Power Profiler V2.3.1
I recently started doing power testing on one of our boards using the power profiler kit. I wanted to tested current consumption at different operating voltage levels. When setting the voltage regulator to 3.0V, the current curve seemed fine and as I started lower the voltage, the overall current (and idle current) started to go down as expected. But at 2.3V or below I started seeing negative current values. There is no battery or other power source attached to our custom board and it is powered solely through the pkk so it couldnt be another source back feeding.
Reading through some of the other posts, there were mentions of changing some setting in some file but I can't seem to find anything in the power profler that i can customize.
Please suggest possible fix to the issue. It is a brand new power profiler kit and it had never been used before.
Thanks your all the help in advance.
Noaman
