Building Zigbee cli example 4.0
For a customer I am developing a Zigbee coordinator / Gateway with the nRF52840. As hardware I am using the nRF52840 Preview Development Kit. As software basis I use the “Zigbee cli example”. I started with the Thread and Zigbee SDK v3.2.0.  Since I had some problems here I wanted to switch to v4.0 and see if the problems are solved in the new version. Building the project, I ran into a problem:
Compiling the “cli” example stops with error message:
Compiling file: zb_nrf52_transceiver.c
In file included from ../../../../../../../../external/nRF-IEEE-802.15.4-radio-driver/src/fem/nrf_fem_protocol_api.h:49,
from ../../../../../../../../external/nRF-IEEE-802.15.4-radio-driver/src/nrf_802154.h:49,from ../../../../../../../../external/zboss/osif/zb_nrf52_transceiver.c:51:
../../../../../../../../external/nRF-IEEE-802.15.4-radio-driver/src/fem/nrf_fem_control_config.h:35:10: fatal error: nrf_fem_config.h: No such file or directory
#include "nrf_fem_config.h"
compilation terminated.
make: *** [../../../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52840_xxaa/zb_nrf52_transceiver.c.o] Error 1
Is there a reason why the file "nrf_fem_config.h" is missing? What should I do to fix the problem?
    First, check that the file is actually located in SDK\external\nRF-IEEE-802.15.4-radio-driver\src\fem\none\nrf_fem_config.h. If it isn't there, try placing it there. (unzip a new SDK to get the file)
    If it is already a file called nrf_fem_config.h, then I suspect that the path to this file is too long. Try to move the entire SDK closer to your C-drive, e.g.:
    C:\Nordic\SDKs\SDK4
    If SDK4 is your Thred and Zigbee SDK v4.0.0, then the paths in the SDK should be short enough for the compilers to find all the files within the SDK.
    Try this, and let me know if it still doesn't work.
    Edvin
  • Hello Edvin.
    Thanks for quick response. The file “SDK\external\nRF-IEEE-802.15.4-radio-driver\src\fem\none\nrf_fem_config.h” is present in the folder. Moving the SDK closer to the C-drive made no difference. After that I checked out a completely new SDK v4 and tried to build it. It worked. I also found the difference:
    In the makefile the link to the Include folder “ $(SDK_ROOT)/external/nRF-IEEE-802.15.4-radio-driver/src/fem/three_pin_gpio \” was missing. I really don’t know why.
    After fixing this building the project worked.
    But: When I start the cli program, the application stops reacting after I start the coordinator with “bdb start”
    > bdb role zc
    Coordinator set
    Done
    > bdb start
    Started coordinator
    Done
    Do you have an Idea, what can cause this?
    Lutz
  • Hello Lutz,
    The CLI responses looks normal. What do you mean by stops reacting? It isn't possible to write to the CLI window after bdb start? Did you do any changes to any of the files in the SDK after you unzipped the new version of the SDK?
    I tested the SDKv4.0.0 now, and I am still able to write commands after bdb start.
    Did you only use these commands, or did you use any other commands first?
    Can you check what the log says? You need to use an RTT Viewer to see the RTT log, e.g. Segger RTT Viewer.
  • Hello Edvin,
    Correct, it isn’t possible to write to the CLI window after bdb start.
    No, I did no changes to any SDK Files except to the files in “<SDK_PATH>/components/toolchain/gcc/” to match the toolchain path.
    I only used these commands so far.
    Currently I cannot check the log, because I am not using an RTT Viewer.
    I am working within the Eclipse IDE.
    Any suggestions?
  • Download RTT Viewer. It is not dependent on the IDE.
    As for Eclipse, that is not something that we officially support. If you get it up and running with the armgcc makefile, that is fine, but I can't help you with Eclipse related issues. Try to download RTT viewer (link in previous reply).
    Does it happen if you just compile using the armgcc compiler (which I assume you have installed)?
    You can flash the file using nRF Command Line Tools. The commands you will have to run from the armgcc folder would be:
    make
    nrfjprog -e
    nrfjprog --program _build\nrf52840_xxaa.hex --verify
    nrfjprog --reset
    And then monitor the RTT Viewer if you are not able to enter any commands after "bdb start".
    As an option to Eclipse, I can recommend Segger Embedded Studio, as this is free for Nordic developers (such as yourself). It is a professional IDE, and there are project files for all the examples in the SDK.
    Edvin
