at command parser library use
nRF9160 DK
I have a simple question regarding processing at command responses. I was hoping to extract the individual values from a at command response using the at command parser library
e.g. from the response "+CESQ: 99,99,255,255,11,49" obtain an array of ints 99,99,255 etc. Before I write code to extract sub strings using comma delimiters will the at command parser
library achieve this? I am struggling to find examples of how to use this library. Using the function "at_params_valid_count_get" on the above example string returns 1 and "at_parser_params_from_str" returns a single value of 99,99,255,255,11,49 so I suspect I am not understanding the purpose of the library or using it correctly. A example of how to use the library would be appreciated.
Thank you
Peter
  • Hi Peter,
    To better understand how to use the AT parser library, you can for example have a look at how CEREG responses are parsed in the LTE link controller:
    https://github.com/NordicPlayground/fw-nrfconnect-nrf/blob/master/lib/lte_link_control/lte_lc.c#L528
    What you need to do is:
    - Initialize a parameter list with the maximum number of parameters in the command response or notification that you wish to decode. So for +CESQ, that is 7, as "+CESQ" also counts as a paramter.
    - Input the response string to the parser using at_parser_max_params_from_str()
    - Read out individual parameter using at_params_string_get() or at_params_int_get() and similar helpper functions. "+CEREG" is the parameter in posiion 0 and can be used to check which response type you're handling.
    - Free the list after you're done with it using at_params_list_free()
    Jan Tore
  • Hi Jan Tore,
    Thanks for your quick response, I have some test parser code working now. I have enabled registration status URC's using +CEREG=1. I take it that I would then need to enable a "global" URC handler using at_notif_register_handler which accepts all URC's and inputs them to the at parser for processing. Since the register handler needs to accept all URC's while the modem is on it never gets de-registered. Is this approach correct? Or can I assign handlers to particular URC's?
    Cheers
    Peter
    Yes, if you're using the at_cmd library, the best way to go about it is to register an AT command handler with at_notif.
    Currently all handlers registered with at_notif will get all URCs, and you can't register a handler for only certain response types.
    So you'll need to have some logic in your handler to check the first parameter coming out of at_parser_max_params_from_str() and handle/ignore it accordingly.
    Jan Tore
  • Hi Jan Tore,
    When I enable a at_notif_register_handler for URC's  I can see the handler being called when URC's are received  but if I try to access the handler's response buffer in any way, the device reset's itself. The same handler used with at command send with callbacks works fine (the at_notif handler is not registered during those tests).
    Also if I setup a simple at socket and poll it I can use a button interrupt to send a at command and get a response but URC's never trigger a POLLIN event.
    I am unsure of what is happening here, any ideas?
    Thank you.
  • Hi Peter,
    Have you checked if this might be a stack overflowing?
    You can enable stack protection by setting CONFIG_HW_STACK_PROTECTION=y in prj.conf.
    If a stack overflows, you'll get some useful debug information to check which instruction causes the error, and which stack is overflowing.
    If possible, you could share your code to make it easier for others to try to reproduce the issues locally and help out that way.
    Regarding the poll() issue, I can't recall having seen similar issues, so I'll have to check that.
    Have you tried doing a blocking receive instead? If so, do you see the same issues?
    Jan Tore
1 2
