HTTP AT
i work on nrf9160 dk
I would like to know if it is possible to use an AT firmware to be able to easily switch to LTE-M, NB-IOT, send sms, switch off the modem etc.... and also to make http post as on the example "http sample" which works very well.
I tried the firmware "simple_at" which works well too but by combining the two, nothing works anymore.
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <drivers/uart.h>
#include <string.h>
#include <zephyr.h>
#include <net/socket.h>
#define HTTP_HOST "google.com"
#define HTTP_PORT 80
#define RECV_BUF_SIZE 1024
char recv_buf[RECV_BUF_SIZE + 1];
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", err);
/**@brief HTTP function */
int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
	int err;
	do {
		err = recv(fd, buf, size, flags);
	} while (err < 0 && errno == EAGAIN);
	return err;
int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags)
	int err;
	do {
		err = send(fd, buf, size, flags);
	return err;
int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len)
	int err;
	do {
		err = connect(fd, local_addr, len);
	return err;
const char *at_commands[] = {
	"AT+CFUN?", "AT+CFUN=1", "AT+CFUN?",
	/* Add more here if needed */
void app_socket_start(void)
	int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
	printk("Starting simple AT socket application\n\r");
	if (at_socket_fd < 0) {
		printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		int bytes_written = send(at_socket_fd, at_commands[i],
					 strlen(at_commands[i]), 0);
		if (bytes_written > 0) {
			int r_bytes =
				blocking_recv(at_socket_fd, recv_buf,
					      sizeof(recv_buf), MSG_DONTWAIT);
			if (r_bytes > 0) {
				printk("%s", recv_buf);
	printk("Closing socket\n\r");
	(void)close(at_socket_fd);
void app_http_start(void)
	struct sockaddr_in local_addr;
	struct addrinfo *res;
	local_addr.sin_family = AF_INET;
	local_addr.sin_port = htons(0);
	local_addr.sin_addr.s_addr = 0;
	printk("HTTP example\n\r");
	int err = getaddrinfo(HTTP_HOST, NULL, NULL, &res);
	printk("getaddrinfo err: %d\n\r", err);
	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
	char send_buf[] =
		//"GET / HTTP/1.1\r\nHost: www.google.com:80\r\nConnection: close\r\n\r\n";
                "POST / HTTP/1.0\r\nHost: www.google.com:80\r\nContent-Type: application/json\r\nContent-Length: 41\r\n\r\n\{\"payload\": \"trame NBIOT de nrf9160 v01\"\}\x1A";
	int send_data_len = strlen(send_buf);
	int client_fd = socket(AF_INET, SOCK_STREAM, 0);
	printk("client_fd: %d\n\r", client_fd);
	err = bind(client_fd, (struct sockaddr *)&local_addr,
		   sizeof(local_addr));
	printk("bind err: %d\n\r", err);
	err = blocking_connect(client_fd, (struct sockaddr *)res->ai_addr,
			       sizeof(struct sockaddr_in));
	printk("connect err: %d\n\r", err);
	int num_bytes = send(client_fd, send_buf, send_data_len, 0);
	printk("send err: %d\n\r", num_bytes);
	int tot_num_bytes = 0;
	do {
		/* TODO: make a proper timeout *
		 * Current solution will just hang
		 * until remote side closes connection */
		num_bytes =
			blocking_recv(client_fd, recv_buf, RECV_BUF_SIZE, 0);
		tot_num_bytes += num_bytes;
		if (num_bytes <= 0) {
	} while (num_bytes > 0);
	printk("\n\rFinished. Closing socket");
	freeaddrinfo(res);
	err = close(client_fd);
void main(void)
	printk("The AT \n");
        app_socket_start();
        printk("The AT 1\n");
       // app_http_start();
        printk("The AT Maxime2\n");
    Thank's for your answer.
    I solved this problem with this function:
    *name:
    *to do:  Repete AT+CEREG jusqu'à avoir du reseau
    *return:
    void Wait_connection(void) {
      char recv_buf1[50];
      char *bufatest;
      int event = 0;
      const char *at_commandsOFF[] =
              "AT+CEREG?", /* Retour d'état de connexion( PSM activé, Connecté au reseau etc...) */
      /* On attend que le modem se connect a la station de base */
      while (event != 8) {
        switch (event) {
        case 0: {
          for (int i = 0; i < ARRAY_SIZE(at_commandsOFF); i++) {
            int bytes_written = send(at_socket_fd, at_commandsOFF[i],
                strlen(at_commandsOFF[i]), 0);
              int r_bytes =
                  blocking_recv(at_socket_fd, recv_buf1,
                      sizeof(recv_buf1), MSG_DONTWAIT);
              if (r_bytes > 0) {
                printk("%s", recv_buf1);
          event = 1;
        case 1: {
          bufatest = strstr(recv_buf1, "+CEREG: 0,1,");
          if (bufatest != NULL) {
            event = 8;
          } else {
            printk("wait");
            k_sleep(K_MSEC(1000));
            event = 0;
    I think to use "w_lte_lc_connect" is better but do you have some example for this ? Because i can't replace and use my function with your function like that..
    Thank's for your help
    Max
  • Hi Max,
    w_lte_lc_connect() is called within lte_lc_init_and_connect(). This is used by several of our samples, e.g. https_client.
    Øyvind
