NRF53 High power consumption on in power_off state - Zephyr
Hi
I've run up the system_off sample (samples/boards/nrf/system_off) and I can see chip fall into deep sleep, but deep sleep still seems to be sitting at 152 microamps, which seems to be quite high?
Below are the usage screenshots, first one showing dropping from active to power_off state, and the second showing the consumption over 30 seconds in power_off state
Drop to power_off state
power off state
I have tried turning off UART, as this could be a possible cause of consumption in power_off state. I know that it is not waking up out of power_off state because I can see that in the consumption, but it is still using power.
Why is it still using this much power?
  • Appreciate your help - I'm actually running it on NRF52 DK and only have access to NRF52 chips now but I had the same result on a borrowed NRF53 chip hence this ticket.
    It is the NRF52 DK v1.2.4 (2019.8)
    - I have also tried this on the NRF52832 Raytac Development Board and had the same result. Schematic is here: https://www.raytac.com/product/ins.php?index_id=82
    - I have also been testing this on a barebones board with an nrf52832 chip only (no external crystal)
    - I am also going to soon try this with a custom board with an external crystal so I will be able to provide a schematic for that when I get it. This will be NRF52 as well.
    I'm measuring the current going through the external supply header as you mentioned, but I unplug the USB, but I see what you mean regarding consumption with other things on the DK.
    The original code did not configure GPIO's - just simply tried to put the chip in system off state
  • Hi Christian
    I have agreed to help Stian out with this case as he will be out all next week.
    Can you confirm what results you get when running the system_off example on the nRF52DK?
    I just tested this myself, and see about 45uA in system off mode. This is still too high, but seems quite different from the numbers you are reporting.
    Can you confirm what you get on the nRF52DK, and I will do some checking with the NCS/Zephyr team to see if there is some way to optimize the example.
    Best regards
    Torbjørn
  • Hi again
    One tip is to disable the serial interface by setting CONFIG_SERIAL=n in prj.conf and rebuilding the project.
    Then you should expect to see lower sleep currents.
    Please give this a go and see what results you get.
    Best regards
    Torbjørn
  • Hi, thanks for your response much appreciated, I have flashed my DK but before I go into in depth consumption testing could you tell me the best way to measure consumption on the DK? Because currently I have a 3v supply going through a DC energy analyzer, which is then hooked up to the external supply pins on the board. This alone does not seem to power the DK though, and it only turns on when I plug in the micro USB?
  • Not sure my sample is working correctly because it's sitting on 49ua with a supply current of ~3v and pressing the buttons doesn't seem to do anything. Also no sign of a drop off when it goes into system_off mode. I'll try reflashing it...
