QSPI CINSTR Command Read Multiple Bytes
I am trying to read the SFDP (Serial Flash Discovery Parameter) register of a Micron NOR flash memory using nRF52840 QSPI peripheral. The read SFDP register op code is 0x5A, which I send using the CINSTR command. However, the number of bytes in the register is 128. From my understanding, the maximum number of bytes that could be read back using a CINSTR command is 8 bytes. The values are given in this enum:
typedef enum
    NRF_QSPI_CINSTR_LEN_1B = QSPI_CINSTRCONF_LENGTH_1B, /**< Send opcode only. value = 0*/
    NRF_QSPI_CINSTR_LEN_2B = QSPI_CINSTRCONF_LENGTH_2B, /**< Send opcode, CINSTRDAT0.BYTE0. value = 1*/
    NRF_QSPI_CINSTR_LEN_3B = QSPI_CINSTRCONF_LENGTH_3B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT0.BYTE1. value = 2*/
    NRF_QSPI_CINSTR_LEN_4B = QSPI_CINSTRCONF_LENGTH_4B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT0.BYTE2. value = 3*/
    NRF_QSPI_CINSTR_LEN_5B = QSPI_CINSTRCONF_LENGTH_5B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT0.BYTE3. value = 4*/
    NRF_QSPI_CINSTR_LEN_6B = QSPI_CINSTRCONF_LENGTH_6B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT1.BYTE4. value = 5*/
    NRF_QSPI_CINSTR_LEN_7B = QSPI_CINSTRCONF_LENGTH_7B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT1.BYTE5. value = 6*/
    NRF_QSPI_CINSTR_LEN_8B = QSPI_CINSTRCONF_LENGTH_8B, /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT1.BYTE6. value = 7*/
    NRF_QSPI_CINSTR_LEN_9B = QSPI_CINSTRCONF_LENGTH_9B  /**< Send opcode, CINSTRDAT0.BYTE0 -> CINSTRDAT1.BYTE7. value = 8*/
} nrf_qspi_cinstr_len_t;
At this moment, I can only read 8 bytes of the 128 byte SFDP register. How can I read all of the bytes in the SFDP register using CINSTR, or is there another method?
Thank you,
Lu Tan
