Implement scan request / scan response by directly accessing radio
Hello
Beacon using timeslot API
I am trying to implementing a beacon functionality using your timeslot API.
The beacon shall run in parallel to the normal SoftDevice operations such as advertising / being in a connection.
Using your Multi Activity Example (https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v11.0.0/ble_sdk_app_multi_activity.html) as a reference, I was able to implement a beacon in non-connectable/non-scannable mode.
Scannable beacon
Now, I would like to make the beacon scannable.
I know that this is not common for a beacon. But, since some vendors offer the option, I am assuming, our customers would want it too.
As with the timeslot API the radio is accessed directly, I assume, waiting for a scan request and sending the response while complying to all timing restrictions must be implemented manually using low-level direct access to the radio?
Would you maybe have an example where something similar was done before or do you have a recommendation on how best to proceed?
Thank you in advance for any help you might be able to provide.
spuhlele
