I found similar questions, but none that were marked as "answered".
I have a working version of "nRF5_SDK_160.0.0_98a08e2/examples/ble_peripheral/ble_app_uart". I also have a modified "nRF5_SDK_160.0.0_98a08e2/examples/peripheral/twi_sensor" that works to communicate with my TWI device. I am using Segger IDE.
I am attempting to merge the two projects into one by starting from the BLE and added the TWI components. TL;DR Why can't I merge these two projects to get a functional program?
In partial merge 1, nothing compiles with error "undefined reference to `nrf_log_backend_uart_init"
To fix this, I added more values to emProject and called it partial merge 2. Without yet attempting to communicate with the TWI board, everything compiles fine. But when I run the program, I hit "app_error_handler_gcc.c/app_error_handler(ret_code_t error_code, uint32_t line_num, const uint8_t * p_file_name) with error code 0x08.
To fix this, I added the final missing parts to the .emProject, which causes the error "'NRF_SUCCESS' undeclared (first use in this function); did you mean 'NRFX_SUCCESS'?"
Partial merge 1 means
- main.c/main.h now initializes the TWI communication as well as handle the nRF52840 UART initialization process.
- The bluetooth control has been moved to its own file
- The TWI initialization driver has been added to the "ble_app_uart" from the working "twi_sensor" example
- the .emProject File has been updated (see "ble_twi-partialMerge1.emProject.txt" since .emProject files won't load)
- The Nordic drivers are moved into their own file so that the project is kept clean (nRF_files and Segger_files)
- The missing includes from "twi_sensor" have NOT been added to "ble_app_uart"
- The sdk_config.h file has been updated with everything from both files (see "sdk_config-ble_only.h" and "sdk_config-twi_added.h")
Partial merge 2 means (same as partial 1 except...)
- .emProject (see "ble_twi-partialMerge2.emProject" since .emProject files won't load)
- Some of the missing includes from "twi_sensor" HAVE been added to "ble_app_uart"
- to "<folder Name="nRF_Drivers">"
- File <file file_name="nRF_sdk/integration/nrfx/legacy/nrf_drv_twi.c" /> is added
- File <file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_twi.c" /> is added
- File <file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_twim.c" /> is added
- to "<folder Name="nRF_Log">" the value "<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_backend_uart.c" />" is added
Complete merge means (same as partial 2, except...)
- .emProject (see "ble_twi-completeMerge.emProject" since .emProject files won't load)
- All the missing includes from "twi_sensor" HAVE been added to "ble_app_uart"
- to "configuration/c_preprocessor_definitions" the value "BSP_DEFINES_ONLY;" is added
- to "configuration/c_user_include_directories" the value "nRF_sdk/components/drivers_nrf/nrf_soc_nosd;" is added
Example Code
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include "main.h"
// @brief Function for initializing the timer module.
static void init_timers(void) {
// Create timers.
// TODO YOUR_JOB: Create any timers to be used by the application.
// Below is an example of how to create a timer.
// For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
// one.
// ret_code_t err_code;
// err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
// APP_ERROR_CHECK(err_code);
// @brief Function for handling the YYY Service events.
// TODO YOUR_JOB implement a service handler function depending on the event the service you are using can generate
// @details This function will be called for all YY Service events which are passed to
// the application.
// @param[in] p_yy_service YY Service structure.
// @param[in] p_evt Event received from the YY Service.
//static void on_yys_evt(ble_yy_service_t * p_yy_service,
// ble_yy_service_evt_t * p_evt)
// switch (p_evt->evt_type)
// case BLE_YY_NAME_EVT_WRITE:
// APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
// break;
// default:
// // No implementation needed.
// break;
// @brief Function for starting timers.
static void application_timers_start(void) {
// TODO YOUR_JOB: Start your timers. below is an example of how to start a timer.
// err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
// @brief Function for initializing buttons and leds.
// @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
static void init_buttons_leds(bool *p_erase_bonds) {
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
// @brief Function for initializing the nrf log module.
static void init_log(void) {
// @brief Function for initializing power management.
static void init_power_management(void) {
// @brief Function for handling the idle state (main loop).
