nrf9160 ztest framework : unable to get a unit test to work
Hi. I am working on the nrf9160. I want to use a unit test framework for my application code (which is a combination of C/C++14). I thought about using gtest/gmock or ztest. For now I am trying to get to run a single sample provided: zephyr/sample/testing/integration up and running but unable to do so. I am working on a win 64 laptop.  Can you please explain how I can run a unit test please. I looked at the following webpages:https://docs.zephyrproject.org/1.12.0/subsystems/test/ztest.htmlhttps://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_ZTEST.htmlhttps://developer.nordicsemi.com/nRF_Connect_SDK/doc/0.4.0/zephyr/guides/test/ztest.html. Please dont direct me to the same webpages.
what are the steps to run a unit/integration test on the win 64 enviroment? Do I have to run cmake? Trying to run the sanitycheck script fails due to several reasons:
On cmd:
xxxxx\zephyr\scripts>python sanitycheck -s ..\samples\testing\integration
Install the anytree module to use the --test-tree option
Install tabulate python module with pip to use --device-testing option.
Renaming output directory to xxx\zephyr\scripts\sanity-out.4
INFO - JOBS: 8
INFO - Selecting default platforms per test case
INFO - Building initial testcase list...
INFO - 0 test configurations selected, 163531 configurations discarded due to filters.
INFO - Adding tasks to the queue...
INFO - [32m0 of 0[39m tests passed (0.00%), [39m0[39m failed, 0 skipped with [39m0[39m warnings in 7.89 seconds
INFO - In total 741 test cases were executed on 0 out of total 225 platforms (0.00%)
'stty' is not recognized as an internal or external command,
operable program or batch file.
On Cygwin: "/usr/bin/env: ‘python3’: No such file or directory" python3 not found. I had to change the shebang in sanitycheck to python instead. After that another error:
$ xxx/zephyr/scripts/sanitycheck -s ../samples/testing/integration
File "xxx/zephyr/scripts/sanitycheck", line 213, in <module>
import edtlib
ModuleNotFoundError: No module named 'edtlib'
when I try to source the zephyr env variable on cygwin: here is the error i get:
source xxx/zephyr/zephyr-env.sh
-bash: $'\r': command not found
-bash: xxx/zephyr/zephyr-env.sh: line 70: syntax error: unexpected end of file
All I want to do is write unit tests and then eventually integration tests using the ztest framework, first on win64 platform. I hope someone can help me out. Please provide a step wise approach with commands to be run. Noob here.
  • Okay. Just to mention: VB Ubuntu is not a preferred option...as of now.
  • It seems like this line is the one that includes the path where zephyr/scripts/dts/edtlib.py is located.
    Have you set the ZEPHYR_BASE?
    Could you try to add the following below this line (above import edtlib), to see what the path is equal to:
    print("scripts/dts/ path",os.path.join(ZEPHYR_BASE, "scripts", "dts"))
    Simon
  • Hi SImon,
    I see what I got previously after adding "dts." to the import paths.
    $ zephyr/scripts/sanitycheck -s ../samples/testing/integration
    scripts/dts/ path C:\ConnectivityNodes_Cellular\zephyr\scripts\dts
    File "zephyr/scripts/sanitycheck", line 1403, in <module>
    class Platform:
    File "zephyr/scripts/sanitycheck", line 1408, in Platform
    platform_schema = scl.yaml_load(os.path.join(ZEPHYR_BASE,
    File "C:\ConnectivityNode_Cellular\zephyr\scripts\sanity_chk\scl.py", line 29, in yaml_load
    with open(filename, 'r') as f:
    FileNotFoundError: [Errno 2] No such file or directory: 'C:\\ConnectivityNodes_Cellular\\zephyr\\scripts\\sanity_chk\\platform-schema.yaml'
  • I managed to make this work, I did the following:
    • Installed ncs v1.2.0. Check out our newly released app Toolchain Manager, which simplifies the process of installing ncs
    • Opened Git Bash
    • Typed in:
    cd <location_of_ncs>/ncs/zephyr
    export ZEPHYR_BASE=c:/Nordic_SDK/ncs/zephyr
    • Copied the sample ..\ncs\zephyr\samples\testing\integration into ..\ncs\zephyr\tests
    • Ran the following command:
    python scripts/sanitycheck -s tests/integration
    • Got the following output:
    INFO    - JOBS: 8
    INFO    - 0 test configurations selected, 163755 configurations discarded due to filters.
    INFO    - 0 of 0 tests passed (0.00%), 0 failed, 0 skipped with 0 warnings in 4.73 seconds
    INFO    - In total 742 test cases were executed on 0 out of total 225 platforms (0.00%)
    Renaming output directory to C:\Nordic_SDK\ncs\zephyr\sanity-out.4
    Simon
  • Hi Simon. Thanks for the update. After copying the folder to zephyr/tests it seems to be working. Here is my output:
    INFO - JOBS: 8
    INFO - 0 of 0 tests passed (0.00%), 0 failed, 0 skipped with 0 warnings in 5.14 seconds
    scripts/dts/ path xxx/zephyr\scripts\dts
    Renaming output directory to xxx\zephyr\sanity-out.1
    But I am surprised that the script found 742 tests and it was not run on any platform. It says  "0 test configurations selected" and "0 of 0 tests passed (0.00%), 0 failed" How do I run the testcase from main.c and see the output?
