Stable application crashes at address 0x00000000 when I add JLINK_MONITOR_ISR_SES.s but DebugMonitor_IRQn is disabled
Very strange, I have lots of nRF52x experience, but this one has me stumped.
Successfully updated our custom board/application from nRF5_SDK_15.0.0 to latest as indicated below:
Setups:
SDK: nRF5_SDK_16.0.0_98a08e2
SoftDevice:
FreeRTOS (from SDK)
Segger Embedded Studio (same issue on 4.12 / 4.18 / 4.50)
Windows 10
Custom board
Preprocessor definitions:
BOARD_CUSTOM
NRF52
NRF52832_XXAA
NRF52_PAN_74
S132
SOFTDEVICE_PRESENT
NRF_SD_BLE_API_VERSION=7
CONFIG_NFCT_PINS_AS_GPIOS
FLOAT_ABI_HARD
INITIALIZE_USER_SECTIONS
NO_VTOR_CONFIG
ARM_MATH_CM4
FREERTOS
After migrating to SKD16, everything works very nicely. It is a reasonably complex application.
We use default flash_placement.xml from SDK16 example applications.
Application passes all of our testing. In Debug mode, NRF_LOG via RTT is active. This all operates fine.
Verified we have excess RAM available to the application. RAM_START=0x20002a98.
   ret_code_t ret_code = sd_ble_enable(p_app_ram_start); returns a start value of 0x20002220  ... so we are good here.
To help me isolate the problem, I have erased my nRF52832 IC, and no longer are using our Bootloader.
Only the Softdevice and Application are being loaded via SES.
The last to do item was to re-enable our JLINK debug monitor. This is the ONLY change we are making to the application
We use the recommended method, as outlined in https://github.com/NordicPlayground/j-link-monitoring-mode-debugging. We use the 3 files as is unmodified.
We use the SDK16.0.0 branch, and our JLINK options are set to:
    SetMonModeDebug = 1
    SetMonModeVTableAddr = 0x26000
    We execute NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW);  in our Logger task.
When we do this, our application does not startup up at all, and the SES Debugger shows us at address 0x00000000 ... see attached picture below [Crash.png]
Note also the messaging indicating:   T-bit of XPSR is 0 but should be 1. Changed to 1.
To further isolate the problem, I commented out NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW);  ... but no change...
Very weird ... [DebugMon_Handler] is being compiled in, but not being executed.
... and all of this causes the SES to fail in loading the application.  I am a bit stymied.
I tried setting early breakpoints in thumb_crt0.s ... but it would not hit any of the early breakpoints.
As a very last investigative step, I took the SDK 16.0.0 example application, and modified it to support JLINK_MONITOR ...
... after some tweaking ... works like a charm :}
Free beer to whoever can solve my problem :}
  • Been a while since I have looked at startup code ...
    _start is at 0x26200
    Is there any other code that gets executed upon reset and/or JTAG startup ... ie. Reset_Handler ?
    I could see if possible to set a breakpoint elsewhere, since upon JTAG startup, I cannot get it to break at _start.
  • Coming from 15.0.0 sounds like MBR is new ... but I haven't familiarized myself with it.
    Whats the easiest way to confirm that I have erased it ?
    I see in the softdevice directory there is mbr_nrf52_2.4.1_mbr.hex  which looks to consist of a significant amount of code presumably.
    Maybe my next step is to actually confirm that is truly erased, and not somehow getting in the way.
  • OK, I see MBR is at Flash address 0x0 and indeed I have MBR contents there that match contents of mbr_nrf52_2.4.1_mbr.hex, at least there 1st 100 bytes or so ...
    I wonder if I have no Bootloader ... then if there is any reason for the weird interactions with JLink ?
    But that doesn't make sense ... if I go back to my demo application running ble_app_hrs_freertos_pca10040, and modified to support JLink Debug Monitor, that works fine.
    It also has no Bootloader, and same MBR programmed, using same SDK.
    So bloody weird ...
    But to isolate MBR as being a factor, would you know steps to erase it, and have it boot to application appropriately ?
    I presume JLink may issue a reset command via JTAG after flash programming ... maybe that is the reason for that odd "T-bit of XPSR is 0 but should be 1" ... possibly MBR and JLink battling over something.
  • I use the depreciated nRFGo Studio to Erase All. There is indeed an erase all in SES but I can't confirm that removes the MBR as I haven't tried it. nRFGo Studio is a good option. Nordic say use nRF Connect which should also work.
  • // The least-significant bit of each vector must be 1, indicating that the exception handler is Thumb code
    // See http://infocenter.arm.com/help/topic/com.arm.doc.dui0553b/DUI0553.pdf