// @details If there is no pending log operation, then sleep until next the next event occurs.
static void idle_state_handle(void) {
if (NRF_LOG_PROCESS() == false) {
nrf_pwr_mgmt_run();
else {
printf("NRF_LOG_PROCESS is TRUE");
// @brief Application main function.
int main(void) {
// Initialize.
initialize();
// Start execution.
advertising_start();
// Enter main loop.
for (;;) {
idle_state_handle();
// @brief Initialization
void initialize() {
// Microcontroller initialization
init_uCtrl();
// Initialize the TWI/I2C Serial Communication
init_twi();
// BLE Stack initialization
init_isp1807();
// @brief Sets the default value for the microcontroller
void init_uCtrl() {
// TODO This is never set so not sure how or why it is used.
bool erase_bonds;
// Logger initialization
init_log();
// Timer initialization
init_timers();
// Button and LED initialization (not sure if does anything)
init_buttons_leds(&erase_bonds);
// Initialize the power management
init_power_management();
// Initialize the TWI communication.
#include "twi_driver.h"
i2c_sensors current_sensor = twi_BMI160;
// Indicates if operation on TWI has ended.
volatile bool twi_xfer_done = false;
// TWI instance.
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
// TWI initialization.
void init_twi(void) {
const nrf_drv_twi_config_t twi_gi_pill_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false};
err_code = nrf_drv_twi_init(&m_twi, &twi_gi_pill_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
NRF_LOG_INFO("Initialization Complete: TWI Communication");
// TWI events handler. Called when I2C data is received.
// @details Dont put any long stuff in here. no print statements!!!
void twi_handler(nrf_drv_twi_evt_t const *p_event, void *p_context) {
switch (p_event->type) {
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX) {
if (current_sensor == twi_BMI160) { //{BMI160, LPS22HB, AD5241, MCP4017, MCP4725, LP55231};
//data_handler_bmi160(gyroAccelData); //, GA_Done);
} else if (current_sensor == twi_LPS22HB) {
//data_handler_lps22hb(m_sample,pSample,tSample,lps_RX_Type,&checked,&ready);
//LPSFLAG = 1;
LPSFLAG=1;
if(lps_RX_Type==TEMP){
printTemp(((int16_t)((int16_t)tSample[1] << 8 | tSample[0])) / 100.f);
else if(lps_RX_Type == PRESSURE){
printPressure(((int32_t)((int32_t)pSample[2] << 16 | (int32_t)pSample[1] << 8 | pSample[0])) / 4096.f);
else{}
} else if (current_sensor == twi_AD5241) {
} else if (current_sensor == twi_MCP4017) {
} else if (current_sensor == twi_MCP4725) {
} else if (current_sensor == twi_LP55231) {
} else {
//yo you shouldnt be here...
twi_xfer_done = true;
#include "ISP1807.h"
// Initialize the ISP1807 IC.
void init_isp1807() {
init_uart();
init_ble_stack();
init_gap_params();
init_gatt();
init_services();
init_advertising();
init_conn_params();
NRF_LOG_INFO("Initialization Complete: ISP1807");
NRF_LOG_FLUSH();
// @brief Function for assert macro callback.
// @details This function will be called in case of an assert in the SoftDevice.
// @warning This handler is an example only and does not fit a final product. You need to analyse
// how your product is supposed to react in case of Assert.
// @warning On assert from the SoftDevice, the system can only recover on reset.
// @param[in] line_num Line number of the failing ASSERT call.
// @param[in] p_file_name File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
app_error_handler(isp1807_dead_beef, line_num, p_file_name);
// @brief Function for the GAP initialization.
// @details This function will set up all the necessary GAP (Generic Access Profile) parameters of
// the device. It also sets the permissions and appearance.
static void init_gap_params(void) {
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)isp1807_device_name,
strlen(isp1807_device_name));
// TODO YOUR_JOB: Use an appearance value matching the application's use case.
// err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
gap_conn_params.min_conn_interval = isp1807_min_conn_interval;
gap_conn_params.max_conn_interval = isp1807_max_conn_interval;
gap_conn_params.slave_latency = isp1807_slave_latency;
gap_conn_params.conn_sup_timeout = isp1807_conn_sup_timeout;
// @brief Function for handling Queued Write Module errors.
// @details A pointer to this function will be passed to each service which may need to inform the
// application about an error.
// @param[in] nrf_error Error code containing information about what went wrong.
static void nrf_qwr_error_handler(uint32_t nrf_error) {
APP_ERROR_HANDLER(nrf_error);
// @brief Function for handling the data from the Nordic UART Service.
// @details This function will process the data received from the Nordic UART BLE Service and send
// it to the UART module.
// @param[in] p_evt Nordic UART Service event.
// @snippet [Handling the data received over BLE]
static void nus_data_handler(ble_nus_evt_t *p_evt) {
if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
do {
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') {
while (app_uart_put('\n') == NRF_ERROR_BUSY)
// @brief Function for initializing services that will be used by the application.
static void init_services(void) {
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
// @brief Function for handling an event from the Connection Parameters Module.
