SDK 16.0 output LOGs
Hi there,
Please, if someone can help me (or let me know of other people answered questions), I have multiple questions regarding Nordic's SDK 16.0. My board is nRF DK for nrf52832, and right now I am developing with terminal (my next step is to use a proper IDE,but for the moment I'm trying to figure out how to make it work with command line tools).
1. Why is RTT not included in the SDK? I was looking for it, but seems like it is not included. I manually included as I'm going to use it to debug, but is there a reason of why RTT was not within the SDK's components?
2. NRF_LOG or RTT commands? Which have you used for debug, which one you recommend?
3. I'm not able to see the NRF_LOGs with RTT Viewer. As I see, seems like the sdk_config.h should contain a field saying something like LOG_ENABLE_RTT or similar(to enable LOGs over UART or RTT). I'm looking into /examples/peripheral/uart/pca10040/blank/config/sdk_config.h. Do you know where can I find this option? I have the feeling that the project is trying to use UART for LOGs...
4. How can I debug using UART module using NRG_LOG via usb? Whenever I run the uart example, I connect the board to my Ubuntu PC and try to open a port, but I can only find the JLink interfac
df -h displays:
Filesystem      Size  Used Avail Use% Mounted on
udev            3,8G     0  3,8G   0% /dev
tmpfs           783M  1,7M  781M   1% /run
/dev/sda1       229G  123G   95G  57% /
tmpfs           3,9G   85M  3,8G   3% /dev/shm
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           3,9G     0  3,9G   0% /sys/fs/cgroup
/dev/loop2      3,8M  3,8M     0 100% /snap/gnome-system-monitor/135
/dev/loop1      203M  203M     0 100% /snap/vlc/1397
/dev/loop5       15M   15M     0 100% /snap/gnome-characters/399
/dev/loop4      4,3M  4,3M     0 100% /snap/gnome-calculator/544
/dev/loop0       92M   92M     0 100% /snap/core/8689
/dev/loop7      225M  225M     0 100% /snap/wine-platform-runtime/94
/dev/loop6       92M   92M     0 100% /snap/core/8592
/dev/loop8      443M  443M     0 100% /snap/clion/103
/dev/loop9      3,8M  3,8M     0 100% /snap/gnome-system-monitor/127
/dev/loop3       15M   15M     0 100% /snap/gnome-characters/495
/dev/loop11     4,4M  4,4M     0 100% /snap/gnome-calculator/704
/dev/loop10     4,0M  4,0M     0 100% /snap/notepad-plus-plus/225
/dev/loop12      49M   49M     0 100% /snap/gtk-common-themes/1474
/dev/loop14     1,0M  1,0M     0 100% /snap/gnome-logs/81
/dev/loop13     143M  143M     0 100% /snap/slack/22
/dev/loop15      45M   45M     0 100% /snap/gtk-common-themes/1440
/dev/loop16     1,0M  1,0M     0 100% /snap/gnome-logs/93
/dev/loop17      55M   55M     0 100% /snap/core18/1705
/dev/loop18     444M  444M     0 100% /snap/clion/107
/dev/loop19      55M   55M     0 100% /snap/core18/1668
/dev/loop20     143M  143M     0 100% /snap/slack/21
/dev/loop21      74M   74M     0 100% /snap/wine-platform-3-stable/6
tmpfs           783M   92K  783M   1% /run/user/1000
/dev/loop22     227M  227M     0 100% /snap/wine-platform-runtime/104
/dev/loop23     4,0M  4,0M     0 100% /snap/notepad-plus-plus/227
/dev/loop24     161M  161M     0 100% /snap/gnome-3-28-1804/116
/dev/sdb         11M  128K   11M   2% /media/pablo/JLINK
How can I connect the uart from the nRF52 so I can open a COM port with Putty or similar?
Thank you for your time,
Pablo G
