I need help with converting any example from Keil to SES
I've been trying for days to convert any example from Keil to SES, I have road probably every question here on the dev zone but I am unable to fix this, I ever specially install windows on my mac to try if there it would work.
So, I have done everything from official nordic documents, I've been through several problems which I happily solve, but that I'm not able to.
I get those errors:
unplaced section: .log_dynamic_data_app [nrf_log_frontend.o], size=12, align=4
undefined symbol: __SRAM_segment_end__
undefined symbol: __start_log_const_data
undefined symbol: __start_log_dynamic_data
undefined symbol: __stop_log_const_data
I'm working on latest SEGGER, I have tried latest SDK, also 14.2 . The same errors.
Thanks for reply
  • So Am I able to get raw values from mpu2950 in Motion Sensor Demo example over I2C/SPI ? Which would you recommend on this example and always I2C or SPI? I heard that magnetometer from mpu9250 is not working with SPI.
  • The MPU-9250 can be interfaced either SPI or I2C. You choose how you want to use it.  Check the data sheet of the MPU for pins configuration. The IOsonata driver supports both mode.
  • Okay, so lets start again.
    I want to get Motion Sensor Demo example to get working with MPU9250 with NRF 5 Dev Board.
    I imported the project from IOSsonata library.
    Now.
    What Need to be change in mot_sensor_demo.cpp and board.h to get this example to work with mpu9250 and get it to stream data to eclipse terminal by printf ?
    I checked the pinout of my board, and found SCL, SDA is 26,27 and I have connected it. Devboard + mpu9250 are connected and ready.
    Doing Run. I get "Failed initializing hardware"
    Doing Debug, I get:
  • You need to create an I2C object then pass it to the init of the MPU object.
    Instead of
    res = g_MotSensor.Init(s_AccelCfg, &g_Spi, &g_Timer);
    replace the g_Spi with your g_I2c object you created.
    res = g_MotSensor.Init(s_AccelCfg, &g_I2c, &g_Timer);
    See also the TPHDemo how to select between SPI & I2C to interface with the environmental sensor.
  • I did that and I can't build:
    /Users/jacobbudny/Desktop/DEVELOPMENT/IOsonata/exemples/sensor/mot_sensor_demo.cpp:254:39: error: 'g_I2c' was not declared in this scope
      254 |   res = g_MotSensor.Init(s_AccelCfg, &g_I2c, &g_Timer);
    make: *** [src/mot_sensor_demo.o] Error 1
    "make all" terminated with exit code 2. Build might be incomplete
    So in mot_sensor_demo.cpp there is no i2c communication option at all yes? I need to add it, to get it to work?
    If I use SPI to communicate with MPU9250 all of it will be simpler or not? Because really, I do not even know where to start if I would need to write i2c communication for mpu9250 for this example.
    Maybe you can suggest any simpler way? Like I spent a week now and nothing works.
