Cannot compile pc-ble-drivers on Win10 with VS 2019
I have some problems when I tried to compile pc-ble-drivers (C) .
1. When I tried to execute ./bootstrap-vcpkg.bat after I follow the steps:
$ git clone github.com/.../vcpkg.git
$ cd vcpkg
$ git checkout fix/temporary-fix-spdlog-until-vcpkg-release #
Then it always return the error below:
E:\vcpkg\scripts\bootstrap.ps1 : Building vcpkg.exe failed. Please ensure you have installed Visual Studio with the Desktop C++ workload and the Windows SDK for Desktop C++.
At line:1 char:4
+ & {& 'E:\vcpkg\scripts\bootstrap.ps1' }
 + CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
 + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,bootstrap.ps1
I am sure I have already installed VS 2019 and C++ workload, and also Windows 10 SDK(10.0.18362). Why I still get this error? Is it because your driver do not compatible with Win10 or VS 2019?
2. Then I install vcpkg by clone it from microsoft, then when I execute "vcpkg install --head spdlog" It failed:
CMake Error at scripts/cmake/vcpkg_execute_build_process.cmake:136 (message):
    Command failed: "C:/Program Files/CMake/bin/cmake.exe" --build . --config Debug --target install -- -v
    Working Directory: F:/vcpkg/buildtrees/spdlog/x86-windows-dbg
    See logs for more information:
      F:\vcpkg\buildtrees\spdlog\install-x86-windows-dbg-out.log
  scripts/cmake/vcpkg_build_cmake.cmake:91 (vcpkg_execute_build_process)
  scripts/cmake/vcpkg_install_cmake.cmake:24 (vcpkg_build_cmake)
  ports/spdlog/portfile.cmake:29 (vcpkg_install_cmake)
  scripts/ports.cmake:90 (include)
Error: Building package spdlog:x86-windows failed with: BUILD_FAILED
Please ensure you're using the latest portfiles with `.\vcpkg update`, then
submit an issue at https://github.com/Microsoft/vcpkg/issues including:
  Package: spdlog:x86-windows
  Vcpkg version: 2020.02.04-nohash
Additionally, attach any relevant sections from the log files above.
Do you have solutions for this?
3. Then I gave up this version, and try to compile version 4.1.1 becasue this one does not need spdlog. However, when I try to execute"cmake -G Ninja", the it returned:
CMake Error at test/CMakeLists.txt:8 (find_package):
  Could not find a package configuration file provided by "Catch2" with any
  of the following names:
    Catch2Config.cmake
    catch2-config.cmake
  Add the installation prefix of "Catch2" to CMAKE_PREFIX_PATH or set
  "Catch2_DIR" to a directory containing one of the above files.  If "Catch2"
  provides a separate development package or SDK, be sure it has been
  installed.
But I'm sure I installed catch2. How to solve it?
Thank you very much!
Taoyi
