I need help with converting any example from Keil to SES
I've been trying for days to convert any example from Keil to SES, I have road probably every question here on the dev zone but I am unable to fix this, I ever specially install windows on my mac to try if there it would work.
So, I have done everything from official nordic documents, I've been through several problems which I happily solve, but that I'm not able to.
I get those errors:
unplaced section: .log_dynamic_data_app [nrf_log_frontend.o], size=12, align=4
undefined symbol: __SRAM_segment_end__
undefined symbol: __start_log_const_data
undefined symbol: __start_log_dynamic_data
undefined symbol: __stop_log_const_data
I'm working on latest SEGGER, I have tried latest SDK, also 14.2 . The same errors.
Thanks for reply
  • Hi, I did what you have recommended, I have set up Eclipse and all of that. No w I have this error:
    19:35:04 **** Incremental Build of configuration Debug for project BlueIOThingy ****
    make all
    Building target: BlueIOThingy.elf
    Invoking: Cross ARM GNU C++ Linker
    arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T "../../../../../../exemples/BlueIOThingy/gcc_nrf52_thingy_xxaa.ld" -Xlinker --gc-sections -L"../../../../../../../../../external/BSEC/algo/lite_version/bin/gcc/Cortex_M4" -L"../../../../lib/Eclipse/Debug" -Wl,-Map,"BlueIOThingy.map" --specs=nano.specs --specs=rdimon.specs -Wl,--start-group -lgcc -lc -lm -lrdimon -Wl,--end-group -o "BlueIOThingy.elf"  ./src/BlueIOICM20948.o ./src/BlueIOMPU9250.o ./src/BlueIOTcs.o ./src/BlueIOTes.o ./src/BlueIOThingy.o ./src/BlueIOTms.o ./src/BlueIOTuis.o   -lIOsonata_nRF52832 -lalgobsec
    /usr/local/Caskroom/gcc-arm-embedded/9-2019-q4-major/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: cannot find -lIOsonata_nRF52832
    collect2: error: ld returned 1 exit status
    make: *** [BlueIOThingy.elf] Error 1
    "make all" terminated with exit code 2. Build might be incomplete.
    19:35:04 Build Failed. 2 errors, 0 warnings. (took 131ms)
    It seems that it cannot find -lIOsonata_nRF52832 in arm none eabi? it seems strange.
    What should I Do next?
  • You need to build the lib project first.  open the lib project from .../ARM/Nordic/nRF52/nRF52832/lib
    compile both Debug & Release build. It will generate the libIOsonata_nRF52832.a
  • Thanks, I did it and the project builded correct, with 2 warnings.
    I have tried flashing with JLINK simple Blinky example with .hex file and it works, but while I flashed with BlueOThingy it seems that something is wrong, bluetooth is not advertising.  I have tried to do the debug and check what is wrong and where, but I am not able to see "J LINK" in preferences -> Run/Debug ->, However I can see in Run/Debug -> Launching -> Launch Configurations  something " GDB SEGGER J-Link Debugging" But I have not idea how to set it up to see Jlink options in Run/Debug. Not many answers are on the internet also, maybe you know how to set it up? (I found about updating ARM pluggin so I did that, but it did not worked)
    And, I can't find anywhere in the code how to connect MPU9250 (SCL,SDA) pins to nrf5 dev board, I searched in web that it should be 27 and 26 pin, but also I found that gpio pins can be set as a SCL/SDA, so somewhere in the code it is probably setted up? Please help.
    Thanks for all your help.
  • flashing Blinky will erase the softdevice.  Therefore you need to refrash softdevice outside using nrfjprog first. Then you can use Eclipse to launch the firmware.
  • To be sure..
    So I just need to type "Nrfjprog" in terminal to refresh?
    Do you think Its good way to flash firmware into dev 5 board through Jlink program?
    What about SCL/SDA pinout to dev 5 board?
