Build failure for bluetooth hci rpmsg example for nrf5340 pdk when following youtube tutorial
I am having an issue when building the hci rpmsg example for the following youtube tutorial
Zephyr RTOS and Bluetooth LE on the dual-core nRF5340
I've tried figuring this out but I keep getting the same output when building with the following:
ncs/fw-nrfconnect-nrf/zephyr on HEAD (7ddab66)
❯ west build -b nrf5340_dk_nrf5340_cpunet samples/bluetooth/hci_rpmsg
-- west build: build configuration:
source directory: PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/samples/bluetooth/hci_rpmsg
build directory: PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build
BOARD: nrf5340_dk_nrf5340_cpunet (origin: CMakeCache.txt)
[0/1] Re-running CMake...
-- Zephyr version: 2.1.99
-- Selected BOARD nrf5340_dk_nrf5340_cpunet
-- Found west: /PATH_TO_NCS/.local/bin/west (found suitable version "0.6.3", minimum required is "0.6.0")
-- Loading PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/boards/arm/nrf5340_dk_nrf5340/nrf5340_dk_nrf5340_cpunet.dts as base
nrf5340_dk_nrf5340_cpunet.dts.pre.tmp:79.25-85.5: Warning (unique_unit_address_if_enabled): /soc/clock@41005000: duplicate unit-address (also used in node /soc/power@41005000)
Devicetree configuration written to PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build/zephyr/include/generated/devicetree.conf
Parsing PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/Kconfig
PATH_TO_NCS/ncs/fw-nrfconnect-nrf/nrf/lib/fprotect/Kconfig:19: WARNING: dt_int_val is deprecated.
PATH_TO_NCS/ncs/fw-nrfconnect-nrf/bootloader/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
Loaded configuration 'PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build/zephyr/.config'
No change to 'PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build/zephyr/.config'
-- Cache files will be written to: /PATH_TO_NCS/.cache/zephyr
-- Build type: Debug
-- Host: Linux/x86_64
-- Target: Generic/arm
-- Machine: cortexm
-- Machine: cortexm
-- C_FLAGS : -Wall -Wextra
-- Configuring done
-- Generating done
-- Build files have been written to: PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build
ninja: error: 'cmake_object_order_depends_target_metal_', needed by 'cmake_object_order_depends_target_zephyr_final_', missing and no known rule to make it
ERROR: command exited with status 1: /usr/bin/cmake --build PATH_TO_NCS/ncs/fw-nrfconnect-nrf/zephyr/build
1 2
