I'm experiencing a freeze - at least from user's perspective - when using a slightly modified "usbd_cdc_acm"-example and applying some human generated load (meaning: hitting the keyboard for a couple of seconds, incl. '\n' every now and then in order to reset the buffer / break out of the loop (see code below)).
Sooner or later it's going to freeze at the point right after the `break`.
Hardware is a nRF52840 USB dongle, SDK nRF5 SDK v16.0.0, SoftDevice s140_nrf52_7.0.1
The following diff to mentioned example code will render the nrf52840 unresponsive, meaning, it's stuck and doesn't loop through the main loop anymore.
diff --git a/examples/peripheral/usbd_cdc_acm/main.c b/examples/peripheral/usbd_cdc_acm/main.cindex c78f24cc..1ebc20bf 100644--- a/examples/peripheral/usbd_cdc_acm/main.c+++ b/examples/peripheral/usbd_cdc_acm/main.c@@ -133,7 +133,8 @@ APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,#define READ_SIZE 1-static char m_rx_buffer[READ_SIZE];+static uint8_t m_rx_buffer_pos = 0;+static char m_rx_buffer[512];static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];static bool m_send_flag = 0;@@ -172,12 +173,21 @@ static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,{/*Get amount of data transfered*/size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);- NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);+ NRF_LOG_INFO("RX: size: %lu - char: %d - pos: %d", size, m_rx_buffer[m_rx_buffer_pos], m_rx_buffer_pos);/* Fetch data until internal buffer is empty */ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,- m_rx_buffer,+ &m_rx_buffer[++m_rx_buffer_pos],READ_SIZE);++ if(m_rx_buffer[m_rx_buffer_pos-1] == '\r')+ {+ m_rx_buffer[++m_rx_buffer_pos] = '\0';+ NRF_LOG_INFO("Transmission finished - resetting buffer");+ m_rx_buffer_pos = 0;+ break;+ }+} while (ret == NRF_SUCCESS);bsp_board_led_invert(LED_CDC_ACM_RX);@@ -296,6 +306,7 @@ int main(void)ret = NRF_LOG_INIT(NULL);APP_ERROR_CHECK(ret);+ NRF_LOG_DEFAULT_BACKENDS_INIT();ret = nrf_drv_clock_init();APP_ERROR_CHECK(ret);
According to my debugger it appears to be stuck at __WFE(), however I'm not sure how much I can trust it in that state, also given I've seen it showing me various locations when hitting ^C at the moment of freeze:
Program received signal SIGINT, Interrupt.
0x000311b4 in __WFE () at ../../../../../../components/toolchain/cmsis/include/cmsis_gcc.h:396
396 __ASM volatile ("wfe");
Last line of output from above modified example after hitting the keyboard like a monkey:<info> app: RX: size: 1 - char: 116 - pos: 1<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 13 - pos: 2<info> app: Transmission finished - resetting buffer<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 32 - pos: 0<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 32 - pos: 1<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 13 - pos: 2<info> app: Transmission finished - resetting buffer<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 32 - pos: 0<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 104 - pos: 1<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 13 - pos: 2<info> app: Transmission finished - resetting buffer<info> app: Bytes waiting: 0<info> app: RX: size: 1 - char: 32 - pos: 0<info> app: Bytes waiting: 1<info> app: RX: size: 1 - char: 13 - pos: 1<info> app: Transmission finished - resetting buffer
I'm chasing the root cause for a while now and herewith tried to break and narrow it down to a minimal example triggering the issue, hoping somebody else might be able to spot the flaw.
