How to define four different 128 bit uuid service characteristic? write and read operations on 128 bit uuid
please give me some examples operations on 128bit uuid in python
I posted the instructions for adding and writing 128-bit UUIDs in pc-ble-driver-py a couple of years ago. The examples may have changed a bit since then, but the principle should be the same.
Jørgen
I tried as per your suggestions but i got error
pc_ble_driver_py.exceptions.NordicSemiException: CCCD not found
I defined as
ACtual 128 bit UUID is :
0x80, 0x82, 0xca, 0xa8, 0x41, 0xa6, 0x40, 0x21, 0x91, 0xc6, 0x56, 0xf9, 0xb9, 0x54, 0xcc, 0x34]
SUOTA_MEMD_UUID = BLEUUIDBase(
[0x80, 0x82, 0x00, 0x00, 0x41, 0xa6, 0x40, 0x21, 0x91, 0xc6, 0x56, 0xf9, 0xb9, 0x54, 0xcc, 0x34])
NUS_SUOTA_MEMD_UUID = BLEUUID(0xcaa8, SUOTA_MEMD_UUID)
and added as
self.adapter.driver.ble_vs_uuid_add(SUOTA_MEMD_UUID) in open function
self.adapter.enable_notification(conn_handle = new_conn, uuid = NUS_SUOTA_MEMD_UUID)
in
def connect_and_discover(self)
i got error CCCD not found This char is only Read and write attributes only
please support how to read and write operations on ACtual 128 bit UUID .
Attached an NUS example that works with the latest version of pc-ble-driver-py, that both supports both notifications for TX and also writes for RX.
# Copyright (c) 2016 Nordic Semiconductor ASA
# All rights reserved.
# Redistribution and use in source and binary forms, with or without modification,
# are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice, this
# list of conditions and the following disclaimer in the documentation and/or
# other materials provided with the distribution.
# 3. Neither the name of Nordic Semiconductor ASA nor the names of other
# contributors to this software may be used to endorse or promote products
# derived from this software without specific prior written permission.
# 4. This software must only be used in or with a processor manufactured by Nordic
# Semiconductor ASA, or in or with a processor manufactured by a third party that
# is used in combination with a processor manufactured by Nordic Semiconductor.
# 5. Any software provided in binary or object form under this license must not be
# reverse engineered, decompiled, modified and/or disassembled.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
# ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
# ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import sys
import time
import logging
from queue import Queue, Empty
from pc_ble_driver_py.observers import *
global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEUUIDBase, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
from pc_ble_driver_py import config
config.__conn_ic_id__ = "NRF52"
# noinspection PyUnresolvedReferences
from pc_ble_driver_py.ble_driver import (
BLEDriver,
BLEAdvData,
BLEEvtID,
BLEEnableParams,
BLEGapTimeoutSrc,
BLEUUID,
BLEUUIDBase,
BLEGapScanParams,
BLEConfigCommon,
BLEConfig,
BLEConfigConnGatt,
from pc_ble_driver_py.ble_adapter import BLEAdapter
global nrf_sd_ble_api_ver
nrf_sd_ble_api_ver = config.sd_api_ver_get()
TARGET_DEV_NAME = "Nordic_UART"
CONNECTIONS = 1
CFG_TAG = 1
def init(conn_ic_id):
# noinspection PyGlobalUndefined
config.__conn_ic_id__ = conn_ic_id
BLEDriver,
BLEAdvData,
BLEEvtID,
BLEEnableParams,
BLEGapTimeoutSrc,
BLEUUID,
BLEUUIDBase,
BLEGapScanParams,
BLEConfigCommon,
BLEConfig,
BLEConfigConnGatt,
class HRCollector(BLEDriverObserver, BLEAdapterObserver):
NUS_BASE_UUID = BLEUUIDBase([0x6E, 0x40, 0x00, 0x00, 0xB5, 0xA3, 0xF3, 0x93,
0xE0, 0xA9, 0xE5, 0x0E, 0x24, 0xDC, 0xCA, 0x9E], 0x02) # 0x02 is the type BLE_UUID_TYPE_VENDOR_BEGIN
NUS_RX_UUID = BLEUUID(0x0002, NUS_BASE_UUID)
NUS_TX_UUID = BLEUUID(0x0003, NUS_BASE_UUID)
