Sending consecutive 7 notification on ble characteristic issue
I want to send multiple packets on a notify characteristic using ble_blanky app as baseline but only first 4 consecutive notifications are received on android side.
I send 7 notification one after the other and only first 4 are received on other side even peripheral is connected. by the way i am using sdk 16 on nrf52832 development board.
  • I have change in sdk_config  NRF_SDH_BLE_GAP_EVENT_LENGTH  6 to 12 but still same results please guide can i send more than 6 consecutive ble notification on same characteristic in nordic ble.
    • What application are you using on the android side, is it nRF Connect?
    • Is the BLE_GATTS_EVT_HVN_TX_COMPLETE event generated when the notifications are sent?
    • Could you share your project?
    regards
    Jared
  • Yes i am using nRF Connect on mobile side.
    I have modified the ble_app_blinky example in sdk 16. on button write characteristic i send consecutive notification on a notify characteristic using the following function
    uint32_t ble_on_tx_frame(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t* p_tx_data)
    ble_gatts_hvx_params_t params;
    uint16_t len = 16;
    memset(&params, 0, sizeof(params));
    params.type = BLE_GATT_HVX_NOTIFICATION;
    params.handle = p_lbs->notify_char_handles.value_handle;
    params.p_data = p_tx_data;
    params.p_len = &len;
    return sd_ble_gatts_hvx(conn_handle, &params);
    // The following function is called in button write handle event of the button characteristic
    void GetEncrypted_text(uint8_t opcode)
    uint32_t err_code;
    uint8_t tx_packet_array[16];
    if(opcode == 0x03)
    (void) memset(g_tx_command,0,200);
    static char m_plain_text[] =
    "Example string to demonstrate AES CBC mode with padding. This text has 85 characters."
    uint16_t len_out = sizeof(g_tx_command);
    uint16_t len_in = sizeof(m_plain_text);
    encrypt_cbc(&m_plain_text[0], len_in, &g_tx_command[0],len_out);
    tx_packet_array[0] = 1<<7;
    tx_packet_array[0] |= opcode;
    tx_packet_array[1] |= 0x07; // no of frames
    tx_packet_array[2] |= 0x55; // crc low
    tx_packet_array[3] |= 0xA5; // crc high
    //(void) memset(&tx_packet_array[4],1,12); // First Chunk
    (void) memcpy(&tx_packet_array[4],&g_tx_command,12); // First Chunk
    ble_on_tx_frame(m_conn_handle, &m_lbs, &tx_packet_array[0]);
    tx_packet_array[0] = 0xFF; // Second Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[12],15);
    err_code = ble_on_tx_frame(m_conn_handle, &m_lbs, &tx_packet_array[0]);
    nrf_delay_ms(5);
    tx_packet_array[0] = 0xFF; // Third Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[27],15);
    nrf_delay_ms(5);
    tx_packet_array[0] = 0xFF; // Fourth Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[42],15);
    nrf_delay_ms(25);
    tx_packet_array[0] = 0xFF; // Fifth Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[57],15);
    nrf_delay_ms(5);
    tx_packet_array[0] = 0xFF; // Sixth Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[72],15);
    nrf_delay_ms(5);
    tx_packet_array[0] = 0xFE; // Seventh Chunk
    (void) memcpy(&tx_packet_array[1],&g_tx_command[87],9);
    (void) memset(&tx_packet_array[10],0,6);
     Only first three or some time four notifications are received in nrf Connect side.
    I'm very sorry for the late reply. Are you still having problems with this?
    regards
    Jared
  • I have the same problem. It looks like a limitation on the mobile phone, Whether I use nRF Connect on iOS or Android. The same situation is that the limit of continuous notification is 4. If you want to receive the fifth notification, you must add a delay more than 200ms between the fourth and fifth notifications sent on the peripheral.
