nrf52833 development board flash memory defect.
Dear Sir or Madam,
It´s the second time, I got the same error while start developing with nrf52833 demo board. For first step, I flashed a blinky example to the board - just simple by usb flash memory option. But after a few days, I can´t flash by this option. The device is defect. I can´t use the memory furthermore. The device manager of windows shows en error as shown in attached screenshot. But I think this is no driver problem.
This is the second board I bought and I don´t know what iI´m doing wrong with it. I can´t explain, why this board is suddenly defect. I didn´t do anything with it.
Do you have any idea?
Thanks in advance
Simon
  • My demo boards are both just a few days old, nothing done with it
  • Error from Windows device manager:
    The device cannot be started. (Code 10)
    The I / O device is configured incorrectly or the configuration parameters for the driver are incorrect.
    Can you confirm that you have plugged the USB cable into the USB port on the short end of the DK?
    Can you let me know what positions your switches are in? SW6, ON/OFF, OFF/CN, Li-Po/VDD/USB, nRF OnLY/DEFAULT, and TRACE?
    Have you tried setting the DK in bootloader mode and uploading the programmer chip FW again?
    the positions of the switches are:
    SW6: Default
    SW7 Trace: Default
    SW8: ON
    SW9: VDD
    SW 10: OFF
    I just changed position of SW 8, for power up the board.
    How can I do this? There are a lot of bootloader firmware in the SDK, which one can I use? Where can I find the original factory firmware? I flashed the "blinky" example, maybe I overwrite the bootloader?...
    Thanks in advane.
    Simon
  • Ok. The switches seems to be in the right position.
    When you say that you flashed the blinky example, can you explain to me how you did that? I suspect you did some drag'n'drop action. With a little bit of bad luck, that may be a bit unfortunate.
     Note that the bootloader mode that I mentioned here is not for the nRF52, but for the programming chip mounted on the DK.
    What I want you to do is to try the following:
    1: Download the file "Interface MCU Firmware" (JLink) from here: https://www.nordicsemi.com/Software-and-tools/Development-Kits/nRF52-DK/Download#infotabs
    2: Power off the DK using the on/off switch (SW8)
    3: Hold the IF BOOT/RESET buttone while you power on the DK. At this point you should see that LED5 blinks about once every second.
    4: Drag'n'drop the file you downloaded, J-Link OB-SAM3U128-V2-NordicSemi 170724.bin, to the device called BOOTLOADER and wait for the copy to finish.
    5. LED5 should start blinking more rapidly. When this happens, power cycle the DK (without holding IF BOOT/RESET), and it should pop up as a JLink device.
    I suspect what happened was that perhaps you by mistake put the DK (the programming chip) in bootloader mode earlier, and then you uploaded the hex file intended for the nRF52833 to the programming chip.
    Try the steps above, and let me know how it goes.
    Edvin
