Stuck at SOFTDEVICE_HANDLER_INIT (Return NRF_ERROR_INVALID_PARAM)
I am unable to initialize soft device, but I am able to initialize log, led, gpio and timer as well, I can see debug prints as well. After debugging I found following information. Please help me to solve this problem.
I am using following chip and softdevice:
- nRF51822 REV3
- SDK12.3.0
- S130
- Example code app_ble_uart
- Board PCA10001
MEMORY
FLASH (rx) : ORIGIN = 0x1B000, LENGTH = 0x25000
RAM (rwx) : ORIGIN = 0x20001FE8, LENGTH = 0x2018
Q1: I want to confirm, as I am using gcc to compile (Not Keil) is following files is the place to change the Stack and Heap size ?
I am setting stack and heap size in \nRF5_SDK_12.3.0_d7731ad\components\toolchain\gcc\gcc_startup_nrf51.S
- Stack_Size, 2048
- Heap_Size, 2048
Q2: I am getting error in following code: The function  softdevice_handler_init() returns NRF_ERROR_INVALID_PARAM.
#define SOFTDEVICE_HANDLER_INIT(CLOCK_SOURCE,                                                      \
                                EVT_HANDLER)                                                       \
    do        \
        static uint32_t BLE_EVT_BUFFER[CEIL_DIV(BLE_STACK_EVT_MSG_BUF_SIZE, sizeof(uint32_t))];    \
        uint32_t ERR_CODE;        \
        ERR_CODE = softdevice_handler_init((CLOCK_SOURCE),                                         \
                                           BLE_EVT_BUFFER,                                         \
                                           sizeof(BLE_EVT_BUFFER),                                 \
                                           EVT_HANDLER);                                           \
        APP_ERROR_CHECK(ERR_CODE);        \
    } while (0)
DEBUG PRINTS:
Files:
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ic_info.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#ifdef NRF_LOG_MODULE_NAME
#undef NRF_LOG_MODULE_NAME
#define NRF_LOG_MODULE_NAME "APP"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#if (NRF_SD_BLE_API_VERSION == 3)
#define NRF_BLE_MAX_MTU_SIZE            GATT_MTU_SIZE_DEFAULT                       /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    for (uint32_t i = 0; i < length; i++)
        while (app_uart_put(p_data[i]) != NRF_SUCCESS);
    while (app_uart_put('\r') != NRF_SUCCESS);
    while (app_uart_put('\n') != NRF_SUCCESS);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
 * @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            break; // BLE_GAP_EVT_CONNECTED
            break; // BLE_GAP_EVT_DISCONNECTED
            // Pairing not supported
            break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
            break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
        case BLE_GATTC_EVT_TIMEOUT:
            break; // BLE_GATTC_EVT_TIMEOUT
        case BLE_GATTS_EVT_TIMEOUT:
            break; // BLE_GATTS_EVT_TIMEOUT
        case BLE_EVT_USER_MEM_REQUEST:
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            break; // BLE_EVT_USER_MEM_REQUEST
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
        case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
            err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                       NRF_BLE_MAX_MTU_SIZE);
            break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
            // No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
 *        event handler.
 * @details This function is called from the SoftDevice event interrupt handler after a
 *          SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
	//nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION;
    NRF_LOG_INFO("SoftDevice initializing\n");
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    NRF_LOG_INFO("SoftDevice initialized\n");
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    NRF_LOG_INFO("SoftDevice enabled\n");
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    NRF_LOG_INFO("SoftDevice RAM check pass\n");
    // Enable BLE stack.
    ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
    err_code = softdevice_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
                err_code = ble_advertising_restart_without_whitelist();
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\r\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advdata_t          advdata;
    ble_advdata_t          scanrsp;
    ble_adv_modes_config_t options;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    memset(&options, 0, sizeof(options));
    options.ble_adv_fast_enabled  = true;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
    uint32_t err_code;
    bool erase_bonds;
    NRF_LOG_INFO("Logging initialized\n");
	NRF_LOG_INFO("07:59 PM 3/26/2020\n");
    nrf_ic_info_t chipInfo;
    nrf_ic_info_get (&chipInfo);
    NRF_LOG_INFO("CHIP INFO: RAM (%d KB), ROM (%d KB)\n",
                        chipInfo.ram_size, chipInfo.flash_size);
    switch(chipInfo.ic_revision){
        case IC_REVISION_NRF51_REV1:
            NRF_LOG_INFO("IC_REVISION: IC_REVISION_NRF51_REV1\n");
        case IC_REVISION_NRF51_REV2:
            NRF_LOG_INFO("IC_REVISION: IC_REVISION_NRF51_REV2\n");
        case IC_REVISION_NRF51_REV3:
            NRF_LOG_INFO("IC_REVISION: IC_REVISION_NRF51_REV3\n");
        case IC_REVISION_NRF51_UNKNOWN:
            NRF_LOG_INFO("IC_REVISION: IC_REVISION_NRF51_UNKNOWN\n");
            NRF_LOG_INFO("IC_REVISION: UNKNOWN\n");
    // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    NRF_LOG_INFO("Timer initialized\n");
    uart_init();
    NRF_LOG_INFO("Uart initialized\n");
    NRF_LOG_INFO("Led & buttons initialized\n");
    ble_stack_init();
    NRF_LOG_INFO("Ble stack initialized\n");
    gap_params_init();
    NRF_LOG_INFO("GAP params initialized\n");
    services_init();
    NRF_LOG_INFO("Ble service initialized\n");
    advertising_init();
    NRF_LOG_INFO("Ble advertising initialized\n");
    conn_params_init();
    NRF_LOG_INFO("Ble conn params initialized\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    NRF_LOG_INFO("Ble advertising....\n");
    // Enter main loop.
    for (;;)
        if(!NRF_LOG_PROCESS()){
            power_manage();
Q3: I am unable to see file name in debug prints! See following code please.
 * Function is implemented as weak so that it can be overwritten by custom application error handler
 * when needed.
__WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    static error_info_t  * p_error_info;
    p_error_info = (error_info_t*)info;
    NRF_LOG_ERROR("ID: %d, PC: 0x%X\n\r", id, pc);
    NRF_LOG_ERROR("%s (%d): Code 0x%04X %s\n\r",
        (uint32_t)p_error_info->p_file_name, p_error_info->line_num,
        p_error_info->err_code, (uint32_t)ERR_TO_STR(p_error_info->err_code));
    NRF_LOG_FINAL_FLUSH();
    // On assert, the system can only recover with a reset.
#ifndef DEBUG
    NVIC_SystemReset();
#else
    app_error_save_and_stop(id, pc, info);
#endif // DEBUG
Q4: Where I can define DEBUG (I am using gcc as mentioned)?
Let me know if any information you need from me.
Thanks
  • Hi Susheel,
    On nRF51822 I am using (SDK12.3.0 + SoftDevice + HRS Example + FreeRTOS) its running on Dev-Kit but when I change board (PTR5518) its not working.
    First issue was crystal, because PTR5518 not have external crystal. (Solved)(Working ble_uart_app).
    Now HRS example is not working. Any help please. What we need to select in following ?
    #define FREERTOS_USE_RTC      0 /**< Use real time clock for the system */
    #define FREERTOS_USE_SYSTICK  1 /**< Use SysTick timer for system */
