Thread commissioning mqttsn_sleepy not working
I added the commissioning part from the nfc_meshcop example to the mqttsn_sleepy_subscriber example.
I tested the nfc_meshcop exaple and worked, so the border router part is ok.
I get error OT_ERROR_NOT_FOUND when the commissioning is disabled on the border router and OT_ERROR_SECURITY when it is enabled.
I changed the MEMORY_MANAGER setting as suggested in other post but I don't know if it is enough.
#define MEMORY_MANAGER_SMALL_BLOCK_COUNT 64
#define MEMORY_MANAGER_SMALL_BLOCK_SIZE 64
#define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT 16
    Where are you getting the error OT_ERROR_NOT_FOUND and OT_ERROR_SECURITY? Can you post all the log messages? Maybe you can also share your project or part of it here?
    Marjeris
  • On the border router i create a new network:
    # Generate PSKc.
    thread_psk="123456"
    thread_pskc="$(/home/pi/ot-br-posix/tools/pskc $thread_psk $thread_xpanid $thread_network_name)"
    # Atach to the Thread network.
    sudo wpanctl leave
    sleep 1
    sudo wpanctl reset
    sleep 2
    sudo wpanctl setprop Network:Key $thread_network_key
    sudo wpanctl setprop Network:PANID $thread_panid
    sudo wpanctl setprop Network:XPANID $thread_xpanid
    sudo wpanctl setprop NCP:Channel $thread_channel
    sudo wpanctl setprop Network:Name $thread_network_name
    sudo wpanctl setprop Network:PSKc $thread_pskc
    sudo wpanctl attach
    Start the commissioner:
    sudo wpanctl commissioner start
    sudo wpanctl commissioner joiner-add "*" 120 123456
    The code from nfc_meshcop example:
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "app_scheduler.h"
    #include "app_timer.h"
    #include "bsp_thread.h"
    #include "nfc_meshcop_msg.h"
    #include "nfc_t2t_lib.h"
    #include "nrf_assert.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log.h"
    #include "thread_utils.h"
    #include <openthread/cli.h>
    #include <openthread/joiner.h>
    #include <openthread/thread.h>
    #define JOINER_DELAY             500
    #define MAX_JOINER_RETRY_COUNT   3
    #define APP_TIMER_PRESCALER      0                               // Value of the RTC1 PRESCALER register.
    #define APP_TIMER_OP_QUEUE_SIZE  2                               // Size of timer operation queues.
    #define EMPTY_VALUE              ""
    #define SCHED_QUEUE_SIZE         32                              /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE    APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum app_scheduler event size. */
    APP_TIMER_DEF(m_joiner_timer);
    //static uint8_t m_ndef_msg_buf[256];
    typedef struct
        nfc_meshcop_data_t meshcop_data;                    /**< Commissioning data structure. */
        uint32_t           joiner_retry_count;              /**< Retry counter for commissioning process. */
        bool               commissioning_in_progress;       /**< Indicates that the commissioning is ongoing. */
    } application_t;
    static application_t m_app =
        .meshcop_data              =
            .psk_d = "123456"
        .joiner_retry_count        = 0,
        .commissioning_in_progress = false,
     * @ Callback functions
    static void joiner_callback(otError error, void * p_context)
    	uint32_t err_code;
    	NRF_LOG_INFO("OT_ERROR = %d.\n", error);
        if (error == OT_ERROR_NONE)
            NRF_LOG_INFO("COMMISSIONING_SUCCESS\r\n");
    		/*err_code = nfc_t2t_emulation_stop();
            APP_ERROR_CHECK(err_code);*/
            err_code = bsp_thread_commissioning_indication_set(BSP_INDICATE_COMMISSIONING_SUCCESS);
            error = otThreadSetEnabled(thread_ot_instance_get(), true);
            ASSERT(error == OT_ERROR_NONE);
            if (m_app.joiner_retry_count < MAX_JOINER_RETRY_COUNT)
                m_app.joiner_retry_count++;
                err_code = app_timer_start(m_joiner_timer, APP_TIMER_TICKS(JOINER_DELAY), thread_ot_instance_get());
    			NRF_LOG_INFO("COMMISSIONING_RETRY\r\n");
                m_app.joiner_retry_count = 0;
                m_app.commissioning_in_progress = false;
    			NRF_LOG_INFO("COMMISSIONING_NOT_COMMISSIONED\r\n");
                    BSP_INDICATE_COMMISSIONING_NOT_COMMISSIONED);
    /*static void nfc_callback(void          * p_context,
                             nfc_t2t_event_t event,
