Cause: Data bus error (return address in the stack frame is not related to the instruction that caused the error)
Dears,
I'm trying to run the mbedtls library with thread safety with the freertos, already defined MBEDTLS_THREADING_C and MBEDTLS_THREADING_ALT in the user_mbedtls_config.h, but the program runs into a crash when calling xSemaphoreTake( mutex->mutex, portMAX_DELAY ), it seems it's a concurrency issues, so I'm asking for help how to solve this problem, any suggestion is appreciated.
IDE: SES
SDK: nRF5_SDK_for_Thread_and_Zigbee_v3.1.0_c7c4730
the threading_alt.c file is:
void user_mbedtls_mutex_init( mbedtls_threading_mutex_t * mutex )
mutex->mutex = xSemaphoreCreateMutex();
if( mutex->mutex != NULL )
mutex->is_valid = 1;
mutex->is_valid = 0;
NRF_LOG_DEBUG( ( "Failed to initialize mbedTLS mutex.\r\n" ) );
NRF_LOG_FLUSH();
* @brief Implementation of mbedtls_mutex_free for thread-safety.
void user_mbedtls_mutex_free( mbedtls_threading_mutex_t * mutex )
if( mutex->is_valid == 1 )
vSemaphoreDelete( mutex->mutex );
* @brief Implementation of mbedtls_mutex_lock for thread-safety.
* @return 0 if successful, MBEDTLS_ERR_THREADING_MUTEX_ERROR if timeout,
* MBEDTLS_ERR_THREADING_BAD_INPUT_DATA if the mutex is not valid.
int user_mbedtls_mutex_lock( mbedtls_threading_mutex_t * mutex )
int ret = MBEDTLS_ERR_THREADING_BAD_INPUT_DATA;
if( xSemaphoreTake( mutex->mutex, portMAX_DELAY ) )
ret = 0;
ret = MBEDTLS_ERR_THREADING_MUTEX_ERROR;
NRF_LOG_DEBUG( ( "Failed to obtain mbedTLS mutex.\r\n" ) );
NRF_LOG_FLUSH();
return ret;
* @brief Implementation of mbedtls_mutex_unlock for thread-safety.
int user_mbedtls_mutex_unlock( mbedtls_threading_mutex_t * mutex )
if( xSemaphoreGive( mutex->mutex ) )
ret = 0;
NRF_LOG_DEBUG( ( "Failed to unlock mbedTLS mutex.\r\n" ) );
NRF_LOG_FLUSH();
return ret;
void user_mbedtls_threading_set_alt(void)
/* Configure mbedtls to use FreeRTOS mutexes. */
mbedtls_threading_set_alt( user_mbedtls_mutex_init,
user_mbedtls_mutex_free,
user_mbedtls_mutex_lock,
user_mbedtls_mutex_unlock );
the trace of the calling function is:
step 1:--->/SDK/external/mbedtls/library/ssl_cli.c --->line3273
---> int mbedtls_ssl_handshake_client_step( mbedtls_ssl_context *ssl )
case MBEDTLS_SSL_CLIENT_HELLO:
ret = ssl_write_client_hello( ssl );
step 2--->/SDK/external/mbedtls/library/ssl_cli.c --->line707
---> static int ssl_write_client_hello( mbedtls_ssl_context *ssl )
MBEDTLS_SSL_DEBUG_MSG( 3, ( "client hello, max version: [%d:%d]",
buf[4], buf[5] ) );
if( ( ret = ssl_generate_random( ssl ) ) != 0 )
MBEDTLS_SSL_DEBUG_RET( 1, "ssl_generate_random", ret );
return( ret );
step 3--->/SDK/external/mbedtls/library/ssl_cli.c --->line667
---> static int ssl_generate_random( mbedtls_ssl_context *ssl )
if( ( ret = ssl->conf->f_rng( ssl->conf->p_rng, p, 28 ) ) != 0 )
return( ret );
step 4--->/SDK/external/mbedtls/library/ctr_drbg.c --->line399
---> int mbedtls_ctr_drbg_random( void *p_rng, unsigned char *output, size_t output_len )
#if defined(MBEDTLS_THREADING_C)
if( ( ret = mbedtls_mutex_lock( &ctx->mutex ) ) != 0 )
return( ret );
step 5 -- threading_alt.c
the program stuck here and then hardfault happened, see the following log:
<error> hardfault: HARD FAULT at 0x00026DFE
<error> hardfault: R0: 0x200136D4 R1: 0x00000004 R2: 0xFFFFC2F7 R3: 0x000148B5
<error> hardfault: R12: 0x2002EF94 LR: 0x00027A1B PSR: 0x21000000
<error> hardfault: Cause: Data bus error (return address in the stack frame is not related to the instruction that caused the error).
Thanks so much if any help
  • can you keep a count on calls to xSemaphoreGive and xSemaphoreTake to see if the semaphore is given enough times for this mutex to be unlocked? What I mean to say is, could it be possible that the application is not unlocking the mutex properly?
  • I add two variable to the struct mbedtls_threading_mutex_t  for counting the take/give mutex control and update the mute_take/mutex_give function, please see the following snippet code
    typedef struct
    SemaphoreHandle_t mutex;
    char is_valid;
    uint8_t take_count;
    uint8_t give_count;
    } mbedtls_threading_mutex_t;
    * @brief Implementation of mbedtls_mutex_init for thread-safety.
    mutex->take_count = 0;
    mutex->give_count = 0;
    NRF_LOG_FLUSH();
    mutex->take_count++;
    ret = 0;
    NRF_LOG_FLUSH();
    return ret;
    mutex->give_count++;
    ret = 0;
    NRF_LOG_FLUSH();
    return ret;
    the take and give mutex count is 0, so I think it would be successful to take the mutex, BUT the program would stuck at the if statement "if( xSemaphoreTake( mutex->mutex, portMAX_DELAY ) ) " forever.
