I am buys setting up a project on the NRF52 that needs to use the TWI.
Usually I would read byte for byte, and if one of the registers has enough data to justify it, I would do a DMA transaction to read out its contents.
I am new to tis easyDMA stuff. What I want to know is can you switch between the easyDMA and normal read, or is it one or the other?
I also cant seem to find an example that uses easyDMA. Not sure about the use.
I can see I need to enable easyDMA for the TWI in sdk_config. But I cant seem to find the actual use. Take it there would be a callback when operation is done.