// @details This function will be called for all events in the Connection Parameters Module
// which are passed to the application.
// @note All this function does is to disconnect. This could have been done by simply setting
// the disconnect_on_fail config parameter, but instead we use the event handler
// mechanism to demonstrate its use.
// @param[in] p_evt Event received from the Connection Parameters Module.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
uint32_t err_code;
if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
// @brief Function for handling errors from the Connection Parameters module.
static void conn_params_error_handler(uint32_t nrf_error) {
// @brief Function for initializing the Connection Parameters module.
static void init_conn_params(void) {
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.first_conn_params_update_delay = isp1807_first_conn_params_update_delay;
cp_init.next_conn_params_update_delay = isp1807_next_conn_params_update_delay;
cp_init.max_conn_params_update_count = isp1807_max_conn_params_update_count;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// @brief Function for putting the chip into sleep mode.
// @note This function will not return.
static void sleep_mode_enter(void) {
// Prepare wakeup buttons.
// @brief Function for handling advertising events.
// @details This function will be called for advertising events which are passed to the application.
// @param[in] ble_adv_evt Advertising event.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
uint32_t err_code;
switch (ble_adv_evt) {
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
// @brief Function for handling BLE events.
// @param[in] p_ble_evt Bluetooth stack event.
// @param[in] p_context Unused.
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
uint32_t err_code;
switch (p_ble_evt->header.evt_id) {
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GAP_EVT_SCAN_REQ_REPORT:
// printf("\n\n\rBLE_GAP_EVT_SCAN_REQ_REPORT");
// ble_gap_evt_scan_req_report_t *p_scan_req_report_t = (ble_gap_evt_scan_req_report_t *)&p_ble_evt->evt.gap_evt.params.scan_req_report;
// printf("\n\rPeer Address = 0x%02x:%02x:%02x:%02x:%02x:%02x",
// p_scan_req_report_t->peer_addr.addr[5],
// p_scan_req_report_t->peer_addr.addr[4],
// p_scan_req_report_t->peer_addr.addr[3],
// p_scan_req_report_t->peer_addr.addr[2],
// p_scan_req_report_t->peer_addr.addr[1],
// p_scan_req_report_t->peer_addr.addr[0]);
// printf("\n\rRSSI value = %d dBm", p_scan_req_report_t->rssi);
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// @brief Function for the SoftDevice initialization.
// @details This function initializes the SoftDevice and the BLE event interrupt.
static void init_ble_stack(void) {
uint32_t ram_start = 0;
err_code = nrf_sdh_ble_default_cfg_set(isp1807_app_ble_conn_cfg_tag, &ram_start);
// Enable BLE stack.
NRF_SDH_BLE_OBSERVER(m_ble_observer, isp1807_app_ble_observer_prio, ble_evt_handler, NULL);
// @brief Function for handling events from the GATT library.
void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
// @brief Function for initializing the GATT library.
void init_gatt(void) {
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
// @brief Function for handling events from the BSP module.
// @param[in] event Event generated by button press.
void bsp_event_handler(bsp_event_t event) {
uint32_t err_code;
switch (event) {
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
if (err_code != NRF_ERROR_INVALID_STATE) {
case BSP_EVENT_WHITELIST_OFF:
if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
// @brief Function for handling app_uart events.
// @details This function will receive a single character from the app_uart module and append it to
// a string. The string will be be sent over BLE when the last character received was a
// 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
// @snippet [Handling the data received over UART]
void uart_event_handle(app_uart_evt_t *p_event) {
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type) {
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len)) {
if (index > 1) {
//uint8_t ed = sample_energyDetection();
//printf("Energy Detection = %d", ed);
do {
(err_code != NRF_ERROR_NOT_FOUND)) {
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
// end uart_event_handle()
// @brief Function for initializing the UART module.
