Unexpected system reset(may caused with spi and twi conflict)
Hi, Guys,
I have occured a wired thing. I use NRF51822 with softdevice S130 to do a BLE project. I use both spi and twi to get information from sensor(I use spi0 and twi1, I know that the spi0 and twi0 share the same base address). However, after power on, the chip continuously reset itself. The reset reason is 0x08 cpu lock-up. The wired thing is, this won't happen during the debug session. only happen on regular power-on session. So I can not even debug where goes wrong. Does anyone who may know this? Thank you so much.
I use twi_hw_master and spi_master from the SDK V7.1.0, but I use SHORTS in twi_hd_master instead of PPI.
UPDATE: after tried several times, I think I know what's going on, the thing is SPI and TWI can not coexist. If I disable one of these two, the system works fine. But I still don't know why, because I use SPI0 and TWI1, there two peripheral didn't share the resource. Does any one know why?
  • Hi, cnchen,
    I figured out the issue. The reset issue is not caused by TWI0 and SPI1 incompatible. But due to flash storage shortage. The code size of our system is a little big. So it reach the boundary of the total 256kb flash memory. After optimize the code and decrease the code size the system works fine. I know this is really a specific case for me. I am not sure if you have the same root cause. But might be a way of solution. Just for your information. Thanks.
  • Hi, cnchen,
