SDK 16
52810
LIS3DH
I2C
I am using nrfx_twi_init and wonder when to set the hold_bus_uninit to true, and when I should leave it false?
SDK 16
52810
LIS3DH
I2C
I think it depends on your HW. It should not matter much if you already have external pull-ups. Are you initializing the TWI driver in your code, and do you want the pull-up to always be enabled? I can think of two scenarios where this setting would make a difference:
1. The external sensor voltage supply is cut off when disabled. In such a case, the sensor may get powered through the bus lines and thus cause a leakage current. Set hold_bus_uninit to false to avoid this.
2. The external sensor is idle but powered after you have un-initialized the TWI. In this case you may want to keep the pull-ups enabled to prevent floating input on the sensor.
