We use a custom interface board to program and run test programs on our series of tiny BLE modules based on nRF52xxx series (ISP1507, ISP1807, ISP1907).
Our interface board uses a Segger OB Jlink/COM port program running in an ATmel MCU.
We can use nRFGOSTUDIo to run DTM. This works with our configuration.
When we try to run DTM on nRFConnect the program gives an error at connection time. This is result using Segger OB interface for the COM port.
On an alternative setup using an FTDI Com port Intreface nRFConnect DTM works.
WHen do you expect to fix this issue so as to have access to DTM for BLE5.2?? with added coding and data rates?
Best regards
Chris BARRATT CTO Insight SiP
