HI
How stable is the serial_uartesexample in nRF5? I'm running it on a PCA10056, the example works for about 5 seconds and then UART RX stops, i.e. nothing is received after that point.
Thank you.
Pete.
HI
Thank you.
Pete.
Also, some more info. Long story short this came about from me adding serial_uartes to the FreeRTOS blinky and running into these issues there. I have a GPS unit on 9600 baud connected to the problem UART. So I changed over to the standard serial_uartes example, changed the baud rate and pins to what I am using (and on the same hardware) and see the same issue.
So this is basically what I changed in the serial_uartes example:
#define U2RX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,14)
#define U2TX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,16)
#define URX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,11)
#define UTX_PIN_NUMBER NRF_GPIO_PIN_MAP(0,13)
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
URX_PIN_NUMBER, UTX_PIN_NUMBER,
RTS_PIN_NUMBER, CTS_PIN_NUMBER,
NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
NRF_UART_BAUDRATE_9600,
UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
U2RX_PIN_NUMBER, U2TX_PIN_NUMBER,
NRF_UART_BAUDRATE_115200,
Also interestingly nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0); seems to only work if single characters are received, i.e. when changing to something like this it never receives anything:
char buffer[32]; size_t count_read; nrf_serial_write(&serial0_uarte, buffer, sizeof(buffer), &count_read, 0);
So I have 2 issues:
1. After receiving a number of characters from the GPS (and echoing these on the TX of the same UART to a PC) receive stops completely and nothing more is received.
2. nrf_serial_write can only receive one character at a time, anything more and it doesn't work at all.
Thank you...
Part of the problem here is that nrf_serial doesn't handle errors gracefully, e.g. you need to uninit() and init() again if there are any errors. Instead I recommend to check out:
https://infocenter.nordicsemi.com/topic/sdk_nrf5_v16.0.0/lib_libuarte.html
Kenneth
HI Kenneth
Thank you for your reply. Does lib_libuarte support 2 UARTs?
Best Regards
Pete.
HI Kenneth
I have tried the lib_libuarte example. Seems if there is already data on the RX pin when it starts up, it crashes. If the data (GPS) is connected later it works.
I really like the nRF52840 and the Nordic range, but if it is this hard just to get a UART working, it will be a nightmare to use it on a real product with a deadline. I'm finding it hard to move beyond anything that requires more than is in one of the examples. I would love to use one of these devices in a product, but I can't see how.
Best Regards
Pete.
I am not aware of any issue with lib_libuarte, I tried pulling RXD pin low during init or random time, but the program kept on running when pin was released. Have you added some assert or similar in uart_event_handler() when there is an NRF_LIBUARTE_ASYNC_EVT_ERROR event?
Kenneth