                             const uint8_t * p_data,
                             size_t          data_length)
        UNUSED_VARIABLE(p_context);
        switch (event)
            case NFC_T2T_EVENT_FIELD_ON:
                bsp_board_led_on(BSP_BOARD_LED_3);
                if (!m_app.commissioning_in_progress)
                    m_app.commissioning_in_progress = true;
                    uint32_t err_code = bsp_thread_commissioning_indication_set(
                        BSP_INDICATE_COMMISSIONING_IN_PROGRESS);
            case NFC_T2T_EVENT_FIELD_OFF:
                bsp_board_led_off(BSP_BOARD_LED_3);
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_KEY_3:
                otInstanceFactoryReset(thread_ot_instance_get());
                return;
     * @section State
    static void thread_state_changed_callback(uint32_t flags, void * p_context)
        NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                     flags, otThreadGetDeviceRole(p_context));
     * @section Timers
    static void joiner_timer_handler(void * p_context)
        otError error = otJoinerStart(p_context,
                                      m_app.meshcop_data.psk_d,
                                      EMPTY_VALUE,
                                      "NordicSemiconductor",
                                      EMPTY_VALUE,
                                      EMPTY_VALUE,
                                      EMPTY_VALUE,
                                      joiner_callback,
                                      p_context);
     * @section Initialization
     /**@brief Function for initializing the Application Timer Module
    static void timer_init(void)
        uint32_t err_code = app_timer_init();
        err_code = app_timer_create(&m_joiner_timer, APP_TIMER_MODE_SINGLE_SHOT, joiner_timer_handler);
    /**@brief Function for initializing the LEDs.
    static void leds_init(void)
        LEDS_CONFIGURE(LEDS_MASK);
        LEDS_OFF(LEDS_MASK);
    static void log_init(void)
    /**@brief Function for initializing the Thread Board Support Package
    static void thread_bsp_init(otInstance * p_ot_instance)
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        err_code = bsp_thread_init(p_ot_instance);
    /**@brief Function for initializing the Thread Stack
    static void thread_instance_init(void)
        thread_configuration_t thread_configuration =
            .radio_mode        = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
            .autocommissioning = false,
        thread_init(&thread_configuration);
        thread_cli_init();
        thread_state_changed_callback_set(thread_state_changed_callback);
    /**@brief Function for initializing the Near Field Communication module.
    /*static void nfc_init(void)
        // Set up NFC.
        uint32_t err_code = nfc_t2t_setup(nfc_callback, NULL);
        // Provide information about available buffer size to encoding function.
        uint32_t len = sizeof(m_ndef_msg_buf);
        otLinkGetFactoryAssignedIeeeEui64(thread_ot_instance_get(), &m_app.meshcop_data.eui64);
        err_code = nfc_meshcop_msg_encode(&m_app.meshcop_data, m_ndef_msg_buf, &len);
        // Set created message as the NFC payload.
        err_code = nfc_t2t_payload_set(m_ndef_msg_buf, len);
        // Start sensing NFC field.
        err_code = nfc_t2t_emulation_start();
    /**@brief Function for initializing scheduler module.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
     * @section Main
    int main (int argc, char *argv[])
    	uint32_t err_code;
        log_init();
        scheduler_init();
        timer_init();
        leds_init();
        thread_instance_init();
        thread_bsp_init(thread_ot_instance_get());
        if (!otDatasetIsCommissioned(thread_ot_instance_get()))
            //nfc_init();
        while (true)
            thread_process();
            app_sched_execute();
    		NRF_LOG_FLUSH();
                thread_sleep();
    I am so sorry for the very late reply. Are you still struggling with this?
    Could you call "sudo wpanctl status" to see the status of the network before starting the commissioner?
    Have you tried following the how to Configuring on-mesh Thread commissioning guide from the infocenter? I will link it here in case you haven't seen it.
    Maybe you can provide more of the log information?
    Marjeris
