Sometimes receiving the packages I am sending over ESB
I am using ESB to send package from a nrf52832 (primary transmitter) to a nrf42840 (primary receiver). I use nrf5 SDK v15.3 on both of them. I send a ping message (12 bytes) every 10ms from the primary transmitter using tmsi_esb_ptx_send command. however somehow once in every 180 or so ping messages I send, I receive the ping message I send. This happens even if I remove the power the primary receiver.
I am using the following code for the callback function that get's called when the ping message is send.
static void nrf_esb_event_handler(nrf_esb_evt_t const * p_event)
    int foobar;
    switch (p_event->evt_id)
        case NRF_ESB_EVENT_TX_SUCCESS:
            (*tmsi_esb_ptx_tx_succes)();
        case NRF_ESB_EVENT_TX_FAILED:
            (void) nrf_esb_flush_tx();
            (void) nrf_esb_start_tx();
            (*tmsi_esb_ptx_tx_failed)();
        case NRF_ESB_EVENT_RX_RECEIVED:
            foobar = 1;
            nrf_esb_payload_t rx_payload;
            //NRF_LOG_DEBUG("RX RECEIVED EVENT");
            while (nrf_esb_read_rx_payload(&rx_payload) == NRF_SUCCESS)
                if (rx_payload.length > 0)
                    (*tmsi_esb_ptx_rx_received)(&rx_payload);
I have absolutely no idea how this could happen. Does maybe one of you have a clue?
Martijn
  • Hi Martijn,
    So if I understand correctly, you get a NRF_ESB_EVENT_RX_RECEIVED after sending 180 ping messages eventhough the receiving device is not powered?
    Best regards
    Bjørn
  • Ok, could you post your esb configuration, i.e. the esb_init function?
    uint32_t esb_init( void )
        uint32_t err_code;
        uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
        uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
        uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8 };
    #ifndef NRF_ESB_LEGACY
        nrf_esb_config_t nrf_esb_config         = NRF_ESB_DEFAULT_CONFIG;
    #else // NRF_ESB_LEGACY
        nrf_esb_config_t nrf_esb_config         = NRF_ESB_LEGACY_CONFIG;
    #endif // NRF_ESB_LEGACY
        nrf_esb_config.retransmit_count         = 6;
        nrf_esb_config.selective_auto_ack       = false;
        nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB_DPL;
        nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_2MBPS;
        nrf_esb_config.event_handler            = nrf_esb_event_handler;
        nrf_esb_config.mode                     = NRF_ESB_MODE_PTX;
        err_code = nrf_esb_init(&nrf_esb_config);
        VERIFY_SUCCESS(err_code);
        err_code = nrf_esb_set_base_address_0(base_addr_0);
        err_code = nrf_esb_set_base_address_1(base_addr_1);
        err_code = nrf_esb_set_prefixes(addr_prefix, 8);
        tx_payload.length  = 3;
        tx_payload.pipe    = 0;
        tx_payload.data[0] = 0x00;
        return NRF_SUCCESS;
  • yes, my I initialise the esb primary transmitter using the following function:
    ret_code_t tmsi_esb_ptx_init(void (*esb_ptx_rx_received)(nrf_esb_payload_t *rx_payload), void (* esb_ptx_tx_succes)(), void (* esb_ptx_tx_failed)()){
        tmsi_esb_ptx_rx_received = esb_ptx_rx_received;
        tmsi_esb_ptx_tx_succes = esb_ptx_tx_succes;
        tmsi_esb_ptx_tx_failed = esb_ptx_tx_failed;
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        uint32_t err_code;
        nrf_esb_config.retransmit_delay         = 600;
        nrf_esb_config.payload_length           = 252;
        nrf_esb_config.retransmit_count         = ESB_RETRANSMITS;
        tmsi_esb_set_tx_power(ESB_TX_POWER,0);
        err_code = tmsi_esb_set_rf_channel(ESB_RF_CHANNEL);
        err_code = nrf_esb_set_prefixes(addr_prefix, NRF_ESB_PIPE_COUNT);
        return err_code;
  • Have you checked that the RX payload is identical to the TX payload that was last transmitted?
    Which base addresses and addr prefix  are you using? Would it be possible for you to share the project? Then I could run it here on a nRF52 DK and see if I can reproduce the behavior?