// @snippet [UART Initialization] */
static void init_uart(void) {
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
#if defined(UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
isp1807_uart_rx_buf_size,
isp1807_uart_tx_buf_size,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
// @brief Function for initializing the Advertising functionality.
static void init_advertising(void) {
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = isp1807_app_adv_interval;
init.config.ble_adv_fast_timeout = isp1807_app_adv_duration;
ble_advertising_conn_cfg_tag_set(&m_advertising, isp1807_app_ble_conn_cfg_tag);
// @brief Function for starting advertising.
void advertising_start(void) {
sdk_config-TWI_added.hsdk_config-BLE_only.h
<!DOCTYPE CrossStudio_Project_File>
<solution Name="ble_app_uart_pca10056_s140" target="8" version="2">
<project Name="ble_app_uart_pca10056_s140">
<configuration
Name="Common"
arm_architecture="v7EM"
arm_core_type="Cortex-M4"
arm_endian="Little"
arm_fp_abi="Hard"
arm_fpu_type="FPv4-SP-D16"
arm_linker_heap_size="8192"
arm_linker_process_stack_size="0"
arm_linker_stack_size="8192"
arm_linker_treat_warnings_as_errors="No"
arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
arm_target_device_name="nRF52840_xxAA"
arm_target_interface_type="SWD"
c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10056;BSP_DEFINES_ONLY;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;"
c_user_include_directories="nRF_sdk/components;nRF_sdk/components/ble/ble_advertising;nRF_sdk/components/ble/ble_dtm;nRF_sdk/components/ble/ble_link_ctx_manager;nRF_sdk/components/ble/ble_racp;nRF_sdk/components/ble/ble_services/ble_ancs_c;nRF_sdk/components/ble/ble_services/ble_ans_c;nRF_sdk/components/ble/ble_services/ble_bas;nRF_sdk/components/ble/ble_services/ble_bas_c;nRF_sdk/components/ble/ble_services/ble_cscs;nRF_sdk/components/ble/ble_services/ble_cts_c;nRF_sdk/components/ble/ble_services/ble_dfu;nRF_sdk/components/ble/ble_services/ble_dis;nRF_sdk/components/ble/ble_services/ble_gls;nRF_sdk/components/ble/ble_services/ble_hids;nRF_sdk/components/ble/ble_services/ble_hrs;nRF_sdk/components/ble/ble_services/ble_hrs_c;nRF_sdk/components/ble/ble_services/ble_hts;nRF_sdk/components/ble/ble_services/ble_ias;nRF_sdk/components/ble/ble_services/ble_ias_c;nRF_sdk/components/ble/ble_services/ble_lbs;nRF_sdk/components/ble/ble_services/ble_lbs_c;nRF_sdk/components/ble/ble_services/ble_lls;nRF_sdk/components/ble/ble_services/ble_nus;nRF_sdk/components/ble/ble_services/ble_nus_c;nRF_sdk/components/ble/ble_services/ble_rscs;nRF_sdk/components/ble/ble_services/ble_rscs_c;nRF_sdk/components/ble/ble_services/ble_tps;nRF_sdk/components/ble/common;nRF_sdk/components/ble/nrf_ble_gatt;nRF_sdk/components/ble/nrf_ble_qwr;nRF_sdk/components/ble/peer_manager;nRF_sdk/components/boards;nRF_sdk/components/drivers_nrf/nrf_soc_nosd;nRF_sdk/components/libraries/atomic;nRF_sdk/components/libraries/atomic_fifo;nRF_sdk/components/libraries/atomic_flags;nRF_sdk/components/libraries/balloc;nRF_sdk/components/libraries/bootloader/ble_dfu;nRF_sdk/components/libraries/bsp;nRF_sdk/components/libraries/button;nRF_sdk/components/libraries/cli;nRF_sdk/components/libraries/crc16;nRF_sdk/components/libraries/crc32;nRF_sdk/components/libraries/crypto;nRF_sdk/components/libraries/csense;nRF_sdk/components/libraries/csense_drv;nRF_sdk/components/libraries/delay;nRF_sdk/components/libraries/ecc;nRF_sdk/components/libraries/experimental_section_vars;nRF_sdk/components/libraries/experimental_task_manager;nRF_sdk/components/libraries/fds;nRF_sdk/components/libraries/fifo;nRF_sdk/components/libraries/fstorage;nRF_sdk/components/libraries/gfx;nRF_sdk/components/libraries/gpiote;nRF_sdk/components/libraries/hardfault;nRF_sdk/components/libraries/hci;nRF_sdk/components/libraries/led_softblink;nRF_sdk/components