nrf9160 ztest framework : unable to get a unit test to work
Hi. I am working on the nrf9160. I want to use a unit test framework for my application code (which is a combination of C/C++14). I thought about using gtest/gmock or ztest. For now I am trying to get to run a single sample provided: zephyr/sample/testing/integration up and running but unable to do so. I am working on a win 64 laptop.  Can you please explain how I can run a unit test please. I looked at the following webpages:https://docs.zephyrproject.org/1.12.0/subsystems/test/ztest.htmlhttps://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_ZTEST.htmlhttps://developer.nordicsemi.com/nRF_Connect_SDK/doc/0.4.0/zephyr/guides/test/ztest.html. Please dont direct me to the same webpages.
what are the steps to run a unit/integration test on the win 64 enviroment? Do I have to run cmake? Trying to run the sanitycheck script fails due to several reasons:
On cmd:
xxxxx\zephyr\scripts>python sanitycheck -s ..\samples\testing\integration
Install the anytree module to use the --test-tree option
Install tabulate python module with pip to use --device-testing option.
Renaming output directory to xxx\zephyr\scripts\sanity-out.4
INFO - JOBS: 8
INFO - Selecting default platforms per test case
INFO - Building initial testcase list...
INFO - 0 test configurations selected, 163531 configurations discarded due to filters.
INFO - Adding tasks to the queue...
INFO - [32m0 of 0[39m tests passed (0.00%), [39m0[39m failed, 0 skipped with [39m0[39m warnings in 7.89 seconds
INFO - In total 741 test cases were executed on 0 out of total 225 platforms (0.00%)
'stty' is not recognized as an internal or external command,
operable program or batch file.
On Cygwin: "/usr/bin/env: ‘python3’: No such file or directory" python3 not found. I had to change the shebang in sanitycheck to python instead. After that another error:
$ xxx/zephyr/scripts/sanitycheck -s ../samples/testing/integration
File "xxx/zephyr/scripts/sanitycheck", line 213, in <module>
import edtlib
ModuleNotFoundError: No module named 'edtlib'
when I try to source the zephyr env variable on cygwin: here is the error i get:
source xxx/zephyr/zephyr-env.sh
-bash: $'\r': command not found
-bash: xxx/zephyr/zephyr-env.sh: line 70: syntax error: unexpected end of file
All I want to do is write unit tests and then eventually integration tests using the ztest framework, first on win64 platform. I hope someone can help me out. Please provide a step wise approach with commands to be run. Noob here.
    I am also trying to get unit testing working on nrf91, and also got to this part. I am developing on Ubuntu. What are the next steps to get tests from main.c running?
    Vojislav
  • Sorry for the delay, I've been gone due to easter holidays.
    Could you open a new ticket and ask your question there, since the questions are somewhat unrelated(The first question was about getting tests to work on windows and this question is asking specifically about the tests)? This way we can keep everything more organized.
    Simon
  • Hi Simon, Not a problem. As the heading says: unable to get a unit test to work. I don't see the test in the main.c being run, and my questions previously still hold.Here is a clear list of questions:
    • The sanitycheck script did run without errors on windows but the output of that script needs some explanations. What are the 742 tests found? Why are 0 tests run etc. Please help me understand these.
    • Why can I not see the tests from main.c ? What am I missing?
  • I guess you're right, was too quick to answer. I'll look into it.
    Have you made any progress?
  • Were you able to get either unit test script working in the end? I'm currently attempting to set up unit tests and am coming across the same problems.
1 2 3
