Hi
We are developing by connecting nRF52832 to SMT32f303cb's SPI interface.
SMT32f303cb operates as an SPI Master.
If the clock frequency of SPI Master is changed to 8Mhz, 4Mhz or 2Mhz, normal communication with nRF52832 operates only at 2Mhz.
We want to use the 8Mhz.
I attached the source code related to SPI communication.
How can I fix it?
***** ST (stm32f303cb)*****
static void MX_SPI1_Init(void)
/* SPI1 parameter configuration*/
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_HARD_OUTPUT;
//hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8; // 8MHz
//hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16; // 4MHz
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32; // 2MHz
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
int testSendCnt = 0;
void cis_test_send(void)
uint32_t len;
char dbgBuf[16];
char sendBuf[36];
for (len = 1; len < 25; len++) {
sendBuf[len+4] = len;
sendBuf[0] = 0xA5;
sendBuf[1] = 0xDE;
sendBuf[2] = 0xAD;
sendBuf[3] = 0xBE;
sendBuf[4] = 0xEF;
*(uint32_t *)&sendBuf[26] = testSendCnt;
sendBuf[30] = 0x0d;
sendBuf[31] = 0x0a;
//for (len = 0; len < BT_SEND_MAX; len++)
while(HAL_SPI_GetState(&hspi1)==HAL_SPI_STATE_BUSY_TX){ }
//if (HAL_OK == HAL_SPI_Transmit(&hspi1, &sendBuf[len], 1, 1000)) {
if (HAL_OK == HAL_SPI_Transmit(&hspi1, &sendBuf[len], 36, 1000)) {
while(HAL_SPI_GetState(&hspi1) != HAL_SPI_STATE_READY) { }
sprintf(dbgBuf, "%02x ", sendBuf[len]);
HAL_UART_Transmit(&huart3, dbgBuf, 3, 0xFFFF);
} else {
Error_Handler();
HAL_UART_Transmit(&huart3, "err: spi\r\n", 10, 0xFFFF);
return;
testSendCnt++;
sprintf(dbgBuf, "test %05d\r\n", testSendCnt);
HAL_UART_Transmit(&huart3, dbgBuf, 12, 0xFFFF);
***** BT : nRF52832*****
void spi_init(void) // +-kebi
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.sck_pin = 3; //APP_SPIS_SCK_PIN; ;
spis_config.csn_pin = 29; //APP_SPIS_CS_PIN;
spis_config.mosi_pin = 28; // APP_SPIS_MOSI_PIN;
spis_config.miso_pin = 4; //APP_SPIS_MISO_PIN;
spis_config.mode = NRF_SPIS_MODE_0; ///< SCK active high, sample on leading edge of clock.
spis_config.bit_order = NRF_SPIS_BIT_ORDER_MSB_FIRST;
spis_config.csn_pullup = NRFX_SPIS_DEFAULT_CSN_PULLUP;
spis_config.miso_drive = NRFX_SPIS_DEFAULT_MISO_DRIVE;
#if 1
spis_config.def = NRFX_SPIS_DEFAULT_DEF;
spis_config.orc = NRFX_SPIS_DEFAULT_ORC;
#else
spis_config.def = 36;
spis_config.orc = 36;
spis_config.irq_priority = NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY;
//spis_config.irq_priority = 2; //NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY; // 6
APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
uint8_t gSpiRecvCnt = 0;
void spis_event_handler(nrf_drv_spis_event_t event)
BT_Status_type *StsBt= &AppStsBt;
timer_conter_Typedef* tc= ScanStat.ptc;
uint8_t ii, jj;
char uBuf[120];
switch (event.evt_type){
case NRF_DRV_SPIS_XFER_DONE:
//ScanStat.spi_rp= false; ///< spi packet 수신 완료
if (event.rx_amount == 0) return;
#if 0
sprintf(uBuf, "%02d\r\n", event.rx_amount);
app_uart_send(4, uBuf);
for (ii = gSpiRecvCnt; ii < (event.rx_amount + gSpiRecvCnt); ii++) {
sprintf(uBuf, "%02d-%02x\r\n", ii, m_rx_buf[gSpiCur][ii]);
app_uart_send(7, uBuf);
gSpiRecvCnt += event.rx_amount;
//APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, 0, 0, &m_rx_buf[gSpiCur][gSpiRecvCnt], 1));
APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, 0, 0, &m_rx_buf[gSpiCur][gSpiRecvCnt], 32));
if (gSpiRecvCnt > 32) {
#if 0
for (ii = 0, jj = 0; ii < 32; ii++, jj+=3) {
sprintf(uBuf+jj, "%02x ", m_rx_buf[gSpiCur][ii]);
sprintf(uBuf+jj, "\r\n");
app_uart_send(jj+2, uBuf);
sprintf(uBuf, "%02d-5A-End\r\n", gSpiCur);
app_uart_send(11, uBuf);
gSpiRecvCnt = 0;
if (m_rx_buf[gSpiCur][0] == 0x5A) {
gSpiCur++;
if (gSpiCur >= SPI_MAX_QUEUE) gSpiCur = 0;
//AppFlg.flag = 1;
//AppFlg.msg = SPI_RCV_DONE;
//AppFlg.msg = COMPLETED_SCAN_ROW;
//spis_xfer_done++;
} else {
gSpiCur++;
case NRFX_SPIS_BUFFERS_SET_DONE:
NRF_LOG_INFO("event acquired\n");
bool erase_bonds;
NRF_POWER->TASKS_CONSTLAT = 1;
uint8_t ttt = 0;
// Initialize.
// uint32_t err_code = app_timer_init();
// APP_ERROR_CHECK(err_code);
log_init();
init_gpio();
#ifdef BT_DBG
uart_init(); // ++kebi
timers_init();
drv_timer_init();
spi_init(); // -- kebi
ble_stack_init();
flash_store_init();
mem_config_init();
cust_init();
power_management_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
gatt_mtu_set(m_test_params.att_mtu);
conn_evt_len_ext_set(m_test_params.conn_evt_len_ext_enabled);
usr_advertising_start();
// Enter main loop.
InitQueue();
spis_xfer_done = 0;
gSpiCur = 0;
gSendCur = 0;
//APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, 0, &m_rx_buf[0][0], 1));
APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, 0, 0, &m_rx_buf[0][0], 32));
app_uart_send(12, "BT Start!!\r\n");
while(1) {
CheckFlag();
//while (!spis_xfer_done && !AppFlg.flag && !AppBtFlg.flag)
while (!spis_xfer_done)
__WFE();
//idle_state_handle();
if (ttt) {
ttt = 0;
app_uart_send(3, "+\r\n");
} else {
ttt = 1;
app_uart_send(3, "-\r\n");
