tool to analyze BLE traffic, since it gives you a much higher level of detail.
    With the Sniffer tool running, you are also able to capture a sniffer trace - a log of the BLE traffic - so that I may better see what you are experiencing on your end.
    Looking forward to resolving this issue together,
    Karl
  • If this does not fit your application requirements, then I suggest making use of the Timeslot API to schedule proprietary radio communication window
    Based on a quick look, this again seems to drive the radio registers directly.  we are trying to avoid operating at that level foe now.
    Please see attached wireshark log we took using a PCA10000 with nrf_sniffer_for_bluetooth_le_3.0.0_129d2b3.  If the timing is what you would expect from S140, then we wil evaluate the timeslot example further.