def __init__(self, adapter):
super(HRCollector, self).__init__()
self.adapter = adapter
self.conn_q = Queue()
self.adapter.observer_register(self)
self.adapter.driver.observer_register(self)
self.adapter.default_mtu = 250
def open(self):
self.adapter.driver.open()
if config.__conn_ic_id__ == "NRF51":
self.adapter.driver.ble_enable(
BLEEnableParams(
vs_uuid_count=10,
service_changed=0,
periph_conn_count=0,
central_conn_count=1,
central_sec_count=0,
elif config.__conn_ic_id__ == "NRF52":
gatt_cfg = BLEConfigConnGatt()
gatt_cfg.att_mtu = self.adapter.default_mtu
gatt_cfg.tag = CFG_TAG
self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
self.adapter.driver.ble_enable()
self.adapter.driver.ble_vs_uuid_add(HRCollector.NUS_BASE_UUID)
def close(self):
self.adapter.driver.close()
def connect_and_discover(self):
scan_duration = 180
params = BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=scan_duration)
self.adapter.driver.ble_gap_scan_start(scan_params=params)
try:
new_conn = self.conn_q.get(timeout=scan_duration)
self.adapter.service_discovery(new_conn)
self.adapter.enable_notification(new_conn, HRCollector.NUS_TX_UUID)
return new_conn
except Empty:
print(f"No heart rate collector advertising with name {TARGET_DEV_NAME} found.")
return None
def on_gap_evt_connected(
self, ble_driver, conn_handle, peer_addr, role, conn_params
print("New connection: {}".format(conn_handle))
self.conn_q.put(conn_handle)
def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
print("Disconnected: {} {}".format(conn_handle, reason))
def on_gap_evt_adv_report(
self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
if BLEAdvData.Types.complete_local_name in adv_data.records:
dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
elif BLEAdvData.Types.short_local_name in adv_data.records:
dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
else:
return
dev_name = "".join(chr(e) for e in dev_name_list)
address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
print(
"Received advertisment report, address: 0x{}, device_name: {}".format(
address_string, dev_name
if dev_name == TARGET_DEV_NAME:
self.adapter.connect(peer_addr, tag=CFG_TAG)
def on_notification(self, ble_adapter, conn_handle, uuid, data):
if len(data) > 32:
data = "({}...)".format(data[0:10])
print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
print("NUS_RX: " + ''.join(map(chr,data)))
def main(selected_serial_port):
print("Serial port used: {}".format(selected_serial_port))
driver = BLEDriver(
serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
adapter = BLEAdapter(driver)
collector = HRCollector(adapter)
collector.open()
conn = collector.connect_and_discover()
if conn is not None:
#time.sleep(1000)
while True:
nus_string = input("NUS string: ").encode()
adapter.write_req(conn, HRCollector.NUS_RX_UUID, nus_string + b'\n')
collector.close()
def item_choose(item_list):
for i, it in enumerate(item_list):
print("\t{} : {}".format(i, it))
print(" ")
while True:
try:
choice = int(input("Enter your choice: "))
if (choice >= 0) and (choice < len(item_list)):
break
except Exception:
pass
print("\tTry again...")
return choice
if __name__ == "__main__":
logging.basicConfig(
level="DEBUG",
format="%(asctime)s [%(thread)d/%(threadName)s] %(message)s",
serial_port = None
if len(sys.argv) < 2:
print("Please specify connectivity IC identifier (NRF51, NRF52)")
exit(1)
init(sys.argv[1])
if len(sys.argv) == 3:
serial_port = sys.argv[2]
else:
descs = BLEDriver.enum_serial_ports()
choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
choice = item_choose(choices)
serial_port = descs[choice].port
main(serial_port)
quit()
Jørgen
Hi Jørgen
how to discovery 128bit custom characteristic UUID?
Please post your question in a new ticket.
