BLE disconnect every 30sec depending of the PC since Windows update
Our BLE HID mouse devices has work well during several months and since some windows update, on some PC, the BLE is disconencted every 30 sec.
We received a BLE_GAP_EVT_DISCONNECTED from the host.
Then we re advertize and reconnect in loop.
Only at the first pairing, we have no disconnection:
We are using SDK 15.2.
No issue with Nrf Connect on an Android Smartphone
  Sebastien
  • The BLE_GAP_EVT_DISCONNECTED event has an additional status code. Which one do you get?
  • 0> <info> app: BLE_GAP_EVT_DISCONNECTED, Reason 34 (Decimal)
  • 0> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    0> <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    0> <info> app: BLE_GATTS_EVT Not Implemented ID: 26
    0> <info> nrf_ble_gatt: BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
    0> <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 527 bytes.
    0> <debug> nrf_ble_gatt: Updating ATT MTU to 32 bytes (desired: 32) on connection 0x0.
    0> <info> app: BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
    0> <info> nrf_ble_gatt: BLE_GATTC_EVT_EXCHANGE_MTU_RSP
    0> <info> nrf_ble_gatt: ATT MTU updated to 32 bytes on connection 0x0 (response).
    Reason 34 = 0x22 = BLE_HCI_STATUS_CODE_LMP_RESPONSE_TIMEOUT
    Seems to be related to an  procedure has timed-out. I have seen in the past that some peer may not handle the case where MTU exchange/DLE update is initiated on BLE_GAP_EVT_CONNECTED event. Using a delay of for instance 100ms can workaround in such case, e.g. in on_connected_evt() in nrf_ble_gatt.c add a delay like this:
            nrf_delay_ms(100); // Add a delay
            err_code = sd_ble_gattc_exchange_mtu_request(conn_handle, p_link->att_mtu_desired);
    Though, it can also be something completely different, e.g. that the peer is initiating a BLE procedure that is not handled by the mouse (e.g. an event is not replied to). E.g.  case BLE_GAP_EVT_PHY_UPDATE_REQUEST event is not handled, and adding this may help:
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
    But to be 100% sure we need an on-air sniffer log.
    Btw, what softdevice and version are you using here?
    Kenneth
    I will try what you proposed.
    We are using s140_nrf52_6.1.0_softdevice.
    Sebastien
