IAR Monitor Mode Debugging not linking correctly
I'm attempting to get MMD set up in an IAR project following this tutorial: https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/monitor-mode-debugging---revolutionize-the-way-you-debug-ble-applications.
The top of the page has a link to a newer tutorial, but the new tutorial only deals with SES. I've got the project working with MMD in SES, but need to port it to IAR.
Here's what I have:
1. Project compiles fine in IAR. This includes: JLINK_MONITOR.c, JLINK_MONITOR.h, and JLINK_MONITOR_ISR_IAR.s. All three of these files can be found linked in the tutorial.
2. Project includes the EnableMonMode.mac file linked in the tutorial, with SetMonModeVTableAddr=0x1C000, which I believe is the location of the VTable with SoftDevice 133/NRF52 devices.
The project compiles fine, but does not link. I get the following errors when it links:
- "Error[Li005]: no definition for "JLINK_MONITOR_OnEnter"
- "Error[Li005]: no definition for "JLINK_MONITOR_OnPoll"
- "Error[Li005]: no definition for "JLINK_MONITOR_OnExit"
These functions are of course defined in JLINK_MONITOR.c. However, they are defined only if CONFIG_JLINK_MONITOR_ENABLED is defined, which it apparently is not.
I've tried just defining CONFIG_JLINK_MONITOR_ENABLED, both in the code and in the preprocessor portion of the compiler options. This gets everything to link, but MMD does not work when I program the device (get hard faults when I put a breakpoint, for instance, and do not see the MMD pop-ups).
So, I think there must be a very simple answer to my question that I'm just missing. Everything I see about MMD seems to suggest it's fairly turnkey, so as long as I have the right files, which I think I do, and set up the files correctly it should just work.
There isn't a whole lot of information on MMD with IAR other than the out of date tutorial. Can someone please assist with this? It seems I could have one of two problems, either I just need to define CONFIG_JLINK_MONITOR_ENABLED and then fix a problem with my JLINK, or the MMD files are out of date and do not work.
I've tried the tutorial on both my main development project and a simple example from the SDK (ble_app_uart). The projects function fine without MMD, in so far as they advertise and are connectable with BLE devices.
