Application timers not working properly
Hello Everyone
I am using two application timers one of standard battery service and one i have made for adc sampling like this along with the code added for battery timers
timers_init()
err_code = app_timer_create(&m_adc_sampling_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                adc_sampling_timeout_handler);
application_timers_start()
 err_code = app_timer_start(m_adc_sampling_timer_id, ADC_SAMPLING_INTERVAL, NULL);
my ADC_SAMPLING_INTERVAL is set for 5 seconds and battery sampling is set for 2 seconds. whenever adc sampling timer is out ... it will trigger for adc sampling
void adc_sampling_timeout_handler(void * p_context)
   UNUSED_PARAMETER(p_context);
    uint32_t p_is_running = 0;
    sd_clock_hfclk_request();
    while(! p_is_running)
        /** wait for the hfclk to be available */
        sd_clock_hfclk_is_running((&p_is_running));
    NRF_ADC->TASKS_START = 1;                   /** Start ADC sampling */
this will call ADC IRQ
void ADC_IRQHandler(void)
    static uint8_t adc_count = 0;
    /* Clear dataready event */
    NRF_ADC->EVENTS_END = 0;
    battery_values[adc_count] = NRF_ADC->RESULT;
    if(adc_count > 4)
        current_battery_value = (battery_values[0] + battery_values[1] + battery_values[2] + battery_values[3] + battery_values[4]) / MAX_ADC_SAMPLES;
        memset(battery_values,0,sizeof(battery_values));
        simple_uart_put(current_battery_value);
        adc_count = 0;
        simple_uart_put(battery_values[adc_count]);
        simple_uart_put(adc_count);
        adc_count++;
    NRF_ADC->TASKS_STOP = 1;
    //Release the external crystal
    sd_clock_hfclk_release();
As shown in the above code it will take 5 samples and average it. each samples shud be taken at the interval of 5 seconds . but in my case 1st sample is taken at the interval of 5 seconds, at another 5 seconds 2nd and 3rd sample are taken together then 4th sample at 5 seconds of interval then again 5th and final sample is taken together at the interval of 5 seconds. which is not what i want each sample shud be taken at the interval of 5 second. can anybody tell me what can be the problem.
Regards Asma
