I don't know how to display the serial log of the program on the NRF connect tool.
Can you give me some advice? Thanks.
If you do not see RSSI change and packet count of 0, the DTM test is not running correctly. I tested this with nRF Connect DTM app, this is the RTT output:
I used two instances of nRF Connect DTM app together with two DKs, one running receive test (the one with the firmware attached to my previous post, make sure you press 'No' when nRF Connect asks you to flash firmware when opening the connection to this board) and the second board running transmit test (this can use the default DTM firmware flashed by nRF Connect DTM app).
Thank you very much for your answer.
