TX Carrier frequency offset
We are in process to certified a product using the nrf52832. While testing the certification team find an offset greater than 20 ppm, like in the following scree shot:
(2 402 058 [Hz] - 2 402 000 [Hz]) / 2 402 000 [Hz] = 24.1 e-6
12pF capacitors are used on a 32MHz crystal with load capacitance of 10pF. The 32 MHz crystal frequency tolerance is +/-10ppm at +25°C, +/-20ppm between -20°C and +70°C.
Is this level of accuracy is possible with the nrf52832?
Thank you for your help!
