Dead in the water - "Error starting process make"
Hi Folks,
Windows 10, clean install of ncs v1.2.0, using nRF5340-PDK with SES 4.42a.
Project blinky rebuilds and runs fine.
Now I need a zephyr example of creating a simple library.   My library will be DSP related.  I desire that it can be easily included into multiple related projects on the nRF5340.
So I found the following:   ncs/zephyr/samples/application_development/external_lib
It is a hello world example of a library target.
When I go to compile, I get the following output:
Rebuilding ‘C:/Users/sandbox/dev/ncs/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Rebuilding ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Rebuilding ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘C:/Users/sandbox/dev/ncs/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘C:/Users/sandbox/dev/ncs/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Rebuilding ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Rebuilding ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
Rebuilding ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
Rebuilding ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_..__modules__hal__nordic’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-mkdir’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-mkdir’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-download’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-download’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-update’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-update’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-patch’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-patch’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-configure’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-configure’
Rebuilding ‘mylib/src/mylib_project-stamp/mylib_project-build’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘mylib/src/mylib_project-stamp/mylib_project-build’
1> Error starting process make
Build failed
Is there anyway to get more info on what failed so I can proceed on my mission....or alternatively, is there a another example of creating a simple library that will work instead?
Kind regards!
  • Hi Amanda....below is the build output from a command line pristine build of external_lib sample.  I used a clean Windows 10 install with no extra tools loaded other than those installed by NCS Getting Started Assistant.   Thanks for your advice, but this does not appear to be a Nordic specific issue...just that I run into it while trying to get up & running on the nRF5340-PDK.   My solution was to install make (choco install make), and fix the makefile so it doesn't crash when executing 'mkdir -p'.
    c:\ncs\zephyr\samples\application_development\external_lib>west build -p -b nrf5340_dk_nrf5340_cpuapp
    -- west build: making build dir c:\ncs\zephyr\samples\application_development\external_lib\build pristine
    -- west build: build configuration:
           source directory: c:\ncs\zephyr\samples\application_development\external_lib
           build directory: c:\ncs\zephyr\samples\application_development\external_lib\build
           BOARD: nrf5340_dk_nrf5340_cpuapp (origin: command line)
    -- Zephyr version: 2.1.99
    -- Found PythonInterp: C:/Python38/python.exe (found suitable version "3.8.2", minimum required is "3.6")
    -- git describe failed: fatal: not a git repository (or any of the parent directories): .git;
       BUILD_VERSION is left undefined
    -- Selected BOARD nrf5340_dk_nrf5340_cpuapp
    -- Found west: C:/Python38/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
    -- Loading C:/ncs/zephyr/boards/arm/nrf5340_dk_nrf5340/nrf5340_dk_nrf5340_cpuapp.dts as base
    Devicetree configuration written to C:/ncs/zephyr/samples/application_development/external_lib/build/zephyr/include/generated/devicetree.conf
    Parsing C:/ncs/zephyr/Kconfig
    C:/ncs/nrf\lib\fprotect/Kconfig:20: WARNING: dt_int_val is deprecated.
    C:/ncs/bootloader/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
    Loaded configuration 'C:/ncs/zephyr/boards/arm/nrf5340_dk_nrf5340/nrf5340_dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/ncs/zephyr/samples/application_development/external_lib/prj.conf'
    Configuration saved to 'C:/ncs/zephyr/samples/application_development/external_lib/build/zephyr/.config'
    -- The C compiler identification is GNU 8.3.1
    -- The CXX compiler identification is GNU 8.3.1
    -- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
    -- Cache files will be written to: C:/ncs/zephyr/.cache
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/zephyr/samples/application_development/external_lib/build
    [1/133] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
    [2/133] Generating include/generated/driver-validation.h
    [3/133] Generating misc/generated/syscalls.json
    [4/133] Creating directories for 'mylib_project'
    [5/133] No download step for 'mylib_project'
    [6/133] No patch step for 'mylib_project'
    [7/133] No update step for 'mylib_project'
    [8/133] No configure step for 'mylib_project'
    [9/133] Performing build step for 'mylib_project'
    FAILED: mylib/src/mylib_project-stamp/mylib_project-build mylib/lib/libmylib.a
    cmd.exe /C "cd /D C:\ncs\zephyr\samples\application_development\external_lib\mylib && make PREFIX=C:/ncs/zephyr/samples/application_development/external_lib/build/mylib CC=C:/gnuarmemb/bin/arm-none-eabi-gcc.exe AR=C:/gnuarmemb/bin/arm-none-eabi-ar.exe "CFLAGS=-IC:/ncs/zephyr/include -IC:/ncs/zephyr/samples/application_development/external_lib/build/zephyr/include/generated -IC:/ncs/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/zephyr/lib/libc/minimal/include -IC:/ncs/zephyr/ext/hal/cmsis/Core/Include -IC:/ncs/nrf/include -IC:/ncs/modules/hal/nordic/nrfx -IC:/ncs/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/modules/hal/nordic/nrfx/mdk -IC:/ncs/modules/hal/nordic/. -Ic:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include -Ic:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include-fixed -DKERNEL -D__ZEPHYR__=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -DUSE_PARTITION_MANAGER=0 -DNRF5340_XXAA_APPLICATION -Os -imacrosC:/ncs/zephyr/samples/application_development/external_lib/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mthumb -mcpu=cortex-m33 -imacrosC:/ncs/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/ncs/zephyr/samples/application_development/external_lib=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/zephyr=ZEPHYR_BASE -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -std=c99 -nostdinc -isystemC:/ncs/zephyr/lib/libc/minimal/include -isystemc:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include -isystemc:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include-fixed" && "C:\Program Files\CMake\bin\cmake.exe" -E touch C:/ncs/zephyr/samples/application_development/external_lib/build/mylib/src/mylib_project-stamp/mylib_project-build"
    'make' is not recognized as an internal or external command,
    operable program or batch file.
    [10/133] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    For the second item, I might not have been clear. -- my ask is ease of use.   I am looking for how to add the library source files into SES so that SES can be used to edit, build, and debug the library.    So the concise question for this example is: how do I add mylib.c into the SES solution?  (all I see is main.c)
    The log indicates:
    You need to install the tool to use make.
     nRF Connect SDK (NCS) projects are configured from CMake. Please take a look the CMakeLists.txt under \ncs\zephyr\samples\application_development\external_lib
    -Amanda H.
  • Hi Amanda.  For some reason I was under the impression I could manage (add/delete) source files within SES, but that is not the case.  Also, I agree there is no automatic install for make in Windows, it must be done manually.  Thanks for attending this issue.
