with regards to nrfconnect ios v2.2, has anything changed with respect to service changed characteristic or service and characteristic discovery?
(behaviors described seen on nRF52832, s132v3, sdk v12.3.0 and nRF52840, s140v6, sdk v15.2.0)
I observe the following behavior pre-2.2:
- Connect to a device and verify that all expected services are present, no bonding
- Disconnect, add additional services programmatically on the embedded device
- Connect to the same device with new services, all new services are missing
- In this state, if bluetooth is disabled then re-enabled from system settings, and I connect again, the services are present
This seems to be some sort of caching issue, and I have seen multiple references to the service changed characteristic in solving this. It was enabled, but I added a call to sd_ble_gatts_service_changed() in a ble event handler similarly to how it is called in peer manager.
Now on connect, the services are present, but they have no associated characteristics. I have confirmed that the BLE_GATTS_EVT_SC_CONFRIM event is generated.
If I disconnect and reconnect, I do now see all expected services with their characteristics.
Forward to today, I updated nrfconnect to v2.2 for ios. With the call to sd_ble_gatts_service_changed() still in place, I still see a list of services without characteristics when services change.
But, if I remove the call to sd_ble_gatts_service_changed(), I can now reliably add and remove services while disconnected and see the correct set upon connection. This is the behavior I'm expecting.
SO, has anything changed in v2.2 of nrfconnect in relation to service/characteristic discovery, the service changed characteristic, or anything similar?