/libraries/log;nRF_sdk/components/libraries/log/src;nRF_sdk/components/libraries/low_power_pwm;nRF_sdk/components/libraries/mem_manager;nRF_sdk/components/libraries/memobj;nRF_sdk/components/libraries/mpu;nRF_sdk/components/libraries/mutex;nRF_sdk/components/libraries/pwm;nRF_sdk/components/libraries/pwr_mgmt;nRF_sdk/components/libraries/queue;nRF_sdk/components/libraries/ringbuf;nRF_sdk/components/libraries/scheduler;nRF_sdk/components/libraries/sdcard;nRF_sdk/components/libraries/slip;nRF_sdk/components/libraries/sortlist;nRF_sdk/components/libraries/spi_mngr;nRF_sdk/components/libraries/stack_guard;nRF_sdk/components/libraries/strerror;nRF_sdk/components/libraries/svc;nRF_sdk/components/libraries/timer;nRF_sdk/components/libraries/twi_mngr;nRF_sdk/components/libraries/twi_sensor;nRF_sdk/components/libraries/uart;nRF_sdk/components/libraries/usbd;nRF_sdk/components/libraries/usbd/class/audio;nRF_sdk/components/libraries/usbd/class/cdc;nRF_sdk/components/libraries/usbd/class/cdc/acm;nRF_sdk/components/libraries/usbd/class/hid;nRF_sdk/components/libraries/usbd/class/hid/generic;nRF_sdk/components/libraries/usbd/class/hid/kbd;nRF_sdk/components/libraries/usbd/class/hid/mouse;nRF_sdk/components/libraries/usbd/class/msc;nRF_sdk/components/libraries/util;nRF_sdk/components/nfc/ndef/conn_hand_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/ac_rec_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;nRF_sdk/components/nfc/ndef/connection_handover/ac_rec;nRF_sdk/components/nfc/ndef/connection_handover/ble_oob_advdata;nRF_sdk/components/nfc/ndef/connection_handover/ble_pair_lib;nRF_sdk/components/nfc/ndef/connection_handover/ble_pair_msg;nRF_sdk/components/nfc/ndef/connection_handover/common;nRF_sdk/components/nfc/ndef/connection_handover/ep_oob_rec;nRF_sdk/components/nfc/ndef/connection_handover/hs_rec;nRF_sdk/components/nfc/ndef/connection_handover/le_oob_rec;nRF_sdk/components/nfc/ndef/generic/message;nRF_sdk/components/nfc/ndef/generic/record;nRF_sdk/components/nfc/ndef/launchapp;nRF_sdk/components/nfc/ndef/parser/message;nRF_sdk/components/nfc/ndef/parser/record;nRF_sdk/components/nfc/ndef/text;nRF_sdk/components/nfc/ndef/uri;nRF_sdk/components/nfc/platform;nRF_sdk/components/nfc/t2t_lib;nRF_sdk/components/nfc/t2t_parser;nRF_sdk/components/nfc/t4t_lib;nRF_sdk/components/nfc/t4t_parser/apdu;nRF_sdk/components/nfc/t4t_parser/cc_file;nRF_sdk/components/nfc/t4t_parser/hl_detection_procedure;nRF_sdk/components/nfc/t4t_parser/tlv;nRF_sdk/components/softdevice/common;nRF_sdk/components/softdevice/s140/headers;nRF_sdk/components/softdevice/s140/headers/nrf52;nRF_sdk/components/toolchain/cmsis/include;nRF_sdk/external/fprintf;nRF_sdk/external/segger_rtt;nRF_sdk/external/utf_converter;nRF_sdk/integration/nrfx;nRF_sdk/integration/nrfx/legacy;nRF_sdk/modules/nrfx;nRF_sdk/modules/nrfx/drivers/include;nRF_sdk/modules/nrfx/hal;nRF_sdk/modules/nrfx/mdk;nRF_sdk/sdk_config;"
debug_additional_load_file="nRF_sdk/components/softdevice/s140/hex/s140_nrf52_7.0.1_softdevice.hex"
debug_register_definition_file="nRF_sdk/modules/nrfx/mdk/nrf52840.svd"
debug_start_from_entry_point_symbol="No"
debug_target_connection="J-Link"
gcc_debugging_level="Level 3"
gcc_entry_point="Reset_Handler"
linker_output_format="hex"
linker_printf_fmt_level="long"
linker_printf_width_precision_supported="Yes"
linker_scanf_fmt_level="long"
linker_section_placement_file="flash_placement.xml"
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x27000;FLASH_SIZE=0xd9000;RAM_START=0x20002ae8;RAM_SIZE=0x3d518"
linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000"
macros="CMSIS_CONFIG_TOOL=nRF_sdk/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
project_directory=""
project_type="Executable" />
<folder Name="Application">
<file file_name="src/main.c" />
<file file_name="src/main.h" />
