Instrumenting FreeRTOS 10 from SDK15.3 to support Segger SystemView v3.10
I am trying to evaluate the nrf52840. I am following the instruction to instrument the FreeRTOS from the Nordic SDK15.3.  I managed to follow most of the instructions.  The only step I am having a hard time is instrumenting the ARM-CM4F/port.c.  The problem is xPortSysTickHandler() does not match the patch file.
My setup includes:
  • nrf52840-DK
  • SDK15.3
  • Segger SystemView v3.10
Below is the patch instruction:
    diff -rupN org/Source/portable/GCC/ARM_CM4F/port.c new/Source/portable/GCC/ARM_CM4F/port.c
    --- org/Source/portable/GCC/ARM_CM4F/port.c 2017-11-28 13:48:34.000000000 -0800
    +++ new/Source/portable/GCC/ARM_CM4F/port.c 2017-12-11 01:16:01.771230000 -0800
    @@ -493,14 +493,20 @@ void xPortSysTickHandler( void )
        save and then restore the interrupt mask value as its value is already
        known. */
        portDISABLE_INTERRUPTS();
    + traceISR_ENTER();
            /* Increment the RTOS tick. */
            if( xTaskIncrementTick() != pdFALSE )
    +            traceISR_EXIT_TO_SCHEDULER();
                /* A context switch is required. Context switching is performed in
                the PendSV interrupt. Pend the PendSV interrupt. */
                portNVIC_INT_CTRL_REG = portNVIC_PENDSVSET_BIT;
    +        else
    +             traceISR_EXIT();
        portENABLE_INTERRUPTS();
Below is the freertos.portable.CMSIS.nrf52/port_cmsis_systick.c, xPortSysTickHandler() from the SDK15.3
    #if configUSE_TICKLESS_IDLE == 1
        nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_COMPARE_0);
    BaseType_t switch_req = pdFALSE;
    uint32_t isrstate = portSET_INTERRUPT_MASK_FROM_ISR();
    uint32_t systick_counter = nrf_rtc_counter_get(portNRF_RTC_REG);
    nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_TICK);
    if (configUSE_DISABLE_TICK_AUTO_CORRECTION_DEBUG == 0)
        /* check FreeRTOSConfig.h file for more details on configUSE_DISABLE_TICK_AUTO_CORRECTION_DEBUG */
        TickType_t diff;
        diff = (systick_counter - xTaskGetTickCount()) & portNRF_RTC_MAXTICKS;
        /* At most 1 step if scheduler is suspended - the xTaskIncrementTick
        * would return the tick state from the moment when suspend function was called. */
        if ((diff > 1) && (xTaskGetSchedulerState() != taskSCHEDULER_RUNNING))
            diff = 1;
        while ((diff--) > 0)
            switch_req |= xTaskIncrementTick();
        switch_req = xTaskIncrementTick();
    /* Increment the RTOS tick as usual which checks if there is a need for rescheduling */
    if ( switch_req != pdFALSE )
        SCB->ICSR = SCB_ICSR_PENDSVSET_Msk;
        __SEV();
        portCLEAR_INTERRUPT_MASK_FROM_ISR( isrstate );
Thank you,
L
  • Try this
    +   traceISR_ENTER();
            TickType_t diff;
                diff = 1;
            __SEV();
    +   else
    +      traceISR_EXIT();
  • Hi Susheel,
    Thanks the response.  Your suggestion matches my interpretation of the patch.  But I was still unable to connected to the NRF52 with the SystemView tool.  My issue was that I had to change the target setting in the SystemView tool.  Maybe it was obvious, but all the documents that I have read and troubleshooting pages never mentioned it.  I found it by accident.  I hope this help someone else.  Thanks again.
    L
