Button Configuration
I need some details about the button configuration
To perform a Single Button configuration like
One click (BUTTON_RELEASE)
Double Click (BUTTON_RELEASE)
Button Press for 3 seconds
Button Press for 7 seconds.
all these configuration should apply for only one BUTTON
if this is case which one is better
app_button.c or bsp.c
2. how do i change the wake up button action.
   i.e -   by default while the system off state . when the button is pressed the system wake up. instead of that i need the
wake up action to be change it to BUTTON _RELEASE .
3. or wake up is to be done after the 3seconds of long press of a button.
  • i have a question that my application run with bootloader and hardware i have only one button.
    If i wakeup the device with pressing the button .it enter into DFU because that pin assigned as DFU button
    so. is it possible to have CONNECTION LIKE THIS
    P0.12 as OUTPUT
    P0.13 as INPUT
    when the controller receive command from the app as DFU
    the Pin
    P0.12 will get high
    and P0.13 will get high and enter into DFU process
    this will work ?
    BSP module uses the app_button library. But the board support package (BSP) includes more things like control of LEDS, buttons, etc, are is mostly intended to be used with nordic development kits.
    BSP have single push and long push, but it doesn't have support for double push.
    I think you will need to make something custom using app_button and app_timer. You can look into the BSP module to see how it generates long pushes so you have a starting guide
    With app_button you will get events for both pushes and releases, so you can start a timer and stop it after each release, or when you detect more than 1 push inside one given interval.
    Marjeris
    Why don't disable the DFU button in the bootloader? Try to use the Buttonless DFU template application example in the SDK instead.
  • Hi msromero,
    I have create the C file to run by button application
    please conform that the work nature or it will not affect cpu life cycle when its applied in a large program
    Main Code:
    #include <stdbool.h>
    #include <stdint.h>
    #include "boards.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nordic_common.h"
    #include "nrf_error.h"
    #include "nrf_gpio.h"
    #include "blc.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    void clock_initialization()
        NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
        NRF_CLOCK->TASKS_LFCLKSTART    = 1;
        while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
            // Do nothing.
    {   bool erase_bonds;
        clock_initialization();
        uint32_t err_code = app_timer_init();
        err_code = blc_init();
        NRF_LOG_INFO("BSP example started.");
        while (true)
            NRF_LOG_FLUSH();
            __SEV();
            __WFE();
            __WFE();
            // no implementation needed
    BLC.h
    #ifndef BLC_H__
    #define BLC_H__
    #include <stdint.h>
    #include "boards.h"
    #include "app_button.h"
    uint32_t blc_init(void);
    BLC.c
    #include "blc.h"
    #include "boards.h"
    #include "bsp_config.h"
    #include "app_error.h"
    char flag = 0;
    bool first_click = false;
    APP_TIMER_DEF(m_button_action);
    #define BUTTON_STATE_POLL_INTERVAL_MS  100UL
    #define LONG_PRESS(MS)    (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
    void button_timeout_handler(void * p_context)
         uint32_t err_code;
         static uint32_t cnt;
         if (app_button_is_pushed(0))
             cnt++;
              NRF_LOG_INFO("cnt: %d",cnt);
             if ( cnt >= LONG_PRESS(1300))
                 cnt = 0;
                 bsp_board_leds_off();
                      bsp_board_led_on(BSP_LED_INDICATE_USER_LED3);
                      bsp_board_led_on(BSP_LED_INDICATE_USER_LED4);
                 NRF_LOG_INFO("Long Button press");
                 flag = 0;
                  err_code = app_timer_start(m_button_action,
                                             APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
                                             NULL);
                  NRF_LOG_INFO("timer");
             if (cnt >= 4 )
              if(flag == 2)
                      bsp_board_led_on(BSP_LED_INDICATE_USER_LED2);
                      NRF_LOG_INFO("double click");
                      first_click = true;
                else if((flag == 1)&& (first_click == true))
                      bsp_board_led_on(BSP_LED_INDICATE_USER_LED1);
                      NRF_LOG_INFO("single click");
              cnt = 0; // reset counter variable
                flag = 0;
    void button_callback(uint8_t pin_no, uint8_t button_action)
          uint32_t err_code;
          if ((pin_no == BUTTON_1) && (button_action == APP_BUTTON_PUSH))
                                         APP_TIMER_TICKS(450),
                                         NULL);
               flag++;
         /* else if ((pin_no == BUTTON_1 ) && (button_action == APP_BUTTON_RELEASE))
            app_timer_stop_all();
            cnt = 0;
    uint32_t blc_init()
      uint32_t err_code = NRF_SUCCESS;
      static app_button_cfg_t  button_cfg;
          button_cfg.pin_no         = BUTTON_1;
          button_cfg.button_handler = button_callback;
          button_cfg.pull_cfg       = NRF_GPIO_PIN_PULLUP;
          button_cfg.active_state   = APP_BUTTON_ACTIVE_LOW;
          err_code = app_button_init(&button_cfg, 1, 100);
          if (err_code == NRF_SUCCESS)
          err_code = app_button_enable();
          /*Enable an app timer instance to detect long button press*/
          err_code = app_timer_create(&m_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_timeout_handler);
           return err_code;
    function of the code:
    First:
    Double click to access single click
    long press for 1.2 sec
    single click and double click function
    i want it to assign the same button for wake up and the wake up function must appear only when button is release .
    how to assign for this
    i will try buttonless dfu and i will reply