<file file_name="nRF_sdk/sdk_config/sdk_config.h" />
<folder Name="BLE_Driver">
<file file_name="src/BLE_Driver/ISP1807.h" />
<file file_name="src/BLE_Driver/ISP1807.c" />
</folder>
<folder Name="TWI_Driver">
<file file_name="src/TWI_Driver/twi_driver.h" />
<file file_name="src/TWI_Driver/twi_driver.c" />
</folder>
</folder>
<folder Name="nRF_Files">
<folder Name="BLE">
<folder Name="nRF_BLE">
<file file_name="nRF_sdk/components/ble/common/ble_advdata.c" />
<file file_name="nRF_sdk/components/ble/ble_advertising/ble_advertising.c" />
<file file_name="nRF_sdk/components/ble/common/ble_conn_params.c" />
<file file_name="nRF_sdk/components/ble/common/ble_conn_state.c" />
<file file_name="nRF_sdk/components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c" />
<file file_name="nRF_sdk/components/ble/common/ble_srv_common.c" />
<file file_name="nRF_sdk/components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
<file file_name="nRF_sdk/components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
</folder>
<folder Name="nRF_BLE_Services">
<file file_name="nRF_sdk/components/ble/ble_services/ble_nus/ble_nus.c" />
</folder>
<folder Name="nRF_SoftDevice">
<file file_name="nRF_sdk/components/softdevice/common/nrf_sdh.c" />
<file file_name="nRF_sdk/components/softdevice/common/nrf_sdh_ble.c" />
<file file_name="nRF_sdk/components/softdevice/common/nrf_sdh_soc.c" />
</folder>
</folder>
<file file_name="nRF_sdk/integration/nrfx/legacy/nrf_drv_clock.c" />
<file file_name="nRF_sdk/integration/nrfx/legacy/nrf_drv_uart.c" />
<file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_clock.c" />
<file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_gpiote.c" />
<file file_name="nRF_sdk/modules/nrfx/drivers/src/prs/nrfx_prs.c" />
<file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_uart.c" />
<file file_name="nRF_sdk/modules/nrfx/drivers/src/nrfx_uarte.c" />
<file file_name="nRF_sdk/modules/nrfx/soc/nrfx_atomic.c" />
</folder>
<folder Name="nRF_Libraries">
<file file_name="nRF_sdk/components/libraries/button/app_button.c" />
<file file_name="nRF_sdk/components/libraries/util/app_error.c" />
<file file_name="nRF_sdk/components/libraries/util/app_error_handler_gcc.c" />
<file file_name="nRF_sdk/components/libraries/util/app_error_weak.c" />
<file file_name="nRF_sdk/components/libraries/fifo/app_fifo.c" />
<file file_name="nRF_sdk/components/libraries/scheduler/app_scheduler.c" />
<file file_name="nRF_sdk/components/libraries/timer/app_timer2.c" />
<file file_name="nRF_sdk/components/libraries/uart/app_uart_fifo.c" />
<file file_name="nRF_sdk/components/libraries/util/app_util_platform.c" />
<file file_name="nRF_sdk/components/libraries/timer/drv_rtc.c" />
<file file_name="nRF_sdk/components/libraries/hardfault/hardfault_implementation.c" />
<file file_name="nRF_sdk/components/libraries/util/nrf_assert.c" />
<file file_name="nRF_sdk/components/libraries/atomic_fifo/nrf_atfifo.c" />
<file file_name="nRF_sdk/components/libraries/atomic_flags/nrf_atflags.c" />
<file file_name="nRF_sdk/components/libraries/atomic/nrf_atomic.c" />
<file file_name="nRF_sdk/components/libraries/balloc/nrf_balloc.c" />
<file file_name="nRF_sdk/external/fprintf/nrf_fprintf.c" />
<file file_name="nRF_sdk/external/fprintf/nrf_fprintf_format.c" />
<file file_name="nRF_sdk/components/libraries/memobj/nrf_memobj.c" />
<file file_name="nRF_sdk/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
<file file_name="nRF_sdk/components/libraries/ringbuf/nrf_ringbuf.c" />
<file file_name="nRF_sdk/components/libraries/experimental_section_vars/nrf_section_iter.c" />
<file file_name="nRF_sdk/components/libraries/sortlist/nrf_sortlist.c" />
<file file_name="nRF_sdk/components/libraries/strerror/nrf_strerror.c" />
<file file_name="nRF_sdk/components/libraries/uart/retarget.c" />
</folder>
