Bulk OUT works , but IN not
I inserted code.
OUT 0x04 endpoint works, but 0x84 IN endpoint doesn't.
I use libusb from Linux PC to communicate with nrf52840 via USB. At PC I call function "libusb_bulk_transfer" - it results in timeout - and at SOC no enter to event handler.
I see USB registers - IN endpoint packet counter don't increment, and no response.UGate.23.03.2020.zipUNrf.23.03.2020.zip
    Thanks for providing both firmware and host software to test with. Makes it very easy to look into.
    Firmware built with SDK v16.0.0 (SES)
    I built the software on ubuntu 19.10, and ran it:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    ======= Wallit USB BLE Node server ==========================================================
    === LibUSB init ..... done. ===
    === Get Device List ..... done. ===
    === USB devices:
    VID:0a5c,PID:5801 (bus 1, device address: 4) path: 1.5
    - Intel -
    VID:8087,PID:07dc (bus 1, device address: 3) path: 1.3
    - Intel -
    VID:8087,PID:8000 (bus 1, device address: 2) path: 1
    - Linux Foundation -
    VID:1d6b,PID:0002 (bus 1, device address: 1)
    VID:1d6b,PID:0003 (bus 3, device address: 1)
    - Segger -
    VID:1366,PID:1015 (bus 2, device address: 101) path: 6
    VID:1bcf,PID:28a0 (bus 2, device address: 3) path: 4
    - Logitech -
    VID:046d,PID:c52b (bus 2, device address: 2) path: 2
    - Nordic -
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Seems to be working? Could it be that I'm missing something?
    Håkon
  • Thank you!
    Yes - this works because at that moment  address is 0x04 - for this BULK OUT all works - please change it to 0x84 to reproduce issue - in this case function
    libusb_bulk_transfer( h_nordic, 0x84, nrf_frame, 32, received, 300 );
    results in timeout and I see no activity at EP4 registers inside nrf52840.
    here was said you have ellisys qualifiers and can see what happens in the D+,D- usb line.
    I have not such possibility it costs 50 000 EUR.
    Thanks for clearing that up - I had a feeling I didn't see the whole picture!
    1. You should handle this error from dmesg:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    [122449.313587] usb 2-1: USB disconnect, device number 122
    [122453.543735] usb 2-1: new full-speed USB device number 123 using xhci_hcd
    [122453.692697] usb 2-1: not running at top speed; connect to a high speed hub
    [122453.693668] usb 2-1: config 1 interface 0 altsetting 0 endpoint 0x4 has invalid maxpacket 512, setting to 64
    [122453.693670] usb 2-1: config 1 interface 0 altsetting 0 endpoint 0x84 has invalid maxpacket 512, setting to 64
    [122453.695147] usb 2-1: New USB device found, idVendor=1915, idProduct=7777, bcdDevice= 1.01
    [122453.695149] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [122453.695151] usb 2-1: Product: nRF52 USB HID mouse on nrf_drv Demo
    [122453.695152] usb 2-1: Manufacturer: Nordic Semiconductor
    That is done by setting the EP size to 0x40 (64) or lower:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    #define USBD_ENDPOINT1_DESCRIPTOR \
    0x07, /* bLength | length of descriptor (7 bytes) */ \
    0x05, /* bDescriptorType | descriptor type (ENDPOINT) */ \
    0x04, /* bEndpointAddress | endpoint address (IN1 endpoint) */ \
    0x02, /* bmAttributes | endpoint attributes (usual data) */ \
    0x40, /* bMaxPacketSizeLowByte */ \
    0x00, /* bMaxPacketSizeHighByte | maximum packet size (512 bytes) */ \
    0 /* bInterval | polling interval (10ms) */
    #define USBD_ENDPOINT2_DESCRIPTOR \
    0x84, /* bEndpointAddress | endpoint address (OUT1 endpoint) */ \
    0x02, /* bmAttributes | endpoint attributes (bulk, usual data \
    000010) */ \
    I also changed the transfer blocks to different sizes, where transfer_in has .size = 62 at my end.
    2. It does not seem that you send data? I added a call to send_ep() in main (every time it had run 3000 times, execute send_ep()). Quick way to trigger a periodic transfer if you add this to the main loop:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    static uint32_t count_out;
    count_out ++;
    if (count_out % 3000 == 0)
    //if (0)
    NRF_LOG_INFO("Trying to send data");
    send_ep();
    Log when polling for data:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    00> ================================== USBD example started =========================================================
    00> Reset reasons:
    00> - SREQ
    00> No USB power detection enabled
    00> Starting USB now
    00> No USB Enable - stall
    00> USB Start
    00> SUSPEND state detected
    00> RESUMING from suspend
    00> === GetDescriptor >>>
    00> = Respond Device descriptor =
    00> === EP Transfer ===========================
    00> === SetAddress >>>
    00> Trying to send data
    00> === EPIN ===
    00> === EPIN ===
    Since you are triggering a new transfer from the usbd callback again, it'll send quite often. With the current logic, you technically just need to call send_ep() once, and it should start pumping data (given that no err is returned in the call to usbd_event_handler, case NRF_DRV_USBD_EVT_EPTRANSFER, nrfx_usbd_ep_transfer)
    3. I changed the read size to 64 in libusb main.c example:
      epres = libusb_bulk_transfer( h_nordic, 0x84, nrf_frame, 64, received, 300 );
    and this is the output from the program, which matches the length on the IN transfer:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    === USB devices:
    - Intel -
    - Intel -
    - Segger -
    VID:1366,PID:1015 (bus 2, device address: 112) path: 6
    - Logitech -
    - Nordic -
    Could you try to make similar changes and see if it works on your end?
    Håkon
  • I got something different
    === found descriptor for open device ===
    opening bus.dev: 3.62
    === Nordic normally opened ===
    no active kernel driver.
    === Prepare data EP ===
    === EP transfer 0 ===
    bulk ep callback - actual_length = 0
    complete.
    LIBUSB_TRANSFER_STALL
    Segmentation fault
    I insert you cycle with send_ep() as you advised - got above mentioned message
    Here's the edited project I'm using:
    UGate.zip
    I also included the .hex file I've used in the build folder.
    Could you see if this works?
    Håkon