<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_backend_rtt.c" />
<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_backend_serial.c" />
<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_default_backends.c" />
<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_frontend.c" />
<file file_name="nRF_sdk/components/libraries/log/src/nrf_log_str_formatter.c" />
</folder>
<folder Name="nRF_Segger_RTT">
<file file_name="nRF_sdk/external/segger_rtt/SEGGER_RTT.c" />
<file file_name="nRF_sdk/external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
<file file_name="nRF_sdk/external/segger_rtt/SEGGER_RTT_printf.c" />
</folder>
<folder Name="UTF8/UTF16 converter">
<file file_name="nRF_sdk/external/utf_converter/utf.c" />
</folder>
</folder>
<folder Name="Segger_Files">
<folder Name="Board Definition">
<file file_name="nRF_sdk/components/boards/boards.c" />
</folder>
<folder Name="Board Support">
<file file_name="nRF_sdk/components/libraries/bsp/bsp.c" />
<file file_name="nRF_sdk/components/libraries/bsp/bsp_btn_ble.c" />
</folder>
<folder Name="None">
<file file_name="nRF_sdk/modules/nrfx/mdk/ses_startup_nrf52840.s" />
<file file_name="nRF_sdk/modules/nrfx/mdk/ses_startup_nrf_common.s" />
<file file_name="nRF_sdk/modules/nrfx/mdk/system_nrf52840.c" />
</folder>
<folder Name="Segger Startup Files">
<file file_name="$(StudioDir)/source/thumb_crt0.s" />
</folder>
</folder>
<configuration Name="Debug" linker_printf_fp_enabled="Float" />
</project>
<configuration
Name="Release"
c_preprocessor_definitions="NDEBUG"
gcc_optimization_level="Optimize For Size" />
<configuration
Name="Debug"
c_preprocessor_definitions="DEBUG; DEBUG_NRF"
gcc_optimization_level="None" />
</solution>
<configuration
Name="Common"
arm_endian="Little"
arm_fp_abi="Hard"
c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10056;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;"
c_user_include_directories="nRF_sdk/components;nRF_sdk/components/ble/ble_advertising;nRF_sdk/components/ble/ble_dtm;nRF_sdk/components/ble/ble_link_ctx_manager;nRF_sdk/components/ble/ble_racp;nRF_sdk/components/ble/ble_services/ble_ancs_c;nRF_sdk/components/ble/ble_services/ble_ans_c;nRF_sdk/components/ble/ble_services/ble_bas;nRF_sdk/components/ble/ble_services/ble_bas_c;nRF_sdk/components/ble/ble_services/ble_cscs;nRF_sdk/components/ble/ble_services/ble_cts_c;nRF_sdk/components/ble/ble_services/ble_dfu;nRF_sdk/components/ble/ble_services/ble_dis;nRF_sdk/components/ble/ble_services/ble_gls;nRF_sdk/components/ble/ble_services/ble_hids;nRF_sdk/components/ble/ble_services/ble_hrs;nRF_sdk/components/ble/ble_services/ble_hrs_c;nRF_sdk/components/ble/ble_services/ble_hts;nRF_sdk/components/ble/ble_services/ble_ias;nRF_sdk/components/ble/ble_services/ble_ias_c;nRF_sdk/components/ble/ble_services/ble_lbs;nRF_sdk/components/ble/ble_services/ble_lbs_c;nRF_sdk/components/ble/ble_services/ble_lls;nRF_sdk/components/ble/ble_services/ble_nus;nRF_sdk/components/ble/ble_services/ble_nus_c;nRF_sdk/components/ble/ble_services/ble_rscs;nRF_sdk/components/ble/ble_services/ble_rscs_c;nRF_sdk/components/ble/ble_services/ble_tps;nRF_sdk/components/ble/common;nRF_sdk/components/ble/nrf_ble_gatt;nRF_sdk/components/ble/nrf_ble_qwr;nRF_sdk/components/ble/peer_manager;nRF_sdk/components/boards;nRF_sdk/components/libraries/atomic;nRF_sdk/components/libraries/atomic_fifo;nRF_sdk/components/libraries/atomic_flags;nRF_sdk/components/libraries/balloc;nRF_sdk/components/libraries/bootloader/ble_dfu;nRF_sdk/components/libraries/bsp;nRF_sdk/components/libraries/button;nRF_sdk/components/libraries/cli;nRF_sdk/components/libraries/crc16;nRF_sdk/components/libraries/crc32;nRF_sdk/components/libraries/crypto;nRF_sdk/components/libraries/csense;nRF_sdk/components/libraries/csense_drv;nRF_sdk/components/libraries/delay;nRF_sdk/components/libraries/ecc;nRF_sdk/components/libraries/experimental_section_vars;nRF_sdk/components/libraries/experimental_task_manager;nRF_sdk/components/libraries/fds;nRF_sdk/components/libraries/fifo;nRF_sdk/components/libraries/fstorage;nRF_sdk/components/libraries/gfx;nRF_sdk/components/libraries/gpiote;nRF_sdk/components/libraries/hardfault;nRF_sdk/components/libraries/hci;nRF_sdk/components/libraries/led_softblink;nRF_sdk/components/libraries/log;nRF_sdk/components/libraries/log/src;nRF_sdk/components/libraries/low_power_pwm;nRF_sdk/components/libraries/mem_manager;nRF_sdk/components/libraries/memobj;nRF_sdk/components/libraries/mpu;nRF_sdk/components/libraries/mutex;nRF_sdk/components/libraries/pwm;nRF_sdk/components/libraries/pwr_mgmt;nRF_sdk/components/libraries/queue;nRF_sdk/components/libraries/ringbuf;nRF_sdk/components/libraries/scheduler;nRF_sdk/components/libraries/sdcard;nRF_sdk/components/libraries/slip;nRF_sdk/components/libraries/sortlist;nRF_sdk/components/libraries/spi_mngr;nRF_sdk/components/libraries/stack_guard;nRF_sdk/components/libraries/strerror;nRF_sdk/components/libraries/svc;nRF_sdk/components/libraries/timer;nRF_sdk/components/libraries/twi_mngr;nRF_sdk/components/libraries/twi_sensor;nRF_sdk/components/libraries/uart;nRF_sdk/components/libraries/usbd;nRF_sdk/components/libraries/usbd/class/audio;nRF_sdk/components/libraries/usbd/class/cdc;nRF_sdk/components/libraries/usbd/class/cdc/acm;nRF_sdk/components/libraries/usbd/class/hid;nRF_sdk/components/libraries/usbd/class/hid/generic;nRF_sdk/components/libraries/usbd/class/hid/kbd;nRF_sdk/components/libraries/usbd/class/hid/mouse;nRF_sdk/components/libraries/usbd/class/msc;nRF_sdk/components/libraries/util;nRF_sdk/components/nfc/ndef/conn_hand_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/ac_rec_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;nRF_sdk/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;nRF_sdk/components/nfc/ndef/connection_handover/ac_rec;nRF_sdk/components/nfc/ndef/connection_handover/ble_oob_advdata;nRF_sdk/components/nfc/ndef/connection_handover/ble_pair_lib;nRF_sdk/components/nfc/ndef/connection_handover/ble_pair_msg;nRF_sdk/components/nfc/ndef/connection_handover/common;nRF_sdk/components/nfc/ndef/connection_handover/ep_oob_rec;nRF_sdk/components/nfc/ndef/connection_handover/hs_rec;nRF_sdk/components/nfc/ndef/connection_handover/le_oob_rec;nRF_sdk/components/nfc/ndef/generic/message;nRF_sdk/components/nfc/ndef/generic/record;nRF_sdk/components/nfc/ndef/launchapp;nRF_sdk/components/nfc/ndef/parser/message;nRF_sdk/components/nfc/ndef/parser/record;nRF_sdk/components/nfc/ndef/text;nRF_sdk/components/nfc/ndef/uri;nRF_sdk/components/nfc/platform;nRF_sdk/components/nfc/t2t_lib;nRF_sdk/components/nfc/t2t_parser;nRF_sdk/components/nfc/t4t_lib;nRF_sdk/components/nfc/t4t_parser/apdu;nRF_sdk/components/nfc/t4t_parser/cc_file;nRF_sdk/components/nfc/t4t_parser/hl_detection_procedure;nRF_sdk/components/nfc/t4t_parser/tlv;nRF_sdk/components/softdevice/common;nRF_sdk/components/softdevice/s140/headers;nRF_sdk/components/softdevice/s140/headers/nrf52;nRF_sdk/components/toolchain/cmsis/include;nRF_sdk/external/fprintf;nRF_sdk/external/segger_rtt;nRF_sdk/external/utf_converter;nRF_sdk/integration/nrfx;nRF_sdk/integration/nrfx/legacy;nRF_sdk/modules/nrfx;nRF_sdk/modules/nrfx/drivers/include;nRF_sdk/modules/nrfx/hal;nRF_sdk/modules/nrfx/mdk;nRF_sdk/sdk_config;"
</folder>
</folder>
</folder>
<folder Name="BLE">
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</project>
<configuration
Name="Release"
<configuration
Name="Debug"
</solution>
<configuration
Name="Common"
arm_endian="Little"
arm_fp_abi="Hard"
</folder>
</folder>
</folder>
<folder Name="BLE">
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</folder>
</project>
<configuration
Name="Release"
<configuration
Name="Debug"
</solution>
